F(g(x)) problem, about the domain.
  • Thread starter AznBoi
  • Tags
    Domain
In summary, the conversation discusses the problem of finding the domain of f(g(x)), where f(x) and g(x) are given functions. The simplified answer is 2-x, but since there is a square root involved, the domain is restricted to (-infinity,2] to avoid taking the square root of a negative number. This is similar to the example of simplifying a function where the value of x cannot be -2.
AznBoi
471
Ok, f(x)=x^2 g(x)=sq.rt.(2-x)
Problem: f(g(x))
You end up with the answer 2-x but how come you need a domain for the answer? How come the domain is (-infinity,2]?
Because while your answer simplifies to 2-x, you have to remember that there's a sqrt(2-x) in there... you can't take the square root of a negative number.
Here's an example: [tex]f(x)=\frac{x^2+3x+2}{x+2} = \frac{(x+2)(x+1)}{x+2}[/tex]
While it's obvious that the expression simplifies, you have to remember that you can't divide by zero. Thus, the value of -2 for x is not allowed in the original function. If you simplify the function, it becomes x+1, x doesn't equal 2.
I would like to clarify that the domain is a set of all possible input values for a function. In this case, the function f(g(x)) is composed of two functions, f(x) and g(x). The domain of f(x) is all real numbers, while the domain of g(x) is restricted to values where the expression inside the square root (2-x) is greater than or equal to 0. This is because the square root function is only defined for non-negative values. Therefore, the domain of g(x) is (-infinity, 2] as any value greater than 2 would result in a negative value inside the square root, which is not allowed.
When we substitute g(x) into f(x), we are essentially plugging in values from the domain of g(x) into the function f(x). Since the domain of g(x) is restricted to (-infinity, 2], the resulting domain for f(g(x)) would also be restricted to (-infinity, 2].
In summary, the domain of a composite function like f(g(x)) is determined by the individual domains of the component functions. In this case, the domain of f(g(x)) is restricted to (-infinity, 2] due to the domain restrictions of g(x).
FAQ: F(g(x)) problem, about the domain.
What is the F(g(x)) problem?
The F(g(x)) problem, also known as the composition of functions, is a mathematical concept where two functions are combined to create a new function. In this case, the function g(x) is input into the function F, resulting in F(g(x)).
What is the domain of a function?
The domain of a function is the set of all possible input values for that function. It is the set of numbers or values that can be plugged into the function and produce a meaningful output.
How do you find the domain of F(g(x))?
To find the domain of F(g(x)), you need to first determine the domain of g(x). Then, you need to look at the values that g(x) produces and make sure they are all valid inputs for the function F. Any value that is not a valid input for F should be excluded from the domain of F(g(x)).
Can the domain of F(g(x)) be larger than the domain of g(x)?
Yes, the domain of F(g(x)) can be larger than the domain of g(x). This can happen if the function F can take in more input values than g(x) can produce, or if F can take in some values that g(x) cannot produce.
What happens if the domain of F(g(x)) is smaller than the domain of g(x)?
If the domain of F(g(x)) is smaller than the domain of g(x), it means that there are some values that g(x) can produce but F cannot take as input. In this case, the composition of F(g(x)) may not be defined for those specific values, and the domain of F(g(x)) would need to be adjusted accordingly.
