f(x) = 2x+1, proving that it is continuous when p = 1 with 𝛿 and ε
In summary, the function f(x) = 2x + 1 can be proven to be continuous at the point p = 1 by using the definitions of ε (epsilon) and δ (delta). To demonstrate continuity, we need to show that for every ε > 0, there exists a δ > 0 such that if |x - 1| < δ, then |f(x) - f(1)| < ε. By substituting f(1) = 3 and analyzing the expression |(2x + 1) - 3|, we can simplify it to |2x - 2|, which is equal to 2|x - 1|. Setting δ = ε/2 ensures
thethagent
TL;DR Summary: Continuity of a function, Calculus newbie, delta, epsilon,
Greetings! I have just started studying Calculus for my engineering course, and I am already facing some problems to understand the fundamental ideas regarding the continuity of a function. I'd be very much grateful if you guys spared a minute or two to help me with this question:
f(x) = 2x+1, p = 1, prove with delta and epsilon notation that it is continuous for p
How I'd start it
1 - 𝛿 < x < 1 + 𝛿 => 3 - ε < f(x) < 3+ ε
No problems so far. I'd change f(x) for its function and then I'd have a inequality for x on both sides
1 - 𝛿 < x < 1 + 𝛿 => 1 - ε/2 < x < 1 + ε/2
From this point I'm starting to have some problems. The author of the book assumes that 1 - 𝛿 = 1 - ε/2 and 1 + 𝛿 = 1 + ε/2, but I cannot fathom why it is true. For instance, I could say that x = 3, then
0 < 3 < 6 and 2 < 3 < 9
My point with it is: x shouldn't necessarily be limited by the same two things, which is why 1 - 𝛿 = 1 - ε/2 and 1 + 𝛿 = 1 + ε/2 isn't necessarily true. Yet, the book states it, so I must be missing something here. Can you help me with it?
I appreciate anyone who has read so far; thank you so much!
I can't really follow what you are trying to do.
In general, an epsilon-delta proof is of the form:
Let ##\epsilon > 0##. Choose ##\delta =## some function of ##\epsilon## (making sure that ##\delta > 0##). Then show that:
$$|x - p| < \delta \implies |f(x) - f(p)| < \epsilon$$In this case,given that ##f## is a linear function, it should be clear that it's sufficient to choose ##\delta = \dfrac \epsilon 2##.
I would redo your proof using this standard approach.
PS I don't want to give you too much help, but note that:
$$|f(x)- f(p)| = |(2x +1) - (2p +1)| = |2x - 2p| = 2|x - p|$$This is the way you should think about it.
Likes FactChecker
A "word-smithing" note on your statement of the problem:
It wasn't until I saw @PeroK 's answer that I realized what p had to do with the problem. A more clear statement of the problem would be:
Show that f(x)=2x+1 is continuous at the point x=1.
My first question was "what is [itex]p[/itex]?"
In fact what you are trying to do is show that [itex]f(x) = 2x + 1[/itex] is continuous at [itex]x = 1[/itex].
And it is a very poor example where almost nothing can be learned from. It invites to confuse the roles of ##\varepsilon ## and ##\delta ,## and the dependence of the location ##x=1## doesn't occur.
@thethagent, if you want to learn something, then prove that ##f(x)=\begin{cases}\dfrac{1}{x}&\text{ for }x\neq 0\\0 &\text{ for }x=0\end{cases} \quad ## is continuous at ##x=0.2## and discontinuous at ##x=0.##
The technique of the proof is: given an arbitrarily small ##\epsilon \gt 0##, define ##\delta \gt 0## such that ##|x-1|\lt\delta## forces ##|f(x)=f(1)|\lt\epsilon##.
Suppose we have an arbitrarily small ##\epsilon\gt 0##. Can we define a ##\delta## that will work? The author is proposing that if ##\delta## is defined so that ##1-\delta=1-\epsilon/2## it will work. He is correct. From that definition, ##\delta=\epsilon/2##. Suppose that ##|x-1|\lt\delta=\epsilon/2##. Can you continue the proof from there?
FAQ: f(x) = 2x+1, proving that it is continuous when p = 1 with 𝛿 and ε
What does it mean for a function to be continuous at a point?
A function is continuous at a point \( p \) if the following three conditions are met: the function \( f(p) \) is defined, the limit of \( f(x) \) as \( x \) approaches \( p \) exists, and the limit equals the function's value at that point, i.e., \( \lim_{x \to p} f(x) = f(p) \).
How do we apply the \( \epsilon \)-\( \delta \) definition of continuity to the function \( f(x) = 2x + 1 \) at \( p = 1 \)?
To show that \( f(x) = 2x + 1 \) is continuous at \( p = 1 \) using the \( \epsilon \)-\( \delta \) definition, we need to demonstrate that for every \( \epsilon > 0 \), there exists a \( \delta > 0 \) such that if \( |x - 1| < \delta \), then \( |f(x) - f(1)| < \epsilon \). We compute \( f(1) = 3 \). Thus, we need \( |2x + 1 - 3| < \epsilon \), which simplifies to \( |2x - 2| < \epsilon \) or \( 2|x - 1| < \epsilon \). Therefore, if we let \( \delta = \frac{\epsilon}{2} \), we can satisfy the condition.
What is the value of \( f(1) \) for the function \( f(x) = 2x + 1 \)?
The value of \( f(1) \) is calculated by substituting \( x = 1 \) into the function: \( f(1) = 2(1) + 1 = 3 \).
What is the limit of \( f(x) \) as \( x \) approaches 1?
The limit of \( f(x) = 2x + 1 \) as \( x \) approaches 1 can be found by direct substitution: \( \lim_{x \to 1} f(x) = 2(1) + 1 = 3 \). Therefore, the limit exists and equals \( f(1) \).
Why is it important to prove that a function is continuous at a point?
Proving that a function is continuous at a point is essential because continuity ensures that small changes in the input result in small changes in the output. This property is crucial in calculus, particularly in the application of the Intermediate Value Theorem,
