MHB Factorials and Exponent Challenge
anemone
MHB
POTW Director
Find all positive integer solutions $(a,\,b,\,c,\,n)$ of the equation $2^n=a!+b!+c!$.
Mathematics news on Phys.org
Without loss of generalty we can have $a>=b>=c$.
Now we get a multiple of power of 2 only when we add multiples of same power of 2
So $a!$ and $b!+c!$ should be muiltiple of same power of 2. and when we add the 2
we shall get multiple of power of 2 say of the form $m2^x$. if m is power of 2 then we are
done.
Now b and c should be multiple of same power of 2 and when we add the same we get a multiple of
higher power and further this should be same as multiple of power of 2 of a.
So we have 2 cases to check
$b = c$ and $a = 2$ or 3 (for reason please see below )-
And $ b = c + 1$ then any a.
As c devides a!+b!+c! so c can not be greater than 2 as sum is power of 2
Now
Put the values b= 1, c = 1 giving a = 2 or 3 as a =4 gives a! divsible by 4 but b!+c! is not
a =2 gives c = 2
a =3 gives c = 3
c= 2, b= 3 gives b! + c! = 8 so we need to check for a = 4 and 5 only as a = 6 or above a! is
divisible by 16 so it is not possible
a = 4 gives 32 power of 2 so n = 5 so solution (4,3,2,7)
a = 5 gives 128 power of 2 so n = 7 so solution (5,3,2,7)
so solution set $(2,1,1,2), (3,1,1,3), (4,3,2,7),(4,3,2,7)$ and any permutation of 1st 3 numbers is each set
done.
Now
a =2 gives c = 2
a =3 gives c = 3
above one has mistake in last 3 lines
it should be
a = 4 gives 32 power of 2 so n = 5 so solution (4,3,2,5)
so solution set $(2,1,1,2), (3,1,1,3), (4,3,2,5),(5,3,2,7)$ and any permutation of 1st 3 numbers is each set
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
