Will External Magnets Affect PMDC Motor Armature Rotation?
In summary, in a PMDC motor, the armature rotates with the help of magnets. If external magnets are added, the rotation of the armature may change. However, increasing the strength of the magnets can actually slow down the rotation of the armature due to an increase in the motor constant and torque. This may improve efficiency by reducing heat loss, but the manufacturer has likely already optimized the motor's magnetic circuit. Overall, using powerful rare earth magnets can make the motor more efficient compared to weaker ferrite magnets.
naeem shaik
generally in the pmdc motor the armature will rotate.As it works with the help of magnets ,if i provide external magnets to motor ,there will be any change in the rotation of armature?
Probably.
It might seem surprising but the stronger the magnets the slower it will go.
In principle: Yes.
If you strengthen the magnetic field in the airgap, you will increase the motor constant, Km . Thus you will increase the back-emf in the motor [ V/ω ], which will make the motor turning slower at constant supply voltage ( unloaded ).
At the same time you will increase the torque [ Nm/A ] at constant supply current.
However I don't think you can improve the motor performance significant, because the manufacturer has already optimized the magnetic circuit of the motor.
Likes naeem shaik
Increasing the motor constant allow you to reduce the number of turns and yet achieve the same rpm. Reducing the number of turns on the armature reduces the resistance and that reduces the heat loss ("copper losses"). This is why motors with powerful rare Earth magnets are more efficient than motors with weaker ferrite magnets.
Likes naeem shaik
thank you
FAQ: Will External Magnets Affect PMDC Motor Armature Rotation?
How do external magnets affect a PMDC motor?
External magnets can significantly increase the performance and efficiency of a PMDC motor. By placing additional magnets on the outside of the motor, the magnetic field is strengthened, resulting in a stronger torque and faster rotation.
What types of magnets are typically used for external magnets in PMDC motors?
The most commonly used magnets for external magnets in PMDC motors are rare earth magnets, such as neodymium or samarium-cobalt. These magnets have a strong magnetic field and are able to produce a significant increase in motor performance.
How are external magnets installed on a PMDC motor?
External magnets can be attached to the motor in various ways, such as gluing, clamping, or screwing them onto the motor casing. It is important to ensure that the magnets are securely attached and properly aligned for optimal performance.
What are the benefits of using external magnets in a PMDC motor?
The use of external magnets in a PMDC motor can lead to increased torque, higher efficiency, and improved speed control. It can also extend the lifespan of the motor by reducing wear and tear on the internal components.
Are there any drawbacks to using external magnets in a PMDC motor?
One potential drawback of using external magnets is the added weight and size to the motor. This can affect the overall size and portability of the motor. Additionally, if not properly installed, the magnets could cause interference with the motor's internal magnetic field, leading to performance issues.
