Falling body with air resistance
In summary, the main difference between the two equations is that the first one is only accurate for low Reynolds numbers and small objects, while the second one is a better model for larger Reynolds numbers and speeds below Mach no 0.2. The second equation is also nonlinear, making it more difficult to solve, and involves a quadratic term that arises from the projectile having to accelerate the mass of air. This term can be neglected in some cases, depending on the ratio between the linear and quadratic terms, but in general, both terms should be considered for a more accurate mathematical model.
chengbin
What is the difference between these two equations.
m dv/dt = mg - kv
and
m dv/dt = mg - kv^2
as the equation modeling a falling body with air resistance?
The first equation is only accurate for very low Reynolds numbers (Re < 1). For bodies falling in the Earth's atmosphere, it only applies to very small objects like dust particles, tiny insects, etc.
The second equation is a fairly good model for larger Reynolds numbers, at least for speeds below about Mach no 0.2 (about 70 m/s) Above that speed, the compressibility of the air begins to affect the situation and "k" is no longer a constant.
From a mathematics point of view, the second equation is nonlinear making it much more difficult to solve.
A bit of theory first.
The function [tex]f(v)[/tex] that gives the magnitude of the air resistance when the object's velocity is less than the speed of sound may be written, with the Taylor series expansion in mind, as
[tex]f(v) = bv + c v^2 = f_\text{lin} + f_\text{quad}.[/tex]​
Now, the physical origin of these two terms are different. The first linear term is due to the viscous drag of the medium, and it's usually proportional to the viscosity of the medium and the linear dimensions of the object. The second quadratic term arises from the projectile having to accelerate the mass of air with which it is continually colliding; it is proportional to the density of the medium and the cross-sectional area of the projectile. For spherical particles, we have
[tex]b = \beta D[/tex]
[tex]c = \gamma D^2[/tex]​
where [tex]D[/tex] is the diameter of the sphere and [tex]\beta[/tex] and [tex]\gamma[/tex] are constants that depende on the nature of the medium. For spherical projectiles in air and for standard conditions, we have approximate values of
[tex]\beta = 1.6 \cdot 10^{-4} ~\text{N}\cdot\text{s}/\text{m}^2[/tex]​
and
[tex]\gamma = 0.25 ~\text{N}\cdot\text{s}^2/\text{m}^4.[/tex]​
Now, to what you asked: often, one can neglect one of the terms compared to the other. To decide which can be neglected, we need to compare the size of the two terms:
[tex]\frac{f_\text{quad}}{f_\text{lin}} = \frac{\gamma D}{\beta}v = \left(1.6 \cdot 10^3 \frac{\text{s}}{\text{m}^2}\right) D v.[/tex]​
So, in a given problem, you have to substitute the values of the diameter and the velocity into this equation to figure if any of the two terms can be neglected. If [tex]\frac{f_\tex{quad}}{f_\tex{lin}} \approx 1[/tex] then unfortunately you have to keep both terms to have a more accurate mathematical model.
EDIT: (Further information) As a rule of thumb, for very small liquid drops in air, but also slightly larger objects in a very viscous fluid, the drag force can usually be taken as linear. For most other projectiles, such as golf balls, cannonballs, humans in free fall, the dominant drag force is the quadratic one.
As AlephZero has mentioned, this discussion can be related to the Reynolds number. As I have mentioned previously, the linear drag can be related to the viscosity of the fluid, and the quadratic term is related to the inertia (density) of the fluid. Thus, the ratio [tex]\frac{f_\text{quad}}{f_\text{lin}}[/tex] can be related to the fundamental parameters of viscosity and density. The result is that this ratio is of roughly the same order of magnitude as the dimensional number [tex]R = \frac{D v \rho}{\eta}[/tex] we call the Reynolds number. This means that, in general, the quadratic drag is dominant when [tex]R[/tex] is large and that linear drag is dominant when [tex]R[/tex] is small.
Reference: Classical Mechanics, John R. Taylor.
Hope this helps.
I disagree with that. For first order equations, the distinction between "linear" and "non-linear" is not as important as for higher order equations. And certainly not in the case of this particular equation which is "separable" and the general solution is easily written.
Thank you guys.
@RandomGuy88, this is so true. This is why I'm asking this equation in my other thread here
https://www.physicsforums.com/showthread.php?p=3197469#post3197469
@HallsofIvy, The non-linear equation ends up involving tanh and stuff, which I didn't learn yet. From Google searches, I have to do partial fractions with square roots. Sounds hard and a lot of work.
chengbin said:
Thank you guys.
You could leave the result as a function of logarithms, if hyperbolic tangents don't make you feel comfortable, but in any case, this is a good example so that you can see where hyperbolic functions appear in real life.
This may be true for a simple free fall problem, but in the linear case when the motion is not restricted to a line (that is, assume you throw something), the equations for both components aren't coupled, so they can be easily solved separately. However, when the drag is quadratic, each component is coupled, and the equations aren't linear to boot, so mathematically, assuming the problem you're treating isn't a simple free fall but rather a general 2 dimensional motion, the problem is more complicated.
Related to Falling body with air resistance
1. What is air resistance and how does it affect a falling body?
Air resistance is the force exerted by air molecules on a moving object. It acts in the opposite direction to the motion of the object and increases as the speed of the object increases. This means that air resistance can slow down the speed of a falling body, as it falls through the air.
2. How does the shape of a falling object affect air resistance?
The shape of an object can greatly affect the amount of air resistance it experiences while falling. Objects with a larger surface area, such as a parachute, experience more air resistance than objects with a smaller surface area, like a pencil. This is because a larger surface area means more air molecules collide with the object, creating a greater resistance force.
3. Why do objects with the same mass but different sizes have different rates of fall?
The rate at which an object falls is affected by both gravity and air resistance. Objects with a larger surface area (and therefore more air resistance) will fall slower than objects with a smaller surface area. This is because the air resistance force acts in the opposite direction of gravity, slowing down the object's acceleration due to gravity.
4. How does air density affect the rate of fall for a falling body?
Air density is a measure of how many air molecules are present in a given volume of air. The higher the air density, the more air molecules there are to collide with a falling body, resulting in a greater air resistance force. This means that in denser air, a falling body will experience more air resistance and fall slower than in less dense air.
5. Can air resistance ever equal the force of gravity, creating a constant velocity for a falling body?
Yes, it is possible for air resistance to equal the force of gravity on a falling body. This is known as terminal velocity and is the point at which the acceleration due to gravity is balanced by the air resistance force. At this point, the falling body will continue to fall at a constant velocity, without increasing in speed. The exact terminal velocity of an object depends on its mass, surface area, and the density of the air it is falling through.
  • Electromagnetism
  • Classical Physics
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
