F continuous and {f(x)} = f({x}) implies f(x) or f(x)-x periodic
In summary, the conversation discusses a problem posted on a forum on January 8th, 2013. The problem involves proving that a continuous real function f, where the fractional part of x is equal to the fractional part of f(x), is either periodic or f(x)-x is periodic. The conversation goes on to provide a proof and explanation for this statement, using the continuity of f and a well-known theorem.
Fernando Revilla
MHB
631
I quote an unsolved problem from another forum posted on January 8th, 2013.
I don't know how to solve this problem:
Let f be a continuous real function such that [tex]\{f(x)\} = f(\{x\})[/tex] for each x ([tex]\{x\}[/tex] is the fractional part of number [tex]x[/tex]).
Prove that then [tex]f[/tex] or [tex]f(x)-x[/tex] is a periodic function.
Could you help me?
Consider the function [tex]g:\mathbb{R}\to\mathbb{R}[/tex], [tex]g(x)=f(x+1)-f(x)[/tex]. Clearly, [tex]g[/tex] is continuous. As [tex]\{x+n\}=\{x\}[/tex] for all integer [tex]n[/tex]:
[tex]\{f(x+1)\}=\{f(x)\}=f(\{x\})=\{f(x)\}[/tex]
As [tex]\{f(x+1)\}=\{f(x)\}[/tex], [tex]f(x+1)-f(x)[/tex] must be integer. Being [tex]\mathbb{R}[/tex] connected, there exists [tex]m\in \mathbb{Z}[/tex] such that [tex]f(x+1)-f(x)=m[/tex] for all [tex] x\in \mathbb R[/tex] (Why?). This implies that [tex]h(x)=f(x)-mx[/tex] is periodic (Why?).
If we prove that [tex]m=0[/tex] or [tex]m=1[/tex] then, [tex]h(x)=f(x)[/tex] is periodic or [tex]h(x)=f(x)-x[/tex] is periodic. We have
[tex]f(0)=f(\{0\})=\{f(0)\}\in[0,1)[/tex]
But [tex]f(1)=f(0)+m\in[m,m+1)[/tex]. On the other hand, if [tex]x\in[0,1)[/tex] we have [tex]f(x)=f(\{x\})=\{f(x)\}\in[0,1)[/tex]. Using the continuity of [tex]f[/tex]:
[tex]f(1)=\lim_{x\to 1^-}f(x)\in[0,1][/tex]
That is, [tex]f(1)\in [m,m+1)\cap [0,1][/tex]. This intersecion is not empty if and only [tex]m=0[/tex] or [tex]m=1[/tex]
Hi Fernando,
I saw this problem earlier and puzzled over it for some time. My only progress was proof that f is periodic if f(1)<1.
I'm probably just dense, but I don't see why there is an integer m such that for all x, f(x+1)-f(x) =m.
(For a given x, f(x+1)-f(x)=floor(f(x+1))-floor(f(x)), certainly an integer. By why is there one integer for any x?)
Well, according to a well-known theorem, a real continuous function on a connected set asumes as a value each number between any two of its values.
In our case, $g(x)=f(x+1)-f(x)$ is continuous and $\mathbb{R}$ is connected. If $g(x_1)=m$ and $g(x_2)=n$ with $m,n$ distinct integers, $g$ would assume non integers values between $m$ and $n$. Contradiction.
Thanks Rinaldo. I was just being dense. Good proof.
FAQ: F continuous and {f(x)} = f({x}) implies f(x) or f(x)-x periodic
1. What is the definition of "F continuous"?
The term "F continuous" refers to a function that is continuous in the interval from negative infinity to positive infinity. This means that the function has no sudden jumps or breaks in its graph and can be drawn without lifting the pencil from the paper.
2. What does it mean for a function to be periodic?
A periodic function is one that repeats itself at regular intervals. This means that the function will have the same output values for certain input values, and this pattern will continue indefinitely. In other words, the function will have a specific period or cycle that it repeats.
3. What is the relationship between "f(x)" and "f({x})" in the context of periodicity?
The notation "f({x})" means that the function is evaluated at the value {x}. In the context of periodicity, this means that the function is evaluated at a specific value in the interval of its period. This notation is often used to show that a function is periodic, as it implies that the function will have the same output for that particular value of {x}.
4. How does {f(x)} = f({x}) imply that a function is either periodic or has a period of 1?
When {f(x)} = f({x}), this means that the function is equal to itself evaluated at some value of {x}. In other words, the function has a period of 1, as it repeats itself after every 1 unit. Alternatively, if a function is periodic, this equation also holds true because the function's output will be the same for the same input value, regardless of its location in the interval.
5. Can a function be both continuous and periodic?
Yes, a function can be both continuous and periodic. This means that the function has no sudden jumps or breaks in its graph, and it also repeats itself at regular intervals. A common example of a continuous and periodic function is the sine function, which repeats itself every 2π units and has no sudden jumps or breaks in its graph.
