F(x)=x+(5/x), how do i find f^-1(x)?
  • Thread starter Champdx
In summary, the function f(x) is defined as x + (5/x) and can be graphed by plotting points or using a graphing calculator. f^-1(x) is the inverse function of f(x) and can be found by swapping the input and output values and solving the equation. The domain and range of f(x) are all real numbers except 0.
Champdx
f(x)=x+(5/x), how do i find f^-1(x)?
Let me help you to recall what are the steps you have to do.
let f(x) be y , change the y with x , and now express the equation with the subject y . Finally change the y to f^{-1}(x)
FAQ: F(x)=x+(5/x), how do i find f^-1(x)?
What is the function f(x)?
The function f(x) is defined as x + (5/x). This means that for any given input value of x, the output of the function will be x added to the result of 5 divided by x.
How is f(x) graphed?
To graph the function f(x), you can plot points by selecting different values for x and calculating the corresponding output values using the function formula. You can also use a graphing calculator or online graphing tool to plot the function.
What is f^-1(x)?
f^-1(x) is the inverse function of f(x). It is a function that undoes the original function f(x) by swapping the input and output values. In other words, the input of f^-1(x) will be the output of f(x) and vice versa.
How do I find f^-1(x)?
To find the inverse function f^-1(x), you can follow these steps:
1. Replace f(x) with y.
2. Switch the x and y variables in the equation, making it x = y + (5/y).
3. Solve the equation for y using algebraic manipulation.
4. Replace y with f^-1(x) to get the final inverse function.
What is the domain and range of f(x)?
The domain of f(x) is all real numbers except 0, as division by 0 is undefined. The range of f(x) is also all real numbers except 0, as the output of the function will never be 0 for any non-zero input value of x.
