F(x)=(x+1)^0.5, h(x)=x^2+3, what is the range of f(h(x))?
  • Thread starter Thread starter Darkmisc
    Range
The discussion centers on determining the range of the composite function f(h(x)), where f(x) = (x+1)^0.5 and h(x) = x^2 + 3. Participants agree that the range of h(x) is [3, ∞), but there is confusion regarding the domain of f(h(x)). It is clarified that f(h(x)) is defined for all real numbers, not just for values starting from 3. The correct range of f(h(x)) is determined to be [2, ∞), as the lower bound is derived from evaluating f at the minimum value of h(x). Understanding the relationship between the range of h(x) and the domain of f(x) is crucial for solving the problem correctly.
Darkmisc
f(x)=(x+1)^0.5, h(x)=x^2+3, what is the range of f(h(x))?
Hi everyone
I have solutions to this problem, but still don't understand them.
I thought the range of h(x) was [3, \infty). Wouldn't this make the domain of f(h(x)) also [3, infinity)?
If this is correct, shouldn't the range of f(h(x)) be [13^0.5, infinity)?
Below is a graph of f(h(x)) using the assumption that the range of h(x) is [3, infinity)
The solutions say
But the domain of f(h(x)) would need to include 0 for this to be true.
Thanks
Darkmisc said:
Homework Statement:: f(x)=(x+1)^0.5, h(x)=x^2+3, what is the range of f(h(x))?
Relevant Equations:: f(x)=(x+1)^0.5, h(x)=x^2+3
Hi everyone
The solutions say View attachment 316489
View attachment 316490Thanks
What is the range of h(x)? How does this compare with the domain of f(x)?
-Dan
-Dan
Thanks.
range of h(x) is [3, infinity).
If I take [3, infinity) as the domain of f(x), the range becomes [2, infinity), which is the answer from the solutions.
I got the wrong answer by using [3, infinity) as the domain of f(h(x)), although I don't really understand why it is wrong.
That's right, because ##[2, \infty)## is the range of ##h##.
It's wrong, because ##f(h(x))## is well-defined for all ##x \in \mathbb R##. Just write it down:
$$f(h(x)) = \sqrt{x^2 + 4}$$If I gave that function to a student and asked what was its domain, they wouldn't say ##[3, \infty)##. Why would they?
Likes topsquark and Darkmisc
You already took care of h(x) when you figured out that its range was ##[3,\infty)##. Now you want the range of f(z), NOT f(h(x)), for z in the domain of ##[3,\infty)##. Plugging 3 into f should give you 2.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
