Fairly basic trigonometric equation
In summary, the conversation discusses an equation of the form Acos(A*x)-Bcos(B*x)=0, where A>B, and whether there is a general solution for this equation. The participants suggest using the equation Acos(A*x) = Bcos(B*x) and inspecting the existence of trivial roots. It is determined that there are trivial roots at x=n and x=n/D if D divides both A and B. The other roots are believed to be irrational or transcendent. The conversation ends with the question of how to mark the thread as solved.
intangible
Is there a general solution for an equation of this form?
Thanks,
intangible
I'm quite inclined to say there are no solutions for that :(
Thanks,
intangible
Acos(A*x) = Bcos(B*x) -- So we conclude that A = B
How about A=Pi/2
B=3Pi/2
I really can not be bothered to expand cos (3x), but if you are, I will verify the rest. I highly doubt it works though.
Thanks to everyone participating, I think I got sorted it out by inspecting a similar behaving sine and its infinite product.
[tex]\sin x = x \prod_{n = 1}^\infty\left(1 - \frac{x^2}{\pi^2 n^2}\right)[/tex]
If we assume Asin(pi*A*x)=Bsin(pi*B*x) we may easily inspect the existence of trivial roots if there are any. It turns out there are: for every natural number A and B (A>B) there is a trivial root at x=n. Also, if there is a natural number D so that it divides both A and B, then there will be the trivial roots x=n/D.
[tex]A \prod_{n=1}^\infty\left (A x - n)(A x + n)\right = B \prod_{n=1}^\infty\left (B x - n)(B x + n)\right[/tex]
That leaves A-1 unknown roots per cycle if the former is the case, (A-B)/D per cycle for the latter. Unfortunately, the other roots clearly are irrational, perhaps even transcendent.
Regards,
intangible
(How do I mark this thread solved?)
FAQ: Fairly basic trigonometric equation
Question 1: What is a trigonometric equation?
A trigonometric equation is an equation that contains trigonometric functions such as sine, cosine, tangent, and their inverses. These equations involve the relationship between the angles and sides of a triangle.
Question 2: How do you solve a basic trigonometric equation?
To solve a basic trigonometric equation, you can use algebraic manipulation and trigonometric identities to isolate the variable. Then, use the inverse function to find the value of the angle or side.
Question 3: What are the common trigonometric identities used to solve equations?
The most common trigonometric identities used to solve equations are the Pythagorean identities (sin²x + cos²x = 1), the double-angle identities (sin2x = 2sinx cosx), and the reciprocal identities (cscx = 1/sinx).
Question 4: Can you use a calculator to solve a trigonometric equation?
Yes, you can use a calculator to solve a trigonometric equation. However, it is important to set the calculator to the correct mode (degrees or radians) and to be familiar with the inverse trigonometric functions on your calculator.
Question 5: What are the practical applications of trigonometric equations?
Trigonometric equations have many practical applications in fields such as engineering, physics, and navigation. They are used to solve problems involving angles, distances, and heights in real-life situations.
