Extracting sigma from sum of distributions with moving mean
In summary: I understand the setup well enough to give a definitive answer. But it sounds like you have a clear understanding of the experiment and the data, so I would suggest using a statistical approach to analyze the data and see if your assumptions hold up. That way, you can determine the relationship between x and y and see if there is a simple way to relate the mean of y to the resulting sigma_x. However, if the assumptions do not hold up, then it may not be possible to accurately back out the effect from the data.
ArchieDave
I have an experiment in which I want to extract the distribution function of a process. I expect it to be Gaussian. Each data point measured is an entire distribution, f(x), but I am forced to average over many points such that the result of the experiment is the sum of many measurements of f(x). If A and σ are believed to be constants but the mean, μ, varies a little for each point, the resulting sum of distributions appears broader as if σ is larger. My question: If I believe I know the deviation of the mean μ, can this affect be subtracted out so that I am left with the actual value of σ?
I'm not sure what you mean with "Each data point measured is an entire distribution". If every data point is a point, but comes from a distribution with fixed σ and variable μ, then it is possible. The measured standard deviation of your data points will be the quadratic sum of σ and the standard deviation of μ:
$$\sigma_{total} = \sqrt{\sigma^2 + \sigma_\mu^2}$$
Let me clarify. I'm running an experiment for which each result (what I called point) is a trace that gives a distribution. Based on the nature of the experiment, the standard deviation should be the same for each trace. However, there is a random shift of the mean that can obviously be measured. In order to achieve sufficient signal/noise, I must average over many traces such that this shifting of the mean causes a widening of the summation. I wasn't completely sure how to subtract out this effect. I wasn't able to find the solution in my old stats book that I had to dust off. I believe you answered the question, but I was also hoping to see this relationship proven. Thanks for the help.
If you can measure the shift for each data point, then you can do better - you can just shift your measurement to correct for it (and take the uncertainty of this correction as uncertainty on μ). If σμ is small compared to σ this won't make a significant difference, but if the two are comparable it can be a huge improvement.
Sorry again for the poor explanation. Because of the nature of the experiment, I can't measure the mean directly from each trace, but I can infer the deviation of the mean indirectly from other data.
If you can do repeat measurements within the same distribution, before the mean changes, then you can estimate the variance for each distribution and draw some conclusions. Otherwise, you can not statistically separate the variation of distribution mean from the variation for a single distribution with a fixed mean. If you know why and how the mean changes, maybe you can back that out from the data before applying statistical methods. Otherwise, I don't think you can do anything to estimate the variance at a fixed mean.
Follow up question. I get that if I know σ_μ than I can back out σ. Now if the distribution is bivariate such that the trace I see is actually g(x,y=0) and I also have some variation in the mean of y, is there a simple way to relate the mean of y to the resulting sigma_x? In other words, I will be averaging over g(x,y=+/-dy) and the trace (distribution) I see will appear broader. If I assume sigX=sigY, it seems as though I could back out σ again. Thanks again.
How are y and x related?
It would help to know more about the setup and your datasets...
I'd avoided explaining for fear it might devolve off topic, but here goes. My question is not actually directly related to statistics but I have reason to assume a normal distribution so it seemed like a good place to pose the question. I have a 2D distribution of particles injected into a gas medium that I can image using a gated camera and a laser that provides excitation (LIF images). I want to study the rate of diffusion (take the image at different times). The result should be symmetric and gaussian. However, the limitations are that I need to accumulate over many shots/injections in order to see a distribution for a given moment in time after the particles enter. Also, I know from using a medium with higher signal that while sigma is not expected to change at one point in time, the centerline/mean varies from shot to shot. I can measure this under other circumstances and I'd like to back out the effect from the intensity/population distributions that I see. Imagine trying to measure the spread of bird shot by looking at a target but needing to subtract out changes in centerline trajectory caused by imperfect rifleman.
So if I only needed to worry about the dimension in the direction of the beam (x-direction), I'd just use the equation you provided to subtract out the deviation of the mean, which I measure under other circumstances. However, since there is variation in the y-direction (perpendicular to beam) as well, I will be "missing" the centerline and getting a broadening effect there as well. It would be easy for me to generate a 2D normal distribution, assign random values for sigma within a confidence interval of my determination and take the average of a single line over many thousands of points and perform this repeatedly until I arrive at the answer/distribution that I see. However, I'd prefer to just find an actual solution. Any help is, again, greatly appreciated.
For diffusion, x and y are independent, yes you can ignore y then (or look at it separately).
hmmm
I understand that the rate of diffusion is independent for x and y, but if I'm measuring distribution over many "shots" and it's moving in y than I'll be probing a different point at each measurement. The distribution will appear broader when y ≠ 0, correct?
Why should the x-distribution change if your y moves?
Because the function f(x,y) such that f(x,y=const) is different for all y? I'm just looking at the equation for a bivariate normal distribution.
Why should the x-dependence be different?
Independent variables mean you can find g, h such that f(x,y)=g(x)*h(y). You don't have to care about h to find g.
Related to Extracting sigma from sum of distributions with moving mean
1. What is the purpose of extracting sigma from the sum of distributions with moving mean?
The purpose of extracting sigma is to understand the variability or spread of the data in a distribution. This can help in making statistical inferences and predictions.
2. How is sigma related to the sum of distributions with moving mean?
Sigma is a measure of dispersion or variability in a distribution, and it is directly affected by the sum of distributions with moving mean. As the mean of a distribution changes, so does the spread of the data points, resulting in a change in sigma.
3. What are the steps involved in extracting sigma from the sum of distributions with moving mean?
The first step is to calculate the mean of each distribution. Then, the difference between each distribution mean and the overall mean (moving mean) is squared and summed. This sum is divided by the total number of data points, and the square root of this value is the standard deviation or sigma.
4. Can sigma be negative when extracting from the sum of distributions with moving mean?
No, sigma cannot be negative. It is a measure of spread and is always positive or zero. If the calculated sigma is negative, it is most likely an error in calculations.
5. How does extracting sigma help in analyzing data?
Extracting sigma allows us to understand the variability or spread of the data points in a distribution. This information can be used for making statistical inferences, identifying outliers, and determining the accuracy of predictions based on the data.
