Extension of an elastic block of Neo-Hookean material
In summary: The boundary conditions on the lateral surfaces are:- ##S n = 0## (i.e. contact forces at the boundary are 0, i.e. I have no traction)- - - - - - - - - - -The boundary conditions on the bottom surface are:- ##u(0)=f(0)-0 = 0## (i.e. origin is fixed during the deformation)- ##u_3(p)= (f(p)-p)\cdot e_3 = 0## (No displacement along e_3)- ##S(-e_3) \cdot e_1 = S(-e_3) \cdot e_
bobinthebox
29
I'm studying elasticity from classical Gurtin's book, and my professor gave us the following example, during lecture. Unfortunately, this is not present in our references, so I'm posting it here the beginning of the solution, and I will highlight at the end my questions. First I need to state the problem clearly:> Let us consider a body ##B## which has as reference configuration a cube ##[0,b] \times [0,b] \times [0,h]## of incompressible, Neo-Hookean material, without body forces acting on the body.
In the following, ##S## will be the first Piola-Kirchoff stress tensor, and ##f## will indicate the homogeneous deformation.
Boundary conditions on the lateral surfaces:
Boundary conditions on the bottom surface:
- ##S(-e_3) \cdot e_1 = S(-e_3) \cdot e_2 = 0## (Body is constrained to a frictionless plane)
Boundary conditions on the top surface:
- ##u_3(p)=\delta## (we allow displacement of an amount $\delta$ on direction $e_3$
- ##S(e_3) \cdot e_1 = S(e_3) \cdot e_2 = 0##- - - - - - - - - - - - -
**Attacking the problem**
To solve it, we make an ansatz, i.e. that the deformation is going to be homogeneous. The field equation is ##\operatorname{div}(S)=0##, since there are no body forces. Also, since the material is Neo-Hookean, we have ##T=\mu B - \pi I##, and hence the first Piola ##S## is:
$$S = \mu F - \pi F^{-T}$$Here's where I start having big troubles: I will write in bold where I can't understand
Considering the polar decomposition of the deformation gradient ##F##, ##F=RU##, we notice that ##R=I## (**why is that**?) and hence ##F=U## and so $$F=\lambda_1 e_1 \otimes e_1 + \lambda_2 e_2 \otimes e_2 + \lambda_3 e_3 \otimes e_3$$ where ##\lambda_i## are the principal stretches. Therefore, ##\lambda_3 = \frac{h+\delta}{h}## (**why this ratio?**)
Also, by invariance w.r.t rotation around ##e_3## we have ##\lambda_1 = \lambda_2 = \lambda##. How can I see that I have invariance under rotations about ##e_3##? Also, why does this imply that the two principal stretches are the same?
You are saying that you have a uni-axial homogeneous deformation in the 3 direction, and no constraint in the 1 and 2 directions, right?
@Chestermiller, thanks for your reply. Yes, given those boundary conditions I think I am in the situation you wrote.
@Chestermiller I have just changed my first post, so maybe it's more clear what are the points where I need a clarification.
In the situation you have, if you drew differential position vectors between pairs of adjacent material points in the 1, 2, and 3 directions of the original configuration of your body, do you think they would change direction in the final configuration of your body?
@Chestermiller
No, I don't think they would change direction. So after the deformation I would not see any rotation, hence ##R=I## and hence ##F=U##, which means that I have only a stretch, right?
However, I still can't see why ##\lambda_3 = \frac{h+\delta}{h}##, could you explain me why?
bobinthebox said:
@Chestermiller
bobinthebox said:
correct
What is the ratio of the final length to the initial length in the 3-direction of this homogeneous deformation.
Well, precisely ##\frac{h+ \delta }{h}##.
So, ##\lambda_3## has that form because it is the amount of extension.
One last question: why does the professor say that there's invariance w.r.t rotation around ##e_3##? Is it possible to prove it formally? Why does this imply ##\lambda_1 = \lambda_2 ##? @Chestermiller
Suppose I rotated the sample 90 degrees about the 3 axis. Could you tell the difference?
I see. No, I wouldn't be able to tell the difference. This implies that the amount of extension in direction ##e_1## and ##e_2## will be the same, hence ##\lambda_1 = \lambda_2##.@Chestermiller I think I got it, thanks :-)
I'm sorry but I have a very last question: my professor said to try to write which should be the boundary conditions in order to let the lateral surfaces of the body slight on a plane parallel to ##e_1, e_3##. I honestly don't know how to move. I assume I should change also the way/direction in which the body is deformed, right?
I don't understand what he is asking for.
FAQ: Extension of an elastic block of Neo-Hookean material
What is the Neo-Hookean material model?
The Neo-Hookean material model is a common model used to describe the behavior of elastic materials. It assumes that the material is incompressible and has a nonlinear relationship between stress and strain.
How is the extension of an elastic block of Neo-Hookean material calculated?
The extension of an elastic block of Neo-Hookean material can be calculated using the equation: ΔL = L(λ^2 - 1)/2, where ΔL is the change in length, L is the original length, and λ is the stretch ratio.
What factors affect the extension of an elastic block of Neo-Hookean material?
The extension of an elastic block of Neo-Hookean material is affected by the material's properties, such as its Young's modulus and Poisson's ratio, as well as the applied load and the geometry of the block.
How does the extension of an elastic block of Neo-Hookean material differ from other material models?
The Neo-Hookean material model differs from other models, such as Hooke's law, in that it accounts for the nonlinear relationship between stress and strain. It also assumes that the material is incompressible, which is not the case for other models.
Can the Neo-Hookean material model accurately predict the behavior of all elastic materials?
No, the Neo-Hookean material model may not accurately predict the behavior of all elastic materials. It is best suited for materials that exhibit incompressible and nonlinear behavior, and may not be suitable for materials with different properties or behaviors.
27K
