sreerajt
- 39
- 1
What are the difference between extensive and intensive quantities?
Extensive and intensive quantities are terms used in science to describe the properties of a system. Extensive quantities are those that depend on the size or amount of the system, while intensive quantities do not.
An example of an extensive quantity is mass. The mass of a system will increase as the size or amount of the system increases. This means that the mass is dependent on the size of the system and is therefore an extensive quantity.
An example of an intensive quantity is temperature. The temperature of a system will remain the same regardless of the size or amount of the system. This means that the temperature is not dependent on the size of the system and is therefore an intensive quantity.
Extensive and intensive quantities are related in that they both describe properties of a system. However, they differ in that extensive quantities change with the size or amount of the system, while intensive quantities do not.
Understanding extensive and intensive quantities is important in science because it helps us to better understand and analyze systems. By categorizing properties as either extensive or intensive, we can make more accurate predictions and interpretations of how a system will behave.
