Extremely Difficult Extremum Problem.
  • MHB
  • Thread starter Amad27
  • Tags
    Extremum
In summary, In Ackbach's solution, the minimization is done for $y$ in terms of $x$ and $u$ instead of $x$ and $sin(x)$. He solves for $u$ by substituting $x=a-135^{\circ}$ into the original function. He finds that the minimum value is $u=\frac{2}{u-1}$.
  • #36
MarkFL said:
$g(u)$ may be differentiated with respect to $u$. If $u$ is a function of $x$, then we may differentiate $g(u)$ with respect to $x$ via the chain rule.
Hey MarkFL,
Didnt notice about this.
Then if we define
$v = u' = cos(x) - sin(x)$
When isn't $v$ considered part of the derivate as the chain rule? Like
$du/dx$ in the chain rule part ?
Thanks
  • #37
Olok said:
Hey MarkFL,
Then if we define
Thanks
I'm not sure I understand your question. (Wondering)
  • #38
Okay, sorry, I should've been more specific :)
We had the following,
$g(u(x)) = u + \frac{2}{(u-1)}$
What others suggested was,
$g'(u(x)) = 1 - \frac{2}{(u-1)^2}$
But since you had suggested the chain rule, the above $g'(u(x))$ is incorrect.
Then I defined $v = cos(x) - sin(x) = u' = \d{u}{x}$
So that by the chain rule the derivative,
$=g'(u(x))u'(x)$
To get
$(1 - \frac{2}{(u-1)^2})(v)$
Which should be the derivative no? According to the chain rule..
Thanks
  • #39
This is correct.
$g'(u(x))$ means that you differentiate $g$ with respect to its argument (in this case $u$), and afterwards you fill in $u(x)$ for its argument.
As such it is not an application of the chain rule.
Now suppose we define the function $G(x)=g(u(x))$.
Note that this is a different function, although it is often written (sloppily) as $g(x)$.
Then we have by the chain rule that:
$$G'(x)=g'(u(x))\cdot u'(x)$$
  • #40
I like Serena said:
This is correct.
Note that this is a different function, although it is often written (sloppily) as $g(u)$.
Ah - I am starting to see the difference here (more clearly).
So you are differentiating with respect to $u$
You are NOT differentiating with respect to $x$ ?
But keep in mind that $u = u(x)$ is a function.
How can you differentiate with respect to another function?
Thank you!
  • #41
Thank you!
We do not differentiate with respect to a function.
We differentiate with respect to the implicit (unnamed) argument.
And afterwards, we replace the implicit argument in the function definition with what is specified to be substituted.
Btw, strictly speaking, $u(x)$ is not a function.
It's the application of a function $u$ to an unknown value $x$.
The result is a value, and it is this value that gets substituted.Let's make it more explicit, applying it to the functions at hand.
The function $g$ is given by:
$$g(v)=v+\frac {2} {v-1} \tag{1}$$
Note that I've used a different letter for the argument to avoid confusion with the other symbols.
The function $u$ is given by:
$$u(x)=\sin(x) + \cos(x) \tag{2}$$If follows that for instance:
$$g(u(x)) = \big(\sin(x) + \cos(x)\big)+\frac {2} {\big(\sin(x) + \cos(x)\big)-1}$$
Furthermore, the derivative $g'$ is given by:
$$g'(v)=1-\frac {2} {(v-1)^2}$$
Substituting $v=u(x)$, we get:
$$g'(u(x))=1-\frac {2} {(u(x)-1)^2}$$
To highlight the difference we can also write this as:
$$g'(\sin(x) + \cos(x))=1-\frac {2} {\left(\big(\sin(x) + \cos(x)\big)-1\right)^2}$$
  • #42
Ah - I see this system.
So you are suppose we had a function of $t$ as an independent variable.
$g(t) = t + \frac{2}{(t-1)}$
So $t$ is not related to anything else as a function; it is independent.
$g'(t) = 1 - \frac{2}{(t-1)^2}$
Then you are saying we have
$u(x) = sin(x) + cos(x)$ and that like any other function we can substitute.
$g'(u(x)) = 1 - \frac{2}{(u(x) - 1)^2}$
Ok this part seems to be in the clear now, let's move on.
When you set $g'(u(x)) = 0$ and then you find
$u(x) = 0$ at $u = {a}$
We had
$g(t) = t + \frac{2}{t-1}$
How/ whywill
$g(a) = a + \frac{2}{a-1}$ give you the minimum of the original,
$y$ trig function??
Thanks
  • #43
Olok said:
AWhen you set $g'(u(x)) = 0$ and then you find
The symbol $a$ is introduced here without definition.
I'm guessing it is defined as a solution of $g'(a)=0$.
However, that means that:
$$u(x) = a$$
Writing it as $u=a$ is a short hand notation.
How/ whywill
$y$ trig function??
Let's define the original trig function as:
$$G(x) = g(u(x)) \tag 1$$
Then $G(x)$ takes its minimum value when $G'(x)=0$.
That means that:
$$G'(x) = g'(u(x))\cdot u'(x) = 0$$
This happens if $g'(u(x))=0$ or $u'(x) = 0$.
With $a$ as a solution of $g'(a)=0$, we get that $G$ takes a minimum value at $x=u^{-1}(a)$.
The corresponding minimum is:
$$G\Big(u^{-1}(a)\Big) = g\Big(u\big(u^{-1}(a)\big)\Big) = g(a)$$
  • #44
$$u(x) = a$$
Then $G(x)$ takes it minimum value when $G'(x)=0$.
That means that:
With $a$ as the solution of $g'(a)=0$, we get that $G$ takes a minimum value at $x=u^{-1}(a)$.
Okay, so a few things here.
This was a very, very, very, very, very good explanation. No doubts on that. Kudos to I Like Serena!
So we set $g'(u(x)) = 0$ and supposed it happened at $a$
So,
$g'(u(x)) = 0$ at $u(x) = a$ And like you said
$G(x) = g(u(x))$ which is the original trig equation.
$u(x) = a$ would mean
$x = u^{-1}(a)$
$G(u^{-1}(a)) = g(u(u^{-1}(a)))$
By definition,
$u(u^{-1}(a)) = a$ therefore we get,
$G(u^{-1}(a)) = g(u(u^{-1}(a))) = g(a)$
Wow, that is amazing how this works. Because essentially
We (you) have proved that the minimum is indeed at $u(x) = a$
In problems though, it gets very confusing.
When people say
$g(u)$ rather than $g(u(x))$
$g(u)$ means a function of $u$ as $u$ being an independent variable.
$g(u(x))$ means a function of a function $u(x)$ as a composite function.
Because by definition, a single letter would mean an independent variable.
-- This was the source of my confusion, which seems to be better, now. Wow, @I Like Serena, that was a million dollar explanation, I wish I could give a million thanks through MHB, excellent. Thank you very much!
(The rest of the problem is quite simple now)!
  • #45
Olok said:
By definition,
$u(u^{-1}(a)) = a$
Just an observation, we are making the implicit assumption that $u$ is an invertible function.
And furthermore that the range of $u$ covers the domain of $g$, because otherwise we might "miss" a minimum.
When people say
In practice the distinction between independent variables, functions, and composite functions is often not made - especially in physics or engineering.
So you'll typically see $y$, $y(x)$, $y(u)$, and $y(u(x))$ be used interchangeably, even though strictly speaking they are all different.
Not to mention that $x$, $y^{-1}$, and $x(u)$ are used interchangeably, which can be a serious source of confusion.
Normally this works out fine, but sometimes one needs to be alert about what it really means.It does allow us to write a chain rule simply as:
$$\d y x = \d y u \cdot \d u x$$
which makes a lot of intuitive sense, and is more readable than:
$$\d {y^*(x)} x = \d {y(u)} u \cdot \d {u(x)} x$$
where $y^*(x)=y(u(x))$.And it also allows us to write the inverse derivative rule as:
$$\d x y = \frac{1}{\d y x}$$
instead of the cumbersome:
$$(f^{-1})'(y) = \frac{1}{f'(f^{-1}(y))}$$
  • #46
That is disappointing.
This means,
$f(x) = x^2$ could mean
$f(x) = sin^{2}(t)$
where $x = sin(t)$
Isnt it quite important to make the distinction though?
There is a critical difference between
$f(x) = x^2$ and $f(x) = sin^{2}(t)$
Thanks
  • #47
Olok said:
This means,
$f(x) = sin^{2}(t)$
where $x = sin(t)$
Writing it like that is considered wrong, since $f(x) = \sin^{2}(t)$ implies that $x$ and $t$ are unrelated.
We could see for instance:
$$y=x^2$$
$$x=\sin(t)$$
$$y=\sin^2(t)$$
This represents some harmonic oscillation on a parabolic trajectory.
Keeping the physical meaning in mind, we can be sure that no mistakes will creep in.
Btw, to distinguish the derivatives, you'll see $y'$ to represent $y'(x)$, and $\dot y$ to represent $\d {} {t}y(x(t))$.
  • #48
I like Serena said:
Writing it like that is considered wrong, since $f(x) = sin^{2}(t)$ implies that $x$ and $t$ are unrelated.
$$y=x^2$$
$$x=\sin(t)$$
$$y=\sin^2(t)$$
Hi,
I suppose this is right, but when you see,
$f(x) = x^3$
You would suspect $x$ is independent.
Its not wrong to write $f(u)$
But my point is that it will help avoid confusion. Thats all ! THANKS!
