Extreme case of relativitic momentum
  • Thread starter KFC
  • Tags
    Momentum
In summary: Yes, the momentum given by these two expressions are the same. For question 2...In extreme case (when v->c), the first expression will give infinite large momentum? How would that happen? If we use the second expression to find the momentum in extreme case, what will energy E there look like? Anyway, I just wonder how to find the momentum in extremem case. Your first formula for p, and the formula I gave for E, are not usable for photons, which have m_0 = 0 and v = c, because they both give 0/0 which is undefined mathematically.Your second formula for p, on the other hand, is usable for photons, and gives p = E/c
KFC
488
The relativitic momentum is given by
[tex] p = \frac{mv}{\sqrt{1-v^2/c^2}}[/tex]
or
[tex]
p = \frac{\sqrt{E^2 - m_0^2c^4}}{c}
[/tex]
where [tex]m_0[/tex] is the rest mass.
I have two questions about the momentum
1) Are the momentum given by these two expression the same?
2) In extreme case (when v->c), the first expression will give infinite large momentum? How would that happen? If we use the second expression to find the momentum in extreme case, what will energy E there look like? Anyway, I just wonder how to find the momentum in extremem case.
Thanks
or
[tex]
[/tex]
Thanks
Start by expressing the momentum of a particle as
p=p'(1+V/u')/(1-VV/cc)^1/2 (1)
In the limi case u'=c
p=p'sqr[(1+V/c)/1-V/c]1/2 (2)
equation (2) performing the transformation of the momentum of a photon.
Thanks for your reply. But I have no idea how do you get this. What does u', p' and V represent?
Small correction: in the equation above, [itex]m[/itex] should be [itex]m_0[/itex].
or
[tex]
[/tex]
Yes. To show this, you need to use the following equation for energy:
[tex]E = \frac{m_0 c^2}{\sqrt{1-v^2/c^2}}[/tex]
As [itex]v \rightarrow c[/itex], [itex]\sqrt{1 - v^2 / c^2} \rightarrow 0[/itex]. But this is in the denominator, so the whole expression [itex]\rightarrow \infty[/itex].
The expression I gave for E also has [itex]\sqrt{1 - v^2 / c^2}[/itex] in its denominator, so [itex]E \rightarrow \infty[/itex] also.
Thanks. But I think the momentum shouldn't be infinite large even when v->c. For example, a photon is moving at the speed of light, it still have a finite wavelength so the finite momentum, right? My question is how to find the finite momentum for extreme case.
Your first formula for p, and the formula I gave for E, are not usable for photons, which have [itex]m_0 = 0[/itex] and [itex]v = c[/itex], because they both give 0/0 which is undefined mathematically.
Your second formula for p, on the other hand, is usable for photons, and gives p = E/c.
The general equation v=pc/E, may clarify things for you.
The equation I find most useful is (E)2 - (pc)2 = (mc2)2. This is valid for all particles at all velocities.
o.k. Consider that the same tardyon (a particle the speed of which never exceeds c) is detected from the inertial reference frames I and I'. I' moves with constant speed V in the positive direction of the x,x' axes/ Let p and E be momentum and the energy of the tardyon when detected from I and I' respectively. The tardyon moves with speed u relative to I and with speed u' relative to I'. The momentum p and the energy of the tardyon are related in I by
p=Eu/cc (1)
and I' by
p'=E'u'/cc (2)
p and p' are related by the transformation equation [1]
p=[p'+VE'/cc]/sqr(1-VV/cc)]= p'[1+V/u']]/sqr(1-VV/cc) (3)
Replacing the tardyon considered so far by a photon (u'=c) (3) becomes
p=p'sqr[(1+V/c)/(1-V/c) (4)
equation (4) performing the transformation of the momentum of photons.
[1] Robert Resnick, Introduction to Special Relativity (John Wiley and Sons New York, 1968) p.144 (Probably there are newer editions)
or
[tex]
[/tex]
For question 1 my answer is: indeed these two equations are of the same family. Since T=mc^2-m_0c^2=E-m_c^2,
you can refrase the formula for kinetic energy without the huge potential energy.
Perhaps that will help?
FAQ: Extreme case of relativitic momentum
What is an extreme case of relativistic momentum?
An extreme case of relativistic momentum refers to situations where the momentum of an object approaches the speed of light. This occurs when the object's velocity is a significant fraction of the speed of light, typically above 0.1c.
How does the momentum of an object change at high velocities?
At high velocities, the momentum of an object follows the principles of special relativity. This means that as the object's velocity increases, its momentum increases as well, but it approaches a maximum value as it approaches the speed of light.
What is the formula for calculating relativistic momentum?
The formula for calculating relativistic momentum is p = mv/√(1-(v^2/c^2)), where p is momentum, m is mass, v is velocity, and c is the speed of light.
How does relativistic momentum affect the mass of an object?
At high velocities, the mass of an object increases due to relativistic effects. This is known as relativistic mass and it increases as the object's velocity approaches the speed of light.
What are the practical applications of studying relativistic momentum?
Studying relativistic momentum is important in fields such as astrophysics, particle physics, and nuclear physics. It helps us understand the behavior of objects moving at high velocities and is essential for developing theories such as special relativity.
