F(t) as it relates to v(t) and x(t)
  • Thread starter Tonyt88
In summary, the conversation discusses solving for the velocity and position of an object subject to a force, with given initial velocity and position. The solution involves integrating the function cos(ωt) and using initial conditions to determine the constant value.
Tonyt88
62
Starting at t = 0, an object of mass m is subject to a force
F(t) = F nought cos omega t
If the initial speed and position are v nought and x nought, find v(t) and x(t), any help would be greatly appreciated.
Well, now you got to solve
[tex]\frac{dv}{dt}=\frac{F_0}{m}\cos(\omega t)[/tex]
That's easy. What is the function whose derivative is cos?
Okay, so this is how it worked out for me:
dv = (F0/m) cos(ωt) dt
v = (F0/mω) sin(ωt) + C
v(t) = (F0/mω) sin(ωt) + v0
dx =[ (F0/mω) sin(ωt) + v0 ] dt
x = -(F0/mω2) cos(ωt) + v0t + x0
x(t) = -(F0/mω2) cos(ωt) + v0t + x0
Does that make sense?
You went a little too fast. After integrating
you get
x = -(F0/mω²) cos(ωt) + v0t + C
But plugging x(0)= x_0 does not give C=x_0 because cos(0)=1.
Oh, oops, so then C = x_0 + (F_0/mω²) ?
FAQ: F(t) as it relates to v(t) and x(t)
What is F(t)?
F(t) is the symbol used to represent the force applied to an object at a specific time, t. It is a vector quantity, meaning it has both magnitude and direction.
How does F(t) relate to v(t) and x(t)?
F(t) is directly related to both v(t) and x(t) through Newton's second law of motion, which states that the net force on an object is equal to its mass multiplied by its acceleration. In other words, F(t) = m * a = m * (dv/dt) = m * (d^2x/dt^2). This means that the force applied at a given time affects both the velocity and position of an object.
Can F(t) be negative?
Yes, F(t) can be negative. This simply means that the force is acting in the opposite direction of the chosen positive direction. For example, if a force of -5 N is applied to an object in the positive x-direction, it means that the force is acting in the negative x-direction.
What are the units of F(t)?
The SI unit for force is Newtons (N). However, it can also be expressed in other units such as pounds (lb) or dynes (dyn) depending on the system of measurement being used.
How is F(t) measured?
F(t) can be measured using various instruments, such as a spring scale, force gauge, or dynamometer. These instruments can measure the amount of force being applied to an object in different units, and the value can be recorded at a specific time to determine F(t).
