Factors affecting drift velocity?
In summary, according to the student, increasing the temperature in a conductor will increase the vibrations of the ions in the material, creating more collisions for the electrons or charge carriers. This will then increase the resistance and decrease the current. Additionally, if the temperature is increased in a semi-conductor (which will have fewer free charge carriers), the atoms in that semi conductor will be given energy, and this energy will liberate more electrons and release them into the path of flow of the current, so this will then decrease the resistance, and increase the current.
LotusTK
36
I am having a look at drift velocity and i know essentially what it is, and i am now noting down the factors that effect the drift velocity of the charge carriers as i think its a useful thing to know.
So, so far i have that the number of charge carriers will effect the velocity. The more charge carriers you have, the less quickly they must move in order to deliver a current.
If another material is to deliver the same current, and it has less charge carriers per m^3, then those fewer charge carriers will have to move more quickly in order to deliver the charge.
I have also noted down that increasing the temperature in a conductor will increase the vibrations of the ions in the material, creating more collisions for the electrons or charge carriers. Which will increase the resistance and decrease the current flowing through that material
Also, if the temperature is increased in a semi-conductor (which will have fewer free charge carriers), the atoms in that semi conductor will be given energy, and this energy will liberate more electrons and release them into the path of flow of the current, so this will then decrease the resistance, and increase the current. (or if the current were to remain the same, the drift velocity will decrease)
I think the above statements are correct??
I do not quite know how the charge of each carrier and the cross sectional area will effect the drift velocity though.
I think i am correct in saying that an increased current will result in a higher drift velocity? But then looking at the formula I=nVQA makes me think otherwise...
I=nVQA
Current = #of charge carriers x Drift Velocity x Charge per carrier x Cross sectional Area
Correct.
If you increase I, what has to happen to the velocity v if the other parameters stay constant?
If you increase the charge per charge carrier or the cross-section of the conductor, what else can you change for example if everything else stays constant?
Mathematically, looking at the formula, as current increases, velocity will have to decrease if all the other variables remain constant.
Then rearranging to get v = I/nAQ , could it be said that velocity is inversely proportional to number of charge carriers,cross sectional area and charge per unit carrier? Therefore an increase in any of these 3 variables means that the velocity will decrease? (So if the area decreases, velocity increases, or if the charge per unit carrier decreases, velocity increases)
Basically anything on the denominator of the equation v=i/nAQ is inversely proportional to velocity.
Yes.
To avoid ambiguity, I would write that as v = I/(nAQ)
Cheers.
Would it be possible for you to give me an idea or a hint as to why they change the velocity? Now that i know HOW they effect velocity, i can't quite get my head around why they change the velocity.
You rarely have a situation like "I keep current constant and increase the number of charge carriers", so I don't know how useful it is to analyze this.
Current is the charge per time that flows through the resistor. If you keep current constant but increase the density of charge carriers you need a slower velocity to get the same amount of charges per time. The same applies to the other factors.
In the past papers for my exam board i often see types of questions where they change something and ask how this has an implication on something else, so i find it useful to know these kind of things.
It is also really helpful for me to know as it allows me paint an image in my head of how the different concepts in physics.
Thanks for all your replies :)
Related to Factors affecting drift velocity?
What is drift velocity and how is it affected by external factors?
Drift velocity is the average velocity of charged particles, such as electrons, in a conducting material under the influence of an electric field. It is affected by external factors such as the strength of the electric field, the type of material, and the temperature.
How does the strength of the electric field affect drift velocity?
The strength of the electric field directly affects the drift velocity. As the electric field increases, the particles experience a greater force and thus increase their velocity. This relationship is described by the equation v = μE, where v is the drift velocity, μ is the material's mobility, and E is the electric field strength.
What is the role of temperature in drift velocity?
Temperature plays a significant role in drift velocity as it affects the mobility of particles in a material. At higher temperatures, particles have more thermal energy and can overcome obstacles within the material, resulting in a higher mobility and therefore a higher drift velocity.
How does the type of material influence drift velocity?
The type of material also affects the drift velocity. Materials with higher conductivity, such as metals, have a higher density of free electrons and therefore a higher mobility, resulting in a higher drift velocity. Insulating materials have a lower density of free electrons and therefore a lower drift velocity.
Are there any other factors that can affect drift velocity?
Other factors that can affect drift velocity include impurities in the material, external magnetic fields, and the shape and size of the conductor. Impurities can disrupt the movement of particles, while magnetic fields can alter the direction of particle motion. The shape and size of the conductor can also affect the concentration of particles and their mobility, which can impact the drift velocity.
10K
