ChrisP
- 4
- TL;DR Summary
- Can high current alone damage a device (assuming the device is cooled adequately)?
So, let's assume in a theoretical case we have a (semiconductor but not necessarily) device, e.g. a MOSFET, that is perfectly cooled and has zero heat resistance (infinite thermal conductivity), and that it's connected to a perfect heat sink (theoretical abstractions for now, I will come back to the real world later). Let's say that the MOSFET is switching so it has transient behaviour, it operates in normal region (not sub- or near- threshold) and its gate is charged and discharged at a high frequency by a perfect driver (let's say an ideal inverter). You also have an ideal power supply that can deliver as much current as the circuit asks (with perfect line and load regulation), and the voltage never exceeds the dielectric breakdown threshold.
Now, my question is, can the device be damaged from very high current flowing through the gate driver? Again, not because of overheating, but because of physical limitations in the device? I know that high voltage causes dielectric breakdown, due to a high electric field exceeding the dielectric withstand strength of the material, but is there such a thing for very high currents besides heat? Because the only physical effects I know related to high current besides heating is electromigration which is a relatively slow process and affects mostly long term reliability.
The question is motivated by two thoughts: 1) when you have a real IC and you cool it down with liquid nitrogen, cooling is not really an issue, so the only limiting factor to achieving maximum frequency should only be breakdown voltage right? (I know that there are other limiting factors to speed relating to setup and hold requirements, etc. but I mean from a physics perspective. There is also the case where heat is just not removed fast enough due to the thermal resistance of the junction to package, package to heat sink, etc. and it still ends up blowing your device). 2) in a superconducting system where you don't have any heat being generated, what's limiting you from having billions of amps going through the system (assuming that there is a load that can draw so much current, i.e. it has something to do with all this current, and a source that can provide that)?
