one_raven
- 203
I was reading an article regarding "morphogenic fields".
http://twm.co.nz/shel_morfields.htm
I am not really all that interested in the author's conclusions, rather I want to verify the experiments cited. Specifically what he claims in this excerpt:
I have done a little checking and one of the two websites I came across cited the article I linked to as its source (not much help there) the other one claimed that Agar started his experiment in 1938 and ran it for twenty-five years.
Not only would I like correct information on this, but I am also looking for much more complete and specific information regarding how these experiemnts and others (F.A.E. Crew, for example) were performed and the exact results found.
Can anyone help me out with this one?
Thanks.
In the meantime, the puzzles about memory have grown even stranger. This part of our story will take us to one of the most controversial frontiers of current science, although it actually starts back in 1920 when W. McDougall, a biologist at Harvard, began an experiment to see if animals (in this case white rats) could inherit learning. The procedure was to teach the rats a simple task (avoiding a lighted exit), record how fast they learned, breed another generation, teach them the same task, and see how their rate of learning compared with their elders. He carried the experiment through 34 generations and found that, indeed, each generation learned faster in flat contradiction to the usual Darwinian assumptions about heredity. Such a result naturally raised controversy, and similar experiments were run to prove or disprove the result. The last of these was done by W.E. Agar at Melbourne over a period of 20 years ending in 1954. Using the same general breed of rats, he found the same pattern of results that McDougall had but in addition he found that untrained rats used as a control group also learned faster in each new generation. (Curiously, he also found that his first generation of rats started at the same rate of learning as McDougall's last generation.) No one had a good explanation for why both trained and untrained should be learning faster, but since this result did not support the idea that learning was inherited, the biology community breathed a sigh of relief and considered the matter closed.
Thanks.
