Factors Affecting Acceleration Due to Gravity in Free Fall Experiments
In summary, the factors that may cause the experimental value of acceleration due to gravity to be different from the accepted value in a free fall experiment include air resistance, human error, instrument error, wrong calibration, and variations in g on the Earth's surface. However, the specific factors that apply depend on how the experiment was conducted, as factors such as human error and instrument error may not be relevant in all cases. It is important to consider all potential factors and estimate the associated errors when calculating the final answer.
nnis13
25
What factors may cause the experimental value of acceleration due to gravity to be different from tha accepted value in a free fall experiment?
Will it be something like air resistance , human error , instruments error or wrong calibration ??
All of those plus g does vary a little on the Earth's surface. Oil companies actually use the variation to find likely oil fields.
Much depends on how you measured g. The usual approach is to estimate the inaccuracy in measured quantities and "propagate" those errors through to the final calculated answer.
So all these (air resistance , human error , instruments error or wrong calibration) are true? Because it's a question i have to answer for an experiment
Well, exactly how did you do the experiment? If we tell you "air resistance" and the experiment used a vacuum chamber, that isn't too useful, is it?
It was an experiment with a picket fence and a photogate
Well, then there's no human error because a computer is doing the measurements. (You could of course say there's an error associated with the person dropping the picket fence--and in fact that's the main source of error here--but you have to be way more specific.) Instrument error, calibration errors, etc. are all valid, but they probably play a small role.
Yes i know that some of these might play a small role but actually it's a question i have to answer that asks what factors may cause a difference, so i think it doesn't matter if they play a small role i just have to mention all of them right ?
Related to Factors Affecting Acceleration Due to Gravity in Free Fall Experiments
What is acceleration due to gravity?
Acceleration due to gravity is the force of gravity acting on an object, causing it to accelerate towards the center of the Earth at a rate of approximately 9.8 meters per second squared.
What factors affect acceleration due to gravity in free fall experiments?
The factors that affect acceleration due to gravity in free fall experiments include the mass and distance between objects, the shape of the objects, and the presence of air resistance.
How does mass affect acceleration due to gravity in free fall experiments?
The mass of an object does not affect acceleration due to gravity in free fall experiments. All objects, regardless of their mass, will accelerate towards the Earth at the same rate.
Why is air resistance a factor in free fall experiments?
Air resistance is a factor in free fall experiments because it creates a force that opposes the motion of an object. This can affect the acceleration of the object and cause it to fall at a slower rate than expected.
How does the shape of an object affect acceleration due to gravity in free fall experiments?
The shape of an object can affect acceleration due to gravity in free fall experiments by changing the surface area and air resistance of the object. Objects with a larger surface area will experience more air resistance and may fall at a slower rate compared to objects with a smaller surface area.
  • STEM Educators and Teaching
