Failure Due to Stress or Strain?
In summary, the author is looking for a theoretical proof that it is possible to predict failure based on just stress or just strain. They are also researching the relationship between elasticity, plasticity, and the structure of matter.
247killingtim
Currently I am studying the mechanical properties of artery tissue, and was tasked with determining if the tissue fails due to shear stress or shear strain. I have always worked under the assumption that they go hand in hand with each other, but the nature of this question obviously suggests this isn’t necessarily the case.
After some research, I've found some sources (link below) suggesting that in anisotropic materials, materials where the mechanical properties are differ based on direction of loading/displacement, simple conversions between the stress and strain no longer hold true.
I’m most likely going to run experiments using both strain and stress as the independent variable and seeing which reaches failure first, but I’m having trouble finding any theoretical proof that this would be a valid conclusion. I was thinking that necking is an indicator for failure due to strain, but I couldn’t think of an observable property that would indicate failure due to stress. Additionally, since I’m doing direct shear tests I don’t think necking will be observable anyway.
Anybody have any ideas or a direction to point me?
http://www.failurecriteria.com/isitstressorstra.html
Hello and welcome Killingtim
An interesting problem to investigate.
Some thoughts.
1) Time is a very important variable with materials such as those you are dealing with, as the material response to load takes time to develop. Creep in some materials is one aspect of this.
2) The nature of the load plays a large part in the failure of materials, or even if they fail at all. Loads can be uniaxial, biaxial or triaxial or bending or whatever.
3) Temperature and moisture content are liekly to also be important variables with your material.
Much work has been done on a material that has many similarities, namely bread dough.
there is a whole chapter on this in the excellent Cambridge University book
Elasticity, Plasticity and the Structure of Matter
by Houwink and DeDecker
with many references.
Another book, (a New Scientist Popular Science book) has published data and discussion about the stress strain curves for blood vessels (after Shadwick)
Cats Paws and Catapaults
by
Steven Vogel
go well
I wonder if what the 'tasker' is concerned with is whether you can predict failure based on just stress or just strain. For example maybe it fails with a particular strain state, but the stress required to cause that strain can vary based on all sorts of paramaters like time history, moisture content, etc.
Even then it seems doubtful that the answer could be so simple for such a material.
What's the importance of the distinction? My understanding: Stress and strain are directly related; though anisotropy makes it more difficult to transform your stresses into different, possibly more convenient, coordinate systems.
here's a reference that may be useful for you: http://solidmechanics.org/text/Chapter3_2/Chapter3_2.htm
What is the problem you're trying to solve? Loading condition? General material properties of arterial tissue? Can you assume any material symmetry for the tissue?
Strain is possible without stress.
Yes, this is true I did overlook that important bit in Hooke's Law. This isn't necessarily true for the shear stress-strain problem presented though, correct?
Stress free strain has nothing to do with Hookes law.
An example would be unrestricted thermal expansion. Stress is only developed in thermal expansion in the event of external restraint.
Nor was the OP about shear in particular. If the pressure inside a blood vessel increase, this is countered by and increase in circumferential tension in the vessel wall, as in any membrane. I take the reference to shear as the possibility that the wall material may fail in shear in a direction roughly 45 degrees to the principal stress in the normal manner.
I've got all kinds of overlooking shenanigans going on here.
Though, I did get the impression the OP was talking about shear in particular; if that's the proper thing to be be investigating I guess could depend on the application studied, which wasn't mentioned.
I'm picturing a mechanical test and trying to visualize how the shear strain will be/was developed without stressing the sample simultaneously. Maybe I'll also take a look at that bread dough situation you mentioned March 11th.
Sorry I didn’t jump in earlier but , the question actually does pertain to shear specifically, I’m sorry I didn’t make that more apparent. However, I think that as far as failure theory goes, the same general principles should apply to both normal and shear stress.
I think the largest issue I’ve run into while testing is the viscoelastic nonlinear nature of the tissue. Biological Materials in general, (a link is shown below) appear to exhibit nonlinear properties; this has been partially confirmed by the few tests I have run. From what I’ve read, viscoelastic materials don’t obey Hooke’s law, which makes characterizing the material failure and the stress-strain relationship much more difficult.
http://www.loci.wisc.edu/files/loci/NLV.pdf
Have you considered applying any ASTM (or other) standards for viscoelastic polymers to your situation? Is this not possible or does one not exist?
Perhaps if you were to elaborate on where your investigations have got to we could help further?
I hadn't thought of that, it appears that there aren't any standards that match my situation exactly, but I will definitely investigate further and see if there is anything I can use.
Could you rephrase the question, I'm having difficulty understanding exactly what you are asking? I'm attempting to describe the general failure of artery tissue. I'm currently performing direct shear tests on small (6mm x 6 mm) samples using a shear rheometer that my supervising professor designed. If you want more details on the rheometer I will send you a paper we used as a model during the design process. So far I have only run a few successful tests, but I'm just trying to get a good theoretical basis down for any conclusions I might reach.
Are you also investigating the artery tissue's failure in relation to shear rate?
Related to Failure Due to Stress or Strain?
What is failure due to stress or strain?
Failure due to stress or strain occurs when a material or structure is unable to withstand the applied stress or strain, resulting in permanent deformation or breakage.
What are the types of failure due to stress or strain?
There are three main types of failure due to stress or strain: ductile, brittle, and fatigue. Ductile failure occurs when a material deforms plastically before breaking, while brittle failure occurs when a material breaks without significant deformation. Fatigue failure is caused by repeated loading and unloading of a material, leading to cracks and eventual failure.
What factors contribute to failure due to stress or strain?
There are several factors that can contribute to failure due to stress or strain, including the type and magnitude of the applied stress, the type of material, and the environmental conditions. Other factors such as manufacturing defects, improper design, and inadequate maintenance can also play a role in failure.
How can failure due to stress or strain be prevented?
There are various ways to prevent failure due to stress or strain, including using materials with appropriate strength and ductility for the intended application, designing structures to withstand expected loads and stresses, regularly inspecting and maintaining structures, and following safety guidelines and regulations.
What role does testing play in understanding failure due to stress or strain?
Testing is an essential tool in understanding failure due to stress or strain. By subjecting materials and structures to different types and levels of stress, scientists and engineers can determine their strength, ductility, and failure points. This information can then be used to design safer and more reliable structures and materials.
  • Mechanical Engineering
  • Materials and Chemical Engineering
