Failed rocket problem (momentum conservation, Kleppner 4-4)
The discussion centers on the complexities of a rocket problem related to momentum conservation. Participants highlight that the initial movement of the rocket is not free fall, complicating the trajectory analysis. It is noted that if the rocket maintains powered flight until the top of its trajectory, the horizontal velocity before an explosion remains unknown, leading to unpredictable landing distances. The consensus is that assuming the rocket burns out quickly and follows a parabolic free fall is necessary for a consistent solution. This approach allows for a clearer understanding of the rocket's landing position.
Michael Korobov
An instrument-carrying rocket accidentally explodes at the top of its trajectory. The horizontal distance between the launch point and the point of explosion is L. The rocket breaks into two pieces that fly apart horizontally. The larger piece has three times the mass of the smaller piece. To the surprise of the scientist in charge, the smaller piece returns to Earth at the launching station. How far away does the larger piece land? Neglect air resistance and effects due to the Earth’s curvature.
Momentum conserved
Kinematics equations
Hi,
Can anyone hint me if there is issue in the problem statement?
Consistent answer can be obtained if one presumes that the trajectory of center mass is parabolic.
Assuming this, the CM will land at distance L right to the axis of symmetry of parabola.
But the problem tells about a rocket, therefore first part of rocket movement is not free fall and thus the horizontal distance of falling after the top of trajectory is not necessarily L.
Is it deduction correct?
Yes, it is not necessarily L. That's why the scientist in charge was surprised when it landed there.
  • Haha
Likes Michael Korobov
If we assume powered flight all the way to the top of the trajectory then we have, in principle, no way to know the horizontal velocity of the rocket just prior to the explosion.
It is possible, for instance, that the rocket reverses course, that the "explosion" is a mere fizzle and that both rocket pieces land together at the launch site.
Accordingly, one assumes, as you did in your solution, that the rocket burns out almost immediately after launch and then carries on in a parabolic free fall trajectory. Otherwise, there is no way to a solution.
Indeed, this was the only way to get consistent solution.
Thanks!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
