Factoring Polynomials: Start Here
In summary, the conversation was about factoring the polynomial $m^8-n^8-2m^6n^2+2n^6m^2$. The expert suggested factoring the first two terms as the difference of squares and the last two terms by factoring out a common factor. The final answer was $(m-n)^{3}(m+n)^{3}(m^2+n^2)$.
paulmdrdo1
385
how would i start factoring this
Mathematics news on Phys.org
Re: factoring polynomial
You really need to post your attempts at these, this way we can see where you are at. :D
I would look at factoring the first two terms as the difference of squares, and the last two terms have a common factor as well (I would factor out $-2m^2n^2$)...what do you get?
this is where i can get to
$(m^4+n^4)(m^4-n^4)-2n^2m^2(m^4-n^4)$
$(m^2-n^2)(m^2+n^2)(m^4+n^4)-2n^2m^2(m^2-n^2)(m^2+n^2)$
$(m-n)(m+n)(m^2+n^2)(m^4+n^4)-2n^2m^2(m-n)(m+n)(m^2+n^2)$
I would take this path:
\(\displaystyle \left(m^4+n^4 \right)\left(m^4-n^4 \right)-2m^2n^2\left(m^4-n^4 \right)\)
\(\displaystyle \left(m^4-n^4 \right)\left(m^4-2m^2n^2+n^4 \right)\)
Do you recognize that the second factor is a square of a binomial?
yes this is answer
paulmdrdo said:
yes this is answer
Yes, good job! (Sun)
FAQ: Factoring Polynomials: Start Here
What is factoring a polynomial?
Factoring a polynomial is the process of breaking down an algebraic expression into smaller, simpler expressions that can be multiplied together to give the original expression.
Why is factoring polynomials important?
Factoring polynomials is important because it allows us to solve equations, find roots and zeros, and simplify complex expressions. It is also used in many real-life applications such as finance, engineering, and physics.
What are the different methods for factoring polynomials?
There are several methods for factoring polynomials, including the greatest common factor (GCF) method, grouping method, difference of squares method, and trinomial factoring method. Each method is useful for different types of polynomials and can be chosen based on the specific polynomial given.
How do I know when a polynomial is completely factored?
A polynomial is completely factored when it is written as a product of irreducible factors. In other words, when no further factoring can be done and all the factors are prime numbers or irreducible polynomials.
Can you provide an example of factoring a polynomial?
Yes, for example, we can factor the polynomial x^2 + 5x + 6 using the trinomial factoring method. This gives us (x+2)(x+3) as the factored form. We can check this by multiplying the factors together to get the original polynomial.
11K
