Factoring Fractions: Simplifying Equations with Cancellation
  • MHB
  • Thread starter mathlearn
In summary: Many thanks,In summary, the person is asking how to solve a math problem and provides a summary of their solution. They explain that it becomes obvious after some practice and that the transformations used can be called "multiplying and dividing by the same number".
mathlearn
331
Hi , So far I am stuck in this math problem and
View attachment 5779 MINUS (-) View attachment 5780
Subtract the first sum with pie from the second sum and you should factor it such that the a similar out come in the below given image.
Can anyone subtract and factor this for me such that View attachment 5778
and can you explain me how you did this in a little descriptive manner
Many thanks
Mathematics news on Phys.org
Get a common denominator and then factor.
I'm sorry would you be kind enough to demonstrate please!
\(\displaystyle \pi a^2h-\frac23\pi a^3=\frac{\pi a^2}{3}\cdot3h-\frac{\pi a^2}{3}{2a}=\frac{\pi a^2}{3}(3h-2a).\)
Thank you , can you explain a little bit on how did you solved this problem.
Many Thanks
If you are asking how one comes up with the exact sequence of expressions $E_1,\dots,E_n$ such that $\pi a^2h-\dfrac23\pi a^3=E_1\dots=E_n=\dfrac{\pi a^2}{3}(3h-2a)$, it becomes quite obvious after some practice. If you are asking about a specific equality or transition that you don't understand in my solution, please say which one.
Where did /3 come from in the second step & can you explain a little step by step in doing this
I am using the following laws:
\begin{align}
&(1)\quad x\cdot1=x\\
&(2)\quad\dfrac{3}{3}=1\\
&(3)\quad x\dfrac{y}{z}=\dfrac{xy}{z}\\
&(4)\quad xy=yx\\
&(5)\quad (xy)z=x(yz).
\end{align}
So
\pi a^2h\overset{(1)}{=}\pi a^2h\cdot1\overset{(2)}{=}\pi a^2h\cdot\dfrac33\overset{(3)}{=}\frac{\pi a^2h\cdot3}{3}\overset{(4,5)}{=}\frac{(\pi a^2)(3h)}{3}
\overset{(3)}{=}\frac{\pi a^2h}{3}\cdot 3h.
Many thanks,
Can I know the name of the method you used to solve this
for example like quadratic equations or so
As I said, this is much easier than the quadratic formula and becomes obvious after some practice. The transformations used here can be called "multiplying and dividing by the same number" or "cancellation" (3 in the numerator cancels with 3 in the denominator).
It may be good to get a cheat sheet of laws of fractions, such as this one.
FAQ: Factoring Fractions: Simplifying Equations with Cancellation
What is the difference between solving and factoring an equation?
Solving an equation means finding the value(s) of the variable that make the equation true, while factoring an equation means expressing it in a simpler form by breaking it down into its component parts.
Why is it important to solve and factor equations?
Solving and factoring equations help us understand and manipulate mathematical relationships, and are essential skills in algebra and other areas of mathematics.
What are the common methods for solving and factoring equations?
The most common methods for solving equations are substitution, elimination, and graphing, while the most common methods for factoring equations are grouping, difference of squares, and completing the square.
How do I know if I have solved or factored an equation correctly?
To check if you have solved an equation correctly, plug the value(s) you found for the variable back into the original equation and see if it is true. To check if you have factored an equation correctly, multiply out the factors to see if they simplify to the original equation.
What are some common mistakes to avoid when solving and factoring equations?
Some common mistakes to avoid when solving and factoring equations include forgetting to distribute correctly, making arithmetic errors, and not simplifying the final answer.
