Failure of a steel shelving unit
In summary, determining the weight capacity of mild steel shelving units involves analyzing each shelf as a simply supported beam and calculating the deflection and maximum bending stress. The maximum weight capacity for each shelf should be much lower than the yield stress and fracture stress, and the maximum allowable deflection should be kept within acceptable limits. However, this does not take into account potential failures in the fasteners or buckling of the uprights. Further research may be needed, including studying edge stiffened plates and support conditions in advanced structural mechanics texts.
Ralff
I am currently working on a project to determine how much weight a mild steel shelving units can support. This is a project for a friend and for my own interest.
I am having trouble deciding exactly what is necessary to determine the weight the shelving units will hold. Each shelf on the unit is supported by four pins. Do I analyze each shelf as a beam with a uniformly distributed load? Do I use the yield stress to determine the max load possible after applying a safety factor? For the sides, is it necessary to determine buckling?
I've taken a mechanics of materials class, so I understand, bending stress etc.. I am just not sure exactly how to use what I know to determine the maximum capacity for each shelf and the shelving unit as a whole.
I will appreciate any help. The shelving unit is similar to the one in the link below. Thanks.
http://www.menards.com/main/storage-organization/garage-outdoor-organization/freestanding-storage/edsal-heavy-duty-16-gauge-boltless-steel-shelving-60-in-w-x-24-in-d-x-72-in-h/p-1863678.htm
Your first task will be to determine what you mean by "how much a shelf can support" ie to specify your failure criteria.
For mild steel the deflection will become unacceptable long before there is any failure to support load.
Static load capacity far from the only issue here, you have multiple possible failure modes [substrate load capacity, fasteners, etc.] and load conditions to consider. Safety factors are routinely applied to simplify matters. Finite element analysis is an option, but, rather impractical in most cases.
It's not too hard, just quite a bit of work. You'll have to go through each failure mode like Chronos said. Start with the easy ones, like what is the maximum load each shelf will have to take and determine the maximum stress in the beams. Compares these values with the relevant standards. For example, deflection should be limited to span/250 for a beam with fixed ends. Then you might add up the total load from all the shelves and determine the maximum stress in the bottom sections. It's a pretty easy one, the hard part are the holes in the material...
I'd start with figuring the moment of inertia for the shelf cross section. From there you can figure the max point load you can put in the middle of the shelf and get an idea of your FOS based on crap-steel yield...36ksi. You can distribute the load along a shelf but the max moment will still be the same.
The design is limited to how easily the joints can pull apart and how far the frame can move. Do a force balance on the structure to figure geometry.
According to the ad each shelf can take 700 .lbs. If each Shelf is 16 Ga. over a 60" span, I'm guessing they're pushing an FOS of a mere 1 per shelf.
The next thing to figure out is how substantial the boltless interface is.
To answer your question, if your support system is solid, your shelf material and lengths can be easily figured.
So, first, I should analyze the shelves individually as simply supported beams by finding the cross section moment of inertia and calculating the deflection and max bending stress in each shelf (beam).
So, to determine the max weight capacity for a shelf, I need to make the max stress in the shelf much less than the yield stress and fracture stress, and I also need to make the max allowable deflection acceptable say span/250?
This is not taking into account that the fasteners could fail. Would this be correct so far?
Ralff, is this a school or college project.
If so at what level?
Studiot, this is a project I am working on only to gain experience. I am a college student. I have a degree in Mathematics, and I am working on my degree in engineering, and I have only taken the first semester of a mechanics of materials class. Sorry about the late reply, I was away on break.
I am doing this because I am curious what goes into deciding weight limits on shelving units, stands, etc.. I figured the best way to find out is do it myself and compare results with actual weight limits.
Well I'm sorry to tell you that this shelving project is too difficult for elementary mech of mat.
The shelves are edge stiffened plates, not beams and they are supported at the corners.
You can have some fun, however, calculating things like the tearout shear of the bolts and the buckling strength of the uprights and the many things others have said.
go well with your project and studies
Do you know where I can find more information about deflection in edge stiffened plates?
Well there was much research into this in the second half of the 20th century, but most of the published work is papers. Google will find some of these.
Classic theory as presented in tabulated books of formulae such as those by Roark or Pilkey only treat flat plates.
There is some stuff pertaining to support conditions in the classic treatment by Timoshenko
The Theory of Plates and Shells.
With your background you could cope with
Advanced Structural Mechanics by D Johnson
He has a chapter on plates and membrane theory (and much else) that would be useful.
I would approach this as follows
1) Consider the edges as stiff beams. This will generate support conditions.
2) Consider the main area of shelf as a flat plate or membrane with the support conditions provided by (1). You will have to experiment with moments transferred to the supports v simple support. Johnson's treatment comes in handy here.
You have me curious, are there simulators available for this type of analysis?
You can use various structural design (computer) packages for this. Some offer analysis of framed structures as opposed to FE analysis. These would be with rigid or semi rigid joints.
A sheet metal shelf such as this is really a thin diaphragm or membrane supported on a stiff rectangular edge. Thin plates (diaphragms or membranes) carry their load by in-plane forces, unlike beams which have provide the resistance moments by forces above and below the (neutral) plane. Thick plates or slabs can be considered as two dimensional or two way beams.
In bridge deck analysis one form is known as a grillage, this could be pressed into service here.
Don't waste your time. It's not that complicated.
While I'm a Timoshenko fanboy, there are no plates or shells to be analyzed on this unit. Each shelf is comprised of formed channels with lips to support the filler material (particle board). While the particle board is cheap crap, in addition to holding stuff it supplies weight to drive the shelves into the post locks creating a stiffer joint.
Note there are no diagonal truss members which would be absolutely necessary if the shelves were a thin material e.g. a 22 ga home depot $10 unit.
Mc/I should do it.
The actual joints will need to be seen.
Related to Failure of a steel shelving unit
1. What could cause a steel shelving unit to fail?
There are several potential causes for the failure of a steel shelving unit. These may include overloading the unit with too much weight, poor installation or assembly, corrosion or rust, and structural defects or flaws in the materials used.
2. What factors can contribute to the structural failure of a steel shelving unit?
Factors such as the quality of the steel used, the design and construction of the unit, and the environmental conditions it is exposed to can all play a role in the structural failure of a steel shelving unit. Additionally, misuse or improper maintenance can also contribute to failure.
3. How can I prevent a steel shelving unit from failing?
To prevent failure of a steel shelving unit, it is important to follow the manufacturer's guidelines for weight limits and proper installation. Regular inspections and maintenance can also help identify any potential issues early on. Using high-quality materials and avoiding exposure to harsh environments can also help prevent failure.
4. Can a steel shelving unit be repaired if it fails?
In some cases, a steel shelving unit may be able to be repaired if it fails. This will depend on the extent of the damage and the cause of the failure. It is important to consult a professional for proper repair methods and to ensure the unit is safe to use afterwards.
5. Are there any safety concerns associated with a failed steel shelving unit?
Yes, there can be safety concerns associated with a failed steel shelving unit. If the unit collapses or becomes unstable, it can pose a risk to anyone nearby. It is important to properly dispose of a failed unit and to take necessary precautions to prevent further accidents.
  • Mechanical Engineering
  • DIY Projects
  • General Engineering
17K
