F = ma Exam 2011 # 12 (Gravitational Attraction of Rods and Balls)
In summary, the compressive force in each rod when three balls and three rods are placed at the vertexes and edges of an equilateral triangle is F, as the total force is the sum of two equal forces of magnitude F pointing along each rod.
SignaturePF
112
12. You are given a large collection of identical heavy balls and lightweight rods. When two balls are placed at the ends
of one rod and interact through their mutual gravitational attraction (as is shown on the left), the compressive
force in the rod is F. Next, three balls and three rods are placed at the vertexes and edges of an equilateral triangle
(as is shown on the right). What is the compressive force in each rod in the latter case?
(A) √1/3F
(B)√3 / 2 F
(C) F
(D)√3F
(E) 2F
The correct answer is C
F_g = GmM / r^2
Why is the force still F?
Is it because the only force that the rod has to equal in magnitude is the gravitational acceleration between two balls at a time?
Take a look at the top ball on the triangle - what is the total force on it?
What proportion of that force goes along each rod?
The top ball has Force Gm^2 / R^2 (where R is length of triangle) on the left
same on the right. We'll call this force F, as done in the problem.
However, when these two forces are added the x components of each cancel out, leaving the net force as:
F_net = 2Fsin60
F_net = root(3)F
so each rod will face root(3)/2F, where did I go wrong?
You did the proportions back to front.
Draw the vectors on the diagram.
I don't follow what you mean. When I draw the vectors on the diagram I get the same result.
Surely you get a vector of magnitude F pointing along one rod and another vector of magnitude F pointing along the other rod - the total force being the sum of these vectors?
Related to F = ma Exam 2011 # 12 (Gravitational Attraction of Rods and Balls)
1. What is the formula for F = ma?
The formula for F = ma is known as Newton's Second Law of Motion, which states that the force (F) acting on an object is equal to its mass (m) multiplied by its acceleration (a).
2. How does F = ma relate to the gravitational attraction of rods and balls?
F = ma can be used to calculate the gravitational attraction between objects, such as rods and balls. The force (F) in this case is the gravitational force, the mass (m) is the combined mass of the two objects, and the acceleration (a) is the acceleration due to gravity (9.8 m/s²).
3. What is the significance of the 2011 #12 exam question on the gravitational attraction of rods and balls?
The 2011 #12 exam question on the gravitational attraction of rods and balls is a hypothetical scenario that tests students' understanding of Newton's Second Law and its application to real-life situations involving gravitational forces.
4. Can F = ma be used to calculate the gravitational attraction between any objects?
Yes, F = ma can be used to calculate the gravitational attraction between any objects, as long as their masses and the acceleration due to gravity are known.
5. How can I use F = ma to solve the 2011 #12 exam question on the gravitational attraction of rods and balls?
To solve the 2011 #12 exam question, you can use the formula F = ma and plug in the given values for mass and acceleration due to gravity. This will give you the gravitational force between the rods and balls, which you can then compare to the required force stated in the question.
