Eye and vision during low intensity
In summary, the conversation discusses a common phenomenon where one can see an object more clearly when looking away from it, known as averted vision. This is due to the difference in sensitivity between cones and rods in the eye. The conversation also touches on the concept of color perception and how it is related to the activation of different types of cones in the eye.
Suraj M
39
This is something that i noticed.i.e., it happen to me, when i went to my teacher to ask him why it happens he actually didn't believe me, i guess maybe because he was a physics teacher!
Consider a room with\ all the lights switched off, let their be a far off light source which is very weak. So you can't actually see anything clearly but you can make out the boundaries of things around you, faintly.
What i observed was that when there was a particular object in front of me, or even if the dim far off light source is
in front of me and i tried to look straight at it i could not see it, but if i moved my line of sight away from the source, i could see it.
Summary, could not see it when i look right at it but could see it in the peripheral part of my vision, t when i looked at something else.
why does that happen?
I thought about this for a few years actually because no one believed me! I hope you guys do!
I actually came up with a lame excuse, it was that, maybe because when i look straight at a thing I'm sensing it mostly by my fovea which is loaded with cones, i just assumed that as there are so many cones there would be lesser rods, hence bringing down my sensitivity at low intensities of light! Is that right?
Also try doing this and see if you observe something similar to what i tried to describe above!
Biology news on Phys.org
This is a well-known phenomenon, and your explanation is correct. See this link for a diagram of the rod and cone density in the eye. Astronomers are well aware of this, and often use a technique called "averted vision", where you look slightly away from the object you are trying to see. This enables you to see fainter objects for the reason you described.
Likes Suraj M
Oh! thanks for the link, if you don't mind me adding another question- I've tried the to do the same with a red coloured source, the link you gave says the fovea has red cones. Now though the light is still dim its also red so do rods react to it or cones?
Only cones detect color, but rods are more sensitive to light in general (which is why they still work in low-light conditions). If you could see red, that means there was enough light to activate your cones. But there are more red cones (not that that necessarily correspond to the perception of red, you'd have to look at the chart*).
"red" cones (64%), "green" cones (32%), and "blue" cones (2%)
you can see the radial spatial distribution here:
http://hyperphysics.phy-astr.gsu.edu/hbase/vision/rodcone.html
* the response curve chart:
http://hyperphysics.phy-astr.gsu.edu/hbase/vision/colcon.html#c1
Pythagorean, if you see the penultimate line in the second link you posted, it says at least 2 types of cones should be triggered for the colour to be sensed, then again how can we see only red?
and also it means that if i reduce the intensity of the red light even more it would turn white? as the cone does not react at that intensity, only rods would
The "color" of the cones isn't directly related to the color you perceive. The color you perceive is an abstraction of the combination of which cones are firing and to what degree.
I don't know what the threshold values are. It's possible that any human light source you use will always have too high of a threshold when it's on and will thus always trigger color perception... but I don't know.
Likes Suraj M
My experience with this has been the following. Go outside (not in the city - someplace dark like in the woods or out in the country) before dawn. You will find that you can see things, but that everything is essentially black and white. As dawn approaches, the overall light intensity increases until eventually you can see things in color. I've found it to be quite sudden - it seems like the colors switch on all at once. However, this may just be my perception. You could probably simulate this in a dark room where you gradually increase the light intensity.
Likes Suraj M
Are you aware of the 'blind spot"? This may or may not be what you experienced, but it's a fun example.
https://visionaryeyecare.wordpress.com/2008/08/04/eye-test-find-your-blind-spot-in-each-eye/
Yes Evo I'm aware of it(done that experiment a lot of times :) ) and its not exactly in the line of sight, If i look straight at an object my fovea would recognize it and also i have 2 eyes, so the blind spot shouldn't matter.
Related to Eye and vision during low intensity
1. How does low intensity light affect the eye and vision?
Low intensity light can cause the pupil to constrict, leading to a smaller opening for light to enter the eye. This can result in a decrease in visual acuity and color perception, as well as an increase in sensitivity to glare.
2. Can prolonged exposure to low intensity light damage the eyes?
While prolonged exposure to bright light can cause damage to the eyes, low intensity light is unlikely to cause any significant damage. However, it is still important to protect your eyes from any potential harm by wearing sunglasses or limiting exposure to bright light for extended periods of time.
3. How does low intensity light affect those with existing eye conditions?
Low intensity light can exacerbate symptoms of pre-existing eye conditions, such as dry eyes, cataracts, and age-related macular degeneration. It is important for individuals with these conditions to consult with their eye doctor and take necessary precautions to protect their eyes from low intensity light.
4. Can low intensity light improve vision in people with nearsightedness or farsightedness?
No, low intensity light does not have the ability to improve vision in those with nearsightedness or farsightedness. These conditions are caused by the shape of the eye and can only be corrected with glasses, contact lenses, or surgery.
5. Are there any benefits to exposure to low intensity light?
Yes, exposure to low intensity light can have some benefits on eye health. It can help regulate the body's circadian rhythm, which is important for a healthy sleep-wake cycle. It can also help improve mood and increase alertness. However, it is important to find a balance and not expose the eyes to too much low intensity light, as it can still cause strain and discomfort.
  • Biology and Medical
