MHB External and Internal Direct Sums - Bland - Rings and Their Modules
Bland's book "Rings and Their Modules" distinguishes between external and internal direct sums of R-modules, with specific definitions for each. The external direct sum requires that elements are zero for almost all indices, which addresses potential divergence in sums. In contrast, Bland's internal direct sum does not explicitly mention this condition, leading to confusion about the convergence of sums. Peter realizes that Bland assumes all sums are finite, thus avoiding divergence issues, a point he initially overlooked. The discussion highlights the importance of understanding the nuances in definitions between different authors, such as Bland and Northcott.
Math Amateur
MHB
In Paul E. Bland's book: Rings and Their Modules, the author defines the external direct sum of a family of $$R$$-modules as follows:
Two pages later, Bland defines the internal direct sum of a family of submodules of an $$R$$-module as follows:
I note that in the definition of the external direct sum, Bland defines the elements $$( x_\alpha)$$ of the external direct sum as follows:
$$( x_\alpha) \in \prod_\Delta M_\alpha \ | \ ( x_\alpha) = 0 \text{ for almost all } \alpha \in \Delta $$
In doing this, the way I interpret him, Bland seems concerned that 'sums' of the form $$\sum_\alpha x_\alpha$$ do not diverge ... but why? ... he has no such sums involved ...?
Can someone help clarify this issue?Further, however, when we inspect Bland's definition of the internal direct sum (see above), we find no such care with the definition of the $$x_\alpha$$ - that is no mention of "$$( x_\alpha) = 0 \text{ for almost all } \alpha \in \Delta$$"
... ... BUT ... ... with the internal direct sum as defined by Bland, we are definitely dealing with the sum
$$\sum_\Delta M_\alpha = \{ \sum_\Delta x_\alpha \ | \ x_\alpha \in M_\alpha \}$$Now, how do we know that these sums exist - that is, do not diverge ... ?
Well, my thinking is that since we are dealing with submodules $$M_\alpha$$ of an $$R$$-module $$M$$, each sum must 'converge' to an element $$x = \sum_\Delta x_\alpha$$ ... ... ... whereas in the case of the external direct sum, no such guarantee exists ... ... Can someone please confirm/critique my thinking ... Help will be appreciated ... ...
Peter
***EDIT*** ... ... CONFUSION ... ...
Just a note to say I am now somewhat confused ... ...
I was checking the ideas of direct sums in D. G. Northcott's book: Lessons on Rings, Modules and Multiplicities and found the following introduction to direct sums including a definition of an internal direct sum ... ... as follows:https://www.physicsforums.com/attachments/3464Note that in his definition of internal direct sum above, unlike Bland, Northcott specifies "$$x_i = 0 \text{ for almost all i}$$" ... ...
... ... BUT ... ... maybe the difference is that Northcott talks about "each element $$x$$ of $$M$$" having "a unique representation ... ... " ... ... maybe this explains the difference ...
Can someone please clarify the difference between Bland's and Nothcott's definitions ...
Peter
If you turn to Chapter 0, Section 0.4, you will see a discussion on the meaning of the notation $\sum_{\Delta} x_\alpha$. On page 5, Bland writes,
"From this point forward, all such sums $\sum_{\Delta} x_\alpha$ are to be viewed as finite sums and the expression '$x_{\alpha} = 0$ for almost all $\alpha \in \Delta$' will be omitted unless required for clarity."
Thanks Euge ... Oh ... Missed that ... Thanks ... That definitely clarifies the issue ... must read more carefully ...
Thanks again,
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
