Extra negative in in Laplace transform solution
In summary, an extra negative in a Laplace transform solution refers to an additional minus sign that appears in the solution compared to the original function. This can happen due to the property of linearity, where a constant can result in an extra negative if it is negative. To avoid this, attention should be paid to negative signs in the original function and the solution should be double checked for any errors. While an extra negative will not affect the accuracy of the solution, it can easily be corrected by multiplying the solution by -1.
abalmos
I have the correct solution of this problem ([tex]cos(t)+u_{3\pi}[1-cos(t-3\pi)][/tex]). As you can tell from my solution below I am off by a extra negative sign on the cos(t) coefficient. I have had this same issue on several other problems, so I believe I must be missing something on the procedure. Any guidance would be much appreciated!
Solve IVP [tex]y'' + y = u_{3\pi}(t) \left\{y(0)=1, y'(0)=0[/tex]
My solution:
[tex]s^{2}Y(s) + sY(0) + Y'(0) + Y(s) = \frac{e^{-3\pi s}}{s}[/tex]
[tex]Y(s)(s^{2} +1) + s = \frac{e^{-3\pi s}}{s}[/tex]
[tex]Y(s) = \frac{e^{-3\pi s}}{s(s^{2}+1)} - \frac{s}{(s^{2}+1)}[/tex]
[tex]H(t) = \frac{1}{s(s^{2}+1)}[/tex]
[tex]h(t) = Y(H(t))[/tex]
[tex]y = u_{3\pi}h(t-3\pi}) - cos(t)[/tex]
[tex]h(t) = \frac{1}{s} - \frac{s}{s^{2}+1}[/tex]
[tex]h(t) = 1 - cos(t)[/tex]
so ...
[tex]-cos(t) + u_{3\pi}[1-cos(t-3\pi)][/tex]
I have seen in other examples (http://tutorial.math.lamar.edu/Classes/DE/IVPWithStepFunction.aspx , example 2) which have similar setups, and I noticed that when the little h is introduce (the inverse transformation to the [tex]u_{3\pi}[/tex] term) the sign of the [tex]cos(t)[/tex] term changes but I do not understand why.
Thank you so much for help and guidance you can provide!
- Andrew Balmos
Dear Andrew,
Thank you for sharing your solution and your question. It seems like you have a good understanding of the procedure for solving this type of problem, but you may be missing a key concept when it comes to the step function.
When we use the Laplace transform to solve differential equations with step functions, we are essentially splitting the solution into two parts: one for the case where the step function is "on" (equal to 1) and one for when it is "off" (equal to 0). In your solution, you correctly identified the function h(t) that corresponds to the step function H(t), but you may have missed that h(t) is only valid for t > 0. This means that for t < 0, the solution should be 0, since the step function is "off" and does not affect the solution.
So, when you introduce the inverse transformation h(t) and plug it into the solution for y, you need to take into account the fact that for t < 0, h(t) = 0. This is why the sign of the cos(t) term changes - it is being multiplied by 0 for t < 0. In the solution you referenced from Lamar University, they explicitly mention this and include a piecewise function to handle this case.
In summary, the extra negative sign on the cos(t) coefficient is not incorrect, it is just accounting for the case where t < 0. I hope this helps clarify things for you. Keep up the good work and don't be afraid to ask for guidance when needed. Science is a collaborative field and we all learn from each other. Best of luck in your studies!
FAQ: Extra negative in in Laplace transform solution
What is an extra negative in a Laplace transform solution?
An extra negative in a Laplace transform solution refers to an additional minus sign that appears in the solution compared to the original function. This can happen when the function being transformed has a negative sign in front of it, which can be easily overlooked.
Why does an extra negative appear in a Laplace transform solution?
An extra negative can appear in a Laplace transform solution due to the property of linearity. When taking the Laplace transform of a function multiplied by a constant, the constant can be pulled out and multiplied by the Laplace transform of the function. This can result in an extra negative if the constant is negative.
How can I avoid an extra negative in a Laplace transform solution?
To avoid an extra negative in a Laplace transform solution, it is important to pay attention to any negative signs in the original function. These should be properly accounted for when taking the Laplace transform. It can also be helpful to double check the solution for any potential errors.
Can an extra negative affect the accuracy of a Laplace transform solution?
No, an extra negative will not affect the accuracy of a Laplace transform solution as long as it is properly accounted for. The Laplace transform is a linear operation, so the overall solution will still be correct. However, it is important to be aware of the extra negative to avoid any confusion or errors.
How can I correct an extra negative in a Laplace transform solution?
If an extra negative is discovered in a Laplace transform solution, it can be easily corrected by simply multiplying the entire solution by -1. This will remove the extra negative and result in the correct solution for the original function.
