Extracting zero-point energy using the Casimir effect?
In summary: Number 1/ to start the process up again.In summary, the Casimir effect is used to extract energy from a flowing water fall.
johne1618
371
Hi,
People have hypothesized that one could extract energy from the zero-point field using the Casimir effect by letting the two conducting plates move together and do some useful work.
But surely to reset the system one needs to supply the same amount of work to separate the plates again so no net work is done by such a system?
Is that correct?
John
I had subscribed to this thread, hoping that someone with some useful contribution would respond. But since I am somewhat curious myself, let me try to get this discussion started...
Your argument makes sense. This sounds a bit like a perpetuum mobile (which would make this impossible a priori), but I'm not sure it technically is one... after all, AFAIK it is a commonly accepted theory that virtual particles can become "real", for example if they are created near a black hole and one is sucked in.
So can you get a little more specific who "people" are and how they visualise this extraction of energy?
Sakharov, Haisch, Rueda, and Puthoff all have thought that energy might be extracted from the zero-point field. The latter three had some research financed by NASA's Breakthrough Propulsion program. Sakharov urged his government to ban zero-point experimentation, thinking it was too dangerous (the destroy-the-universe kind of dangerous). So far, no practical extraction of energy, only theoretical "what-ifs".
No, energy can't be extracted using the Casimir effect. Puthoff & Co are infamous crackpots. (From what i understand, Puthoff hasn't done a single serious thing in physics since he got his PhD. But he's done quite a lot of non-serious stuff, such as vouching for Scientology and Uri Geller)
Neither QED in general, or the Casimir effect in particular, or virtual particles allow for the violation of conservation of energy (despite some popular-scientific descriptions to that effect). That's really all there is to it as far as I'm concerned.
johne1618 said:
Hi,
Is that correct?
John
Hi John;
Some years ago Robert Forward sent me some stuff he was working on at Hughes Labs for the Air Force.
I found this one to be interesting with regards to your Casimir energy question:
http://www.calphysics.org/articles/Forward1984.pdf
Creator
Also I found your thread on Zitterbewegung and spin to be astute enough to warrant a reply but haven't found the time to give it the attention it deserves.
Maybe I can get to it later.
Hi,
Thanks for link to Robert Forward's paper.
How about this for a Casimir energy machine cycle?
1/ Start with two conducting plates placed opposite each other at separation d.
2/ Let the Casimir force pull the plates together and use the resulting energy to do some useful work.
3/ Now slide the plates apart - hopefully this shouldn't require much energy.
4/ Separate the plates by distance d again. This shouldn't take much energy as long as they are *not* opposite each other while you separate them.
5/ Now slide them so that they are back opposite each other at separation d.
6/ Repeat
John
It takes at least as much energy as you got in work. It's a conservative force.
You might as well suggest the same only using gravity, or London forces. (Incidentally, London forces are related to the Casimir effect.)
I once saw an article which basically relayed calculations which suggesged plates the size of a city could generate useful power.
If I recall correctly, it was exploiting the fact that the plates are not pulled together uniformly by the Casimir vacuum thus there would be miniscule waves in each plate, the energy of which could be extracted.
I don't know whether the Casimir Force is conservative of not.
Maybe the situation is analogous to that of extracting energy from a water fall.
1/ We slide a plate into the flowing water.
2/ The pressure of the water pushes the plate down and does useful work.
3/ We slide the plate out of the stream of water.
4/ We move the plate up to its original position.
5/ Repeat
Number 2/ is like the Casimir force in that it is induced by a pressure difference.
Except that the maximum amount of work done, is mgh, where m is the mass of the plate and h is the difference in height. And once the plate has been slid out from under the water fall, you will need at least that same amount of energy to push it back up. The trick being, of course, that gravity is definitely conservative.
Related to Extracting zero-point energy using the Casimir effect?
1. What is zero-point energy?
Zero-point energy is the lowest possible energy state that a quantum mechanical physical system can have. It is the energy that remains when a system is at its lowest possible energy state, even at absolute zero temperature.
2. What is the Casimir effect?
The Casimir effect is a phenomenon in quantum field theory where two uncharged parallel plates placed in a vacuum experience an attractive force due to the fluctuations in the surrounding electromagnetic field. This force is caused by the difference in the number of virtual particles outside and inside the plates.
3. How does the Casimir effect relate to zero-point energy?
The Casimir effect is a result of the fluctuations in the electromagnetic field, which is a manifestation of zero-point energy. This means that zero-point energy is responsible for the attractive force between the parallel plates, as it is the fluctuations in the field that cause the force.
4. Is it possible to extract zero-point energy using the Casimir effect?
While the Casimir effect is a result of zero-point energy, it is not currently possible to directly extract zero-point energy using this phenomenon. However, some researchers are exploring ways to indirectly harness zero-point energy through the Casimir effect, but this technology is still in its early stages and has not been proven to be feasible.
5. What are the potential applications of extracting zero-point energy using the Casimir effect?
If it were possible to harness zero-point energy through the Casimir effect, it could have significant implications in various fields, including energy production, nanotechnology, and quantum computing. However, more research and development is needed before any practical applications can be realized.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Beyond the Standard Models
