Fairly simple (I assume) acceleration derivation I've blanked on
In summary, The conversation discusses a problem related to measuring g using two distances, L1 and L2, and the times t1 and t2 for a ball to pass between the distances. The person has tried using equations of motion and mathematical operations, but has not been successful. A suggested equation to use is v_f^2 = v_0^2 - 2 g d.
Jonnoley
Hi, I understand this is probably not at all complicated, but I've completely blanked and I've been working at it for hours now.
Derive the expression g=2(L2t1-L1t2)/t1t2(t1+t2)
I've replaced the lower case ls there with upper case one's for clarity, but it's just two distances, L1 and L2
This relates to a simple experiment to measure g I'm currently doing a lab report for, where L1 and L2 are the distances between some infrared sensors on the drop tower, and t1 t2 are the times for the ball I dropped to pass between the sensors.
I have no idea, I've tried every equation of motion and every mathematical operation I could.
I have tried substituting Δt, ΔL and Δv into L=vt+(at2)/2 and have got some fairly close answers, but have also proved acceleration doesn't exist several times, so that might be barking up the wrong tree, in the wrong forest, on the wrong planet.
This should be in the lower level physics forum, but no matter. Another relevant equation that you might want to try using is [tex]v_f^2 = v_0^2 - 2 g d.[/tex] That should help you eliminate some of the velocities (that you don't ultimately care about) from the other kinematics equation you listed.
FAQ: Fairly simple (I assume) acceleration derivation I've blanked on
What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is a vector quantity, meaning it has both magnitude and direction.
What is the formula for acceleration?
The formula for acceleration is a = (vf - vi) / t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
How do you derive the formula for acceleration?
The formula for acceleration can be derived by using the basic definition of acceleration as the rate of change of velocity over time, and manipulating equations for displacement and velocity to solve for acceleration.
What is the unit of measurement for acceleration?
The unit for acceleration is meters per second squared (m/s^2), or in some cases, feet per second squared (ft/s^2).
How is acceleration related to other physical quantities?
Acceleration is closely related to displacement, velocity, and time. It is also related to force, as described by Newton's Second Law of Motion, which states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass.
