Extreme Ultraviolet Wavelength Question
In summary: Solar and Heliospheric Observatory (SOHO), there are 4 different Extreme Ultraviolet Imaging Telescopes, each with a different wavelength: 171 Angstrom, 195 Angstrom, 284 Angstrom, and 304 Angstrom. 171 Angstrom is meant to view a much lower temperature, despite a higher angstrom than the previous 3. 195 Angstrom and 284 Angstrom are meant to observe the pattern of rising temperature corresponding to higher angstroms. Conversely, 304Å is meant to view a much lower temperature, despite a higher angstrom than the previous 3.
Polyverse
On the Solar and Heliospheric Observatory (SOHO), a satellite which observes the sun from the First Lagrangian Point, there are 4 different Extreme Ultraviolet Imaging Telescopes, each with a different wavelength:
171 Angstrom - 1 million degrees Kelvin
195 Angstrom ~1.5 million degrees Kelvin
284 Angstrom - 2 million degrees Kelvin
304 Angstrom - 60,000 to 80,000 degrees Kelvin
For 171Å, 195Å, and 284Å, you can observe the pattern of rising temperature corresponding to higher angstroms. Contrarily, 304Å is meant to view a much lower temperature, despite a higher angstrom than the previous 3.
Additionally, I always thought that the longer the wavelength, the cooler the observed material would be, which contradicts 195Å and 284Å observing hotter material than 171Å.
Clarification of this would be greatly appreciated.
Source: http://sohowww.nascom.nasa.gov/data/realtime/image-description.html"
Science news on Phys.org
why would you say 304Å is meant to look at a lower temp.
The website ( my daily favourite place to visit... I have been saving images from there almost since SOHO was established) tells you why 304 is hotter, its higher in the atmosphere.
there's a secret here that you may not be aware of...
The chromosphere (coronal region) is substantially hotter at millions of K compared to the ~ 6k K of the photosphere ( the sun's surface)
A little bit from Wiki to get you started on some personal research...
The coronal heating problem in solar physics relates to the question of why the temperature of the Sun's corona is millions of kelvin higher than that of the surface. The high temperatures require energy to be carried from the solar interior to the corona by non-thermal processes, because the second law of thermodynamics prevents heat from flowing directly from the solar photosphere, or surface, at about 5800 K, to the much hotter corona at about 1 to 3 MK (parts of the corona can even reach 10 MK). The amount of power required to heat the solar corona can easily be calculated, that one required to balance coronal radiative losses and the thermal conduction toward the chromosphere through the steep transition region. It is about 1 kilowatt for every square meter of surface area on the Sun, or 1/40000 of the amount of light energy that escapes the Sun...
It continues on further but I will let you do some discovery :)
Its an awesome topic and one I have been into since I was a kid doing my first sunspot drawings
cheers
Dave
PS ... The 304Å HeliumII is a good one to keep an eye on it shows the awesome prominences hanging above the sun :)
Please re-read the numbers I have posted (which are taken from http://sohowww.nascom.nasa.gov/data/realtime/image-description.html" ):
60,000 to 80,000 degrees Kelvin is cooler than 1 million, 1.5 million or 2 million degrees Kelvin.
Yet the angstroms appear to increase with temperature except for 304, where instead of being a higher temperature, it is instead a lower temperature.
For those interested, I seem to have found an answer to my own question (feel free to correct this if it is wrong/inaccurate):The following information is found at http://web.williams.edu/astronomy/jay/solarlinks":
a) Helium II (that is, ionized helium, given that He I is neutral helium) at 304 Å. It shows gas at temperatures of about 60,000 K. (Note that K stands for kelvin, a unit using Celsius degrees but starting at absolute zero, –273°C. Since temperatures we are discussing are in the thousands or millions of degrees, we can ignore for our purposes the differences between K and °C.)
b) Iron IX (that is, iron that has lost eight of its electrons) at 171 Å. It is at a temperature of about 1,000,000 K.
c) Iron XII (that is, iron that has lost eleven of its electrons) at 195 Å. It is at a temperature of about 1,500,000 K.
d) Iron XV (that is, iron that has lost fourteen of its electrons) at 284 Å. It is at a temperature of about 2,000,000 to 3,000,000 K.
It seems that the extreme ultraviolet telescopes are viewing the emission spectra of different atoms, and that their emission wavelengths correspond to the temperature of that specific atom at those temperatures.
Thanks to http://www.sciencechatforum.com/" for help with the answer.
exactly right :)
yeah sorry I didnt read your original comment correctly. thanks for pointing that out ;)
and I also forgot to comment that the first 3 were ionised iron and the 4th (304) was
different element ie. heliumII
that was more relevant than anything else
Dave
FAQ: Extreme Ultraviolet Wavelength Question
1. What is extreme ultraviolet wavelength?
Extreme ultraviolet wavelength refers to a type of electromagnetic radiation that has a very short wavelength, ranging from 10 to 120 nanometers. This type of wavelength falls between the far ultraviolet and soft X-ray regions on the electromagnetic spectrum.
2. How is extreme ultraviolet wavelength produced?
Extreme ultraviolet wavelength is produced through a process called high harmonic generation, where intense laser pulses are focused on a gas target to generate high-energy photons in the extreme ultraviolet range.
3. What are the applications of extreme ultraviolet wavelength?
Extreme ultraviolet wavelength has various applications in fields such as semiconductor manufacturing, lithography, and spectroscopy. It is also used in imaging techniques for studying biological samples and in research on high-energy physics.
4. How does extreme ultraviolet wavelength affect living organisms?
Extreme ultraviolet wavelength is highly energetic and can cause damage to living organisms, particularly to their DNA. However, the Earth's atmosphere filters out most of this wavelength, so it does not pose a significant threat to living organisms on the planet.
5. What are the challenges in working with extreme ultraviolet wavelength?
Working with extreme ultraviolet wavelength presents several challenges, including the need for specialized equipment and facilities, as well as the short lifespan of the photons. Additionally, extreme ultraviolet radiation can be harmful to humans, making safety precautions necessary when working with it.
