(f_n) converges pointwise to a continuous f
  • MHB
  • Thread starter evinda
  • Tags
    Continuous
In summary, the conversation discusses the pointwise convergence of a sequence of functions, $f_n(x)$, defined as $0$ for $x< \frac{1}{n+1}$ or $x>\frac{1}{n}$ and $\sin^2(\frac{\pi}{x})$ for $\frac{1}{n+1} \leq x \leq \frac{1}{n}$. It is proven that $f_n$ converges pointwise to $f=0$ in $\mathbb{R}$, but does not converge uniformly. This is because for any given $x \in (0,1)$, we can pick an $N$ such that $x$ is not
evinda
MHB
3,836
Hey again! (Blush)
I am looking at the following exercise:
Let $$f_n(x)= \begin{cases}
0,x< \frac{1}{n+1} \text{ or } \frac{1}{n}<x \\
\sin^2( \frac{ \pi}{x}), \frac{1}{n+1} \leq x \leq \frac{1}{n}
\end{cases}.$$
Prove that $(f_n)$ converges pointwise to a continuous $f$ in $ \mathbb{R}$.
Which is this $f$ ? Does $f_n \to f$ uniformly in $\mathbb{R}$ ?
Can I show that $(f_n)$ converges pointwise to $f=0$ like that?
$ \displaystyle \forall x<\frac{1}{n+1}$ or $x>\dfrac{1}{n}$: $f_n(x)=0 \to 0$
$ \displaystyle \forall \frac{1}{n+1} \leq x \leq \frac{1}{n} \Rightarrow n \leq \frac{1}{x} \leq n+1 \Rightarrow \pi n \leq \frac{\pi}{x} \leq \pi(n+1) \Rightarrow $
$ \displaystyle \sin^2( \pi n) \leq \sin^2 ( \frac{ \pi}{x}) \leq \sin^2( \pi(n+1)) \Rightarrow$
$\displaystyle \lim_{n \to + \infty} \sin^2( \pi n) \leq \lim_{n \to +\infty} \sin^2 ( \frac{ \pi}{x}) \leq \lim_{n \to +\infty} \sin^2( \pi(n+1)) \Rightarrow 0 \leq f \leq 0 \Rightarrow f=0$ :confused:
Let $x$ be any real number. We wish to show that for any $\epsilon > 0$, there is some $N \in \Bbb N$ such that for all $n > N$:
$|f_n(x)| < \epsilon$.
If $x > 1$, we can choose $N = 1$, and similarly for $x \leq 0$. If $x = 1$, we can pick $N = 2$.
So we just need to focus on $0 < x < 1$.
Choose $N = \lfloor \frac{1}{x} \rfloor + 1$. This tells us that:
$\dfrac{1}{x} < N$ so that for $n > N$:
$\dfrac{1}{n} < \dfrac{1}{N} < x$
in which case we have $f_n(x) = 0$ for all $n > N$.
Note that our choice of $N$ depends on $x$.
Can we pick SOME $N$ that will work for EVERY $x \in (0,1)$?
Suppose we could.
Suppose we have some $n > N$, and consider $x = \dfrac{2}{2n+1}$.
For such $x$, we have $f_n(x) = \sin^2(\frac{\pi}{x}) = \sin^2(\frac{(2n+1)\pi}{2})$
$= \sin^2(\pm \frac{\pi}{2}) = (\pm 1)^2 = 1$, so if:
$1 > \epsilon > 0$, we have, for this $x$:
$|f_n(x)| = 1 > \epsilon$, contradicting our choice of $N$.
So $f_n$ does not converge uniformly.
Suppose we could.
Could you explain me further how you concluded that $f_n$ converges pointwise to $0$,when $ \frac{1}{n+1} \leq x \leq \frac{1}{n} $ ? (Blush)
Put somewhat broadly, the $n$'s we need to look at depend on our $x$.
As $n$ increases, the $x$'s that are in the interval $\left(\dfrac{1}{n+1},\dfrac{1}{n}\right)$ keep getting closer to 0.
So for any $x$, we just need to pick an $N$ big enough so that $x$ is to the right of all those intervals for $n > N$.
Of course, as $x$ gets really close to 0, we keep having to pick enormous $N$'s, and no single $N$ will work for ALL $x$.
If it weren't for the fact that $f_n(0) = 0$ for all $n$, we WOULD have a problem at 0, because we get an "infinitely small area with infinitely fast oscillation" for $f_n$ as $n \to \infty$.
In essence, we "sweep the problem under the rug" by pushing the "problem area" to the left. Since the real numbers are "infinitely deep", we never run out of room, even though we keep having to squeeze the "bad part" in-between $x$ and 0.
The point being, for any given $x$ (at that "point"), we can arrange it so that $x$ is NOT IN the interval you speak of. So the situation you mention does not occur.
So,you mean that, as $\frac{1}{n+1} \leq x \leq \frac{1}{n}$, $x \to 0$ ?
Why do we know that $f_n(0)=0$ ? (Wondering)
No matter how big we pick $n$, we still have:
$0 < \dfrac{1}{n+1}$, so from the definition of $f_n$, we have $f_n(0) = 0$, for ALL $n$.
That's one of the things about natural numbers: no matter how huge they are, every one of them is still finite.
You see to be missing a fundamental point: to show $f_n$ converges at the point $x$, we first FIX $x$. THEN we look for "big enough $n$". We don't "move $x$" along with the $n$'s: the point $x$ stays put.
All we need for "pointwise convergence" is for $f_n$ to "settle down" LOCALLY, which in this case it DOES: eventually, for every $x > 0$, there is a (perhaps very small) neighborhood (interval) around $x$ so that $f_n$ is CONSTANT on that tiny interval, for all $n > N$ (and the $N$ we pick depends on an essentially way on the point $x$).
For "uniform convergence" we need the $f_n$ to settle down "everywhere all at once" to some function, in other words the rate of convergence is "uniform", whereas for pointwise convergence the rate of convergence can vary (in this case, the closer to 0 we get, the slower the convergence gets, and it takes MANY $n$'s for it to converge within a small $\epsilon$ if $x$ is very close to 0).
You can look at it this way:
For $f_1$ everything to the right of 1 is 0.
For $f_2$ everything to the right of 1/2 is 0.
For $f_3$ everything to the right of 1/3 is 0.
For $f_4$ everything to the right of 1/4 is 0.
For $f_n$ everything to the right of 1/n is 0.
So if $x > 0$, surely we can pick $N$ SO BIG, that $x > \dfrac{1}{N}$. This gives us some "wiggle room" (namely, if we set:
$d = x - \dfrac{1}{N}$ then on the entire interval $(x-d,x+d)$ we have $f_n = 0$ for all $n > N$).
We aren't concerned with $f_n(x)$ FOR ALL $x$, we're just interested in $f_n(x)$ at the PARTICULAR $x$ we are trying to prove pointwise convergence at.
The entire point of this problem is to SHOW you that pointwise convergence isn't really the "best" kind of convergence, that sequences of functions that converge pointwise can behave in unexpected ways:
In this case, the range of EVERY $f_n$ is [-1,1], but the range of the function they converge to pointwise is just {0}.
There are other "bad" sequences like this: one can construct a sequence like:
$f_n(x) = \dfrac{1}{x},\ 0 < x < \dfrac{1}{n}$
$f_n(x) = 0$, otherwise.
This likewise converges pointwise to the 0 function, but none of the $f_n$ are continuous, or even bounded.
FAQ: (f_n) converges pointwise to a continuous f
1. What does it mean for a sequence (fn) to converge pointwise to a continuous function f?
Convergence pointwise means that for each point x in the domain, the sequence (fn(x)) approaches f(x) as n approaches infinity. In other words, as n gets larger and larger, the values of (fn(x)) get closer and closer to the value of f(x).
2. Can a sequence converge pointwise to a discontinuous function?
Yes, it is possible for a sequence (fn) to converge pointwise to a discontinuous function. This means that at each point x in the domain, the values of (fn(x)) get closer and closer to the value of f(x), but f(x) may still have discontinuities or jumps at certain points.
3. Is pointwise convergence the same as uniform convergence?
No, pointwise convergence and uniform convergence are not the same. Pointwise convergence only considers the convergence of the function values at individual points, while uniform convergence takes into account the behavior of the entire sequence (fn) as a whole.
4. How does pointwise convergence relate to the convergence of the derivatives of (fn)?
If a sequence (fn) converges pointwise to a function f, then the derivatives of (fn) will also converge pointwise to the derivative of f. However, the converse is not necessarily true. A sequence of functions (fn) can converge pointwise to a function f, but the derivatives of (fn) may not converge to the derivative of f.
5. What are some applications of pointwise convergence in real-world situations?
Pointwise convergence is used in various fields of mathematics and science, such as in the study of Fourier series, differential equations, and numerical analysis. It is also a key concept in the analysis of functions and their behavior, which has practical applications in fields such as engineering, physics, and economics.
