Fabry-Perot interferometer diffraction
In summary, Math Jeans and the other posters discuss the concept of constructive interference in a Fabry-Perot interferometer. They explain how the distance between the two mirrors and the angle of incidence of the light affect the maximum intensity of the transmitted light. They also provide a diagram and elaborate on the relevant distances and angles involved in the problem.
Math Jeans
349
A Fabry-Perot interferometer consists of two parallel half-silvered mirrors separated by a small distance a. Show that when light is incident on the interferometer with an angle of incidence [tex]\theta[/tex], the transmitted light will have maximum intensity when [tex]a = (\frac{m \cdot \lambda}{2})cos(\theta) [/tex]
[tex]d \cdot sin(\theta) = m \cdot \lambda[/tex]
I tried relating the distance a with d by creating a right triangle from the reflected rays.
That method didn't work, and my answer was the same as the one that I was trying to prove, but divided by (sin([tex]\theta[/tex]))^2. I need a new way to do this.
Hi Math Jeans,
The equation [itex]d \sin\theta=m\lambda[/itex] is a derived equation that applies to specific cases (e.g., two slit interference experiment).
The more fundamental relationship is:
[tex]
\mbox{(path length difference of two rays)}=m\lambda
[/tex]
gives constructive interference. (Assuming coherent light that starts out in phase, and assuming that the path length difference effect is the only interference effect).
So when light strikes one of the mirrors inside the interferometer, some passes through the mirror and some is reflected. The maximum will occur when the extra distance that the reflected light has to travel before reaching that same mirror is equal to [itex]m\lambda[/itex].
What does using the right triangles indicate that the extra distance is? Once you have that you can find the given answer. What do you get?
The reason that I used dsin(theta) as my phase difference, is because the light entering the interfermometer exits in such a way that there is a distance between the exiting rays that when applied to dsin(theta) will still exibit the same phase difference. It should be working, but it doesn't seem to be.
http://hyperphysics.phy-astr.gsu.edu/Hbase/phyopt/fabry.html"
That link has info the the interfermometer, and a diagram (the second one down the page) that shows light entering and exiting it. What I was doing in my calculations was equating the distance between the exiting rays to d, and using the rays bouncing back in forth to form my right triangle. The dsin(theta) relation should work for this.
Math Jeans,
I think you might be focusing on the wrong distance in this problem. When we have a diffraction grating or a two slit source the light rays are in phase (at least when we use [itex]d\sin\theta[/itex]). If that is the case, the important distance would be the distance between exit points along the mirror. But here, the phase of the light rays at the exit points are not automatically in phase; the point is we have to choose how the separation a and angle theta are related to make them be in phase when the rays leave the mirror.
So this Fabry-Perot problem is somewhat more like a thin-film type of problem than like a two-source interference problem.
When part of the light ray exits the mirror, the part that remains has to reflect back to the other mirror, then reflect again. The distance the light travels between mirrors is [itex]d=a/\cos\theta[/itex], and the light travels twice this distance between adjacent exit points.
I've created a quick picture at:
http://img215.imageshack.us/my.php?image=fpjl4.jpg
The extra distance that one light ray has to travel more than the one that previously exited is the distance in color. (The color was red, but seemed to change after uploading.)
If I misunderstood your post please let me know.
Ohhhh. I think that I understand now. I was focusing only on the distance between the exit points as the phase difference of the light, when I should have been focusing on the distance that the light traveled between exit points.
I appreciate your help.
Related to Fabry-Perot interferometer diffraction
1. What is a Fabry-Perot interferometer diffraction?
A Fabry-Perot interferometer diffraction is an optical instrument that uses multiple reflections of light between two parallel mirrors to create an interference pattern. This interference pattern can be used to measure the wavelength of light and the refractive index of a material.
2. How does a Fabry-Perot interferometer diffraction work?
The Fabry-Perot interferometer diffraction works by directing a beam of light onto a partially reflective surface, which then reflects the light back and forth between two parallel mirrors. This creates an interference pattern, which is then analyzed to determine the properties of the light source.
3. What are the applications of a Fabry-Perot interferometer diffraction?
A Fabry-Perot interferometer diffraction has many important applications in optics and spectroscopy. It is commonly used in the measurement of wavelengths of light, as well as in the study of the properties of materials such as refractive index, thickness, and absorption coefficients.
4. What are the advantages of using a Fabry-Perot interferometer diffraction?
One of the main advantages of a Fabry-Perot interferometer diffraction is its high sensitivity and accuracy in measuring the properties of light and materials. It is also a relatively simple and inexpensive instrument, making it widely used in research and industrial settings.
5. Are there any limitations to using a Fabry-Perot interferometer diffraction?
One limitation of a Fabry-Perot interferometer diffraction is that it is only suitable for measuring narrow bandwidths of light. It also requires precise alignment and can be affected by external vibrations, making it less suitable for field use. Additionally, it may not be suitable for measuring highly absorbing materials.
  • Other Physics Topics
