F(x) coincides with its inverse function
In summary, the necessary and sufficient conditions for $\displaystyle f(x)$ to coincide with its inverse function are either $\displaystyle a+d=0$ or $\displaystyle b=c=0$ and $\displaystyle a=d$.
alexmahone
304
Suppose that $\displaystyle f(x)=\frac{ax+b}{cx+d}$. What conditions on $\displaystyle a,\ b,\ c,\ d$ are necessary and sufficient in order that $\displaystyle f(x)$ coincide with its inverse function.
My attempt:
$\displaystyle f(f(x))=\frac{a\left(\frac{ax+b}{cx+d}\right)+b}{c\left(\frac{ax+b}{cx+d}\right)+d}=\frac{a(ax+b)+b(cx+d)}{c(ax+b)+d(cx+d)}=\frac{(a^2+bc)x+ab+bd}{(ac+cd)x+bc+d^2}$
$\displaystyle f(x)=f^{-1}(x)$
$\displaystyle \implies f(f(x))=x$
$\displaystyle \implies\frac{(a^2+bc)x+ab+bd}{(ac+cd)x+bc+d^2}=x$
$\displaystyle \implies(a^2+bc)x+ab+bd=(ac+cd)x^2+(bc+d^2)x$
$\displaystyle \implies c(a+d)x^2+(d^2-a^2)x-b(a+d)=0$
$\displaystyle \implies (a+d)[cx^2+(d-a)x-b]=0$
$\displaystyle a+d=0$ or $\displaystyle b=c=0$, $\displaystyle a=d$
Is that correct?
My attempt:
Is that correct? <--- yes
I've compared the co-efficients at:
$ \displaystyle f(x)=\frac{ax+b}{cx+d}$ ... and... $\displaystyle f^{-1}(x)=\frac{-dx+b}{cx-a} $
which yields your results.
FAQ: F(x) coincides with its inverse function
What does it mean for F(x) to coincide with its inverse function?
When F(x) coincides with its inverse function, it means that the output of F(x) is equal to its input when plugged into the inverse function. In other words, applying the inverse function to the output of F(x) will result in the original input value.
How can you tell if F(x) coincides with its inverse function?
To determine if F(x) coincides with its inverse function, you can graph both functions and see if they are reflections of each other across the line y=x. Another way is to plug in the output of F(x) into the inverse function and see if it returns the original input.
What does it mean if F(x) does not coincide with its inverse function?
If F(x) does not coincide with its inverse function, it means that the output of F(x) does not equal its input when plugged into the inverse function. This can happen when the function is not one-to-one, meaning multiple inputs can result in the same output.
Can a function coincide with its inverse function if it is not one-to-one?
No, a function cannot coincide with its inverse function if it is not one-to-one. This is because a one-to-one function has a unique inverse, while a non-one-to-one function has multiple inputs that result in the same output, making it impossible for the inverse function to map back to the original input.
What are some real-world examples of functions that coincide with their inverse functions?
Some examples of functions that coincide with their inverse functions include logarithmic functions, exponential functions, and trigonometric functions such as cosine and secant. These functions have unique inverses and can be used to model various real-world phenomena.
