MHB Factoring when exponent is a variable
The discussion revolves around factoring the expression (x^(1/n) + a)^(n-1), with particular emphasis on the challenges posed by the variable exponent n-1. Participants suggest using the law of exponents to simplify the expression and recommend applying the binomial theorem for further manipulation. There is a focus on the goal of dividing the expression by x and achieving a specific result, x^(1/n) - (n-1)a, while acknowledging that some terms may be ignored for simplicity. The term "factoring" is debated, with clarification that it involves breaking down expressions into lower-degree terms, which is less common in this context. The conversation highlights the need for careful consideration of terms when applying these mathematical techniques.
Vac1
I am trying to factor the following equation
$$\large(x^{\frac{1}{n}}+a)^{n-1}$$
but the fact that the exponent is n-1 is throwing me off. How could I go about factoring out this equation? Thanks.
Mathematics news on Phys.org
Use the law of exponents to simplify the exponent: $$ \displaystyle \left(x^{\frac{1}{n}}\right)^{n-1} = \left(x^{\frac{1}{n}}\right)^n \cdot \left(x^{\frac{1}{n}}\right)^{-1} $$
The only real advantage I can see to simplifying this expression is to be able to use the binomial theorem on the exponent.
The reason I'm trying to factor it is so that I can divide it by x.
$$\large\frac{x}{(x^{\frac{1}{n}}+a)^{n-1}}$$
I'm not concerned with the remainder at all but I'm looking for a result that should be equal to:
$$\large x^{\frac{1}{n}}-((n-1)a)$$
I'm assuming to get this, I'll need to ignore some of the terms in the polynomial when factoring which have less of an influence. Thanks
I do not know if this could help you
let x^{\frac{1}{n}} + a = u
\frac{(u-a)^n}{u^{n-1}}
but you still need the binomial theorem as what supersonic said
if you want to ignore the terms with the denominator different from 1
\frac{(u-a)^n}{u^{n-1}}\approx u - na
sub u value and factor -a
What do you mean by "factoring" this expression(not equation). ?? I don't quite understand what exactly you want to do with this expression.
Factoring to me is something like $x^2+5x+6=(x+2)(x+3)$
Factoring is essentially splitting an expression into terms each with a lower degree than the original. You could factor 8 as (2)(2)(2) or (2)(4) if you so wanted (this mainly comes up in prime factoring for LCM and GCF).
Alternatively you could factor $x^3-x = x(x^2-1) = x(x-1)(x+1)$
In this case factoring is unusual and the only way I could see it being used is to then use the binomial theorem with appropriate truncation
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
