- 8,875
- 637
I'm not sure if I should post this here or in the mathematics section.
I'm trying to find a way to implement a mapping of a larger finite field such as GF(2^64) to a composite field GF((2^32)^2). Let f(x) be a primitive polynomial for GF(2^64), with 1 bit coefficients. If the coefficients of f(x) are considered as 0 and 1 values in GF(2^32), there will be 32 unique primitive polynomial factors of the form x^2 + ax + b where the coefficients are also elements of GF(2^32), that will provide isomorphic mapping from GF(2^64) to GF((2^32)^2), where map(a b) = map(a) map(b) and map(a+b) = map(a) + map(b). I only need one of the 32 factors.
The process normally involves removing repeated factors, but in this case there are none, and then finding factors for specific degree, but in this case the degree for all factors will be 2 (quadratic).
I've done web searches for this, but not having luck with a description that explains the process well enough for me to create code. Based on the articles I've seen so far, rather than a non-feasible brute for search for 32 out of 2^64 possible combinations of values, the process can be reduced to something feasible like 2^36 or so trial combinations.
