Fake water spin experiments around the equator
  • I
  • Thread starter greypilgrim
  • Tags
    Equator
In summary, the basin is filled with water, which is poured in the direction of the eventual spin. The direction of the spin is initiated by the way the water is poured into the basin.
greypilgrim
548
38
Hi.
I just visited the equator in Ecuador, where they perform those fake water spin experiments on and a few meters north and south of the line.
I know that the Coriolis effect is way too small on that scale, so how do they do it? They even let spectators pull the plug.
I would guess that the drain is machined to be slightly inclined in order to start a clockwise or counterclockwise flow going when the plug is pulled. A test would be to swap sinks and see what happens to the flow.
Likes berkeman and russ_watters
It's likely due to asymmetries in the shapes of the basins. It seems the easy way to construct this device is to just look around for old basins and test them.
Watch him fill the basin in the second video. He pours the water in the direction of the eventual spin.
Edit to add...
There may be some tomfoolery in the first video. When he grabs the leaves out of the water, he sweeps the first handfull in a counter-clockwise manner and then pauses to watch the remaining leaves. This may be in order to cancel any slight rotation that he observes prior to unplugging the basin.
Likes cjl, greypilgrim, Bystander and 1 other person
It's the same basin every time, they moved it.
That's probably it. Guess I'll have to do some experiments myself when I get home (which is far from the equator).
They had other experiments which were even more obvious BS, like trying to walk a straight line with your eyes closed or the guide pushing your extended arms down (I forgot if it was supposed to be easier or harder on the equator line compared to just next to it).
My favorite was balancing an egg on a nail head, which only a few of the participants succeeded to do. Apparently you can do it at home too, "but only on the 21st of March and September".
Oh, I didn't see that. Well, if that's the case, then it's like @jbriggs444 says, the direction of rotation is initiated by the way the water is poured into the basin.
Careful experiments were done in the 1960's by researchers at MIT. They used special hemispherical bowls that were carefully machined to be symmetrical. After filling the basins they waited a long time to eliminate any motions imparted by the filling process. In Boston they noted that drainage circulation was generally counterclockwise. They shipped the apparatus to Australia and the drainage there was clockwise.
Here's a photo of inlet vortices to an identical pair of culverts. It was peak flow from this springs snow melt, and the culvert inlets were submerged. The left vortex is rotating clockwise, the right vortex is rotating counterclockwise. Latitude is 45 deg North.
I'm too lazy to make the calculations, but it should be easy to show that the hydrodynamic forces due to water flow are several orders of magnitude larger than the Coriolis forces in this situation.
And, if somebody wants to make the calculation, the culvert outlets. Note that, while the inlets are submerged, the outlets are not running full. The water on the upstream side was about one foot below the road.
Likes nasu
FAQ: Fake water spin experiments around the equator
What is a fake water spin experiment?
A fake water spin experiment is a demonstration that falsely claims to show how water drains differently in different hemispheres due to the Coriolis effect. These experiments often manipulate the setup to produce the desired outcome, misleading viewers about the actual science involved.
Why do people perform fake water spin experiments around the equator?
People perform these fake experiments primarily to entertain or to create viral content, often for tourism purposes. They take advantage of the public's limited understanding of the Coriolis effect to create seemingly miraculous demonstrations that attract attention and curiosity.
Does the Coriolis effect influence water draining in sinks and toilets?
The Coriolis effect, which results from Earth's rotation, is too weak to influence the direction in which water drains in small containers like sinks and toilets. The direction of water drainage is primarily determined by the shape of the container and any initial motion of the water.
How can you tell if a water spin experiment is fake?
To identify a fake water spin experiment, look for signs of manipulation such as the demonstrator using subtle hand movements to create a spin or the use of specially designed containers. Authentic scientific demonstrations should explain the setup transparently and avoid any hidden tricks.
What is the real scientific explanation for water spinning differently in different hemispheres?
In large-scale systems like hurricanes and ocean currents, the Coriolis effect does cause rotation to differ between the Northern and Southern Hemispheres. However, this effect is negligible in small systems like sinks and bathtubs. Fake water spin experiments often misrepresent this scientific principle for dramatic effect.
