Falling EM system contradicts the equivalence principle?
In summary: The equivalence principle states that the local effects of gravity and acceleration are indistinguishable. This means that in a small region of spacetime, the laws of physics should be the same for an observer in a gravitational field as they are for an observer in an accelerating reference frame. It does not say that the effects are equivalent, but rather that they are indistinguishable.
jcap
170
The following is an improved version of my previous post https://www.physicsforums.com/threa...contradicts-the-equivalence-principle.964594/
Consider the following system comprising a particle on the left with charge ##+q## that is a large distance ##d## away from two oppositely charged particles on the right, with charges ##+q##,##-q##, held apart by a spring of length ##L## and spring constant ##k##.
Let us assume that the left-hand particle is sufficiently far from the right-hand particles so that the "static" horizontal component of the electric field that it produces near those particles is negligible. (Actually this assumption is not necessary. We could have another charge ##+q## on the other side of the vertical dipole connected to the first by a horizontal rod. They could then be as close as we like as the horizontal electrostatic forces that they produce on the dipole will cancel out.)
To start with consider the system at rest in empty space. The only electric forces acting on the right-hand particles are "static" attractive forces that are balanced by the compressed spring.
Now let us assume that the whole system is falling in a gravitational field with acceleration ##g##. According to the equivalence principle this situation should be indistinguishable from the system in empty space.
But now as the left-hand charge ##+q## has an acceleration ##g## it should produce a "radiative" vertical component to the electric field in the vicinity of the right-hand particles.
Each right-hand particle is subjected to an extra vertical electromagnetic force whose magnitude is given by
$$F_{EM}=\frac{q^2}{4\pi\epsilon_0 d c^2}g.$$
As the forces on the differently-charged right-hand particles point in opposite directions, the spring is stretched by an amount given by
$$\Delta L=\frac{2F_{EM}}{k}.$$
Thus a local observer can tell that he is falling in a gravitational field which contradicts the equivalence principle.
What's gone wrong?
jcap said:
But now as the left-hand charge ##q## has an acceleration ##g##
As do the the spring and the two right-hand particles... so you are trying to analyze the behavior of the system using the non-inertial frame in which an object at rest experiences a proper acceleration of ##g## and an object subject to no forces accelerates in violation of Newton's second law. You can do the problem that way if you want, but it is somewhat non-trivial - far easier to work in the inertial frame in which all three particles are at rest and you can use Maxwell's laws as they are usually written.
But if you do want to do this problem the hard way, you cannot
This assumption is equivalent to saying that terms in ##1/d## are negligible, but the apparent discrepancy you've found is itself a ##1/d## term. You can't ignore the ##1/d## electrostatic term but include the ##1/d## magnetic term and expect to get a consistent result.
(Actually this assumption is not necessary. We could have another charge +q+q on the other side of the vertical dipole connected to the first by a horizontal rod. They could then be as close as we like as the horizontal electrostatic forces that they produce on the dipole will cancel out.)
Right, and in that case you don't have a ##1/d## term that you're declaring negligible, you have a genuine cancellation to zero that will be present in the non-inertial frame as well - it's just that there are magnetic as well as electrostatic components that cancel.
You might want to give thsi wikipedia article a try: https://en.wikipedia.org/wiki/Paradox_of_radiation_of_charged_particles_in_a_gravitational_field
Likes Dale
What's gone wrong?
Why would it radiate? The proper acceleration is still 0.
Of course, in non-inertial frames you can get weird coordinate expressions for the fields, but those are just coordinate expressions and not particularly meaningful. And you would have to be much more specific about the coordinates to calculate those coordinate expressions anyway.
That's not what the equivalence principle says.
Can you state the equivalence principle? If not, we should start there instead.
The equivalence principle is about local objects, the em. field is not. There's a long history about the question, whether a freely falling point charge radiates or not. The answer is that it does radiate and that this does not violate the equivalence principle:
https://doi.org/10.1016/0003-4916(60)90105-6
With radiation defined very carefully to account for the different frames
Likes vanhees71
I agree there's no proper acceleration so i guess the charges don't radiate.
I suppose the statement of the EP that I'm more comfortable with is the idea that the effect of a gravitational field is equivalent to an accelerating reference frame.
And that is not a correct description of the equivalence principle.
Likes vanhees71
Related to Falling EM system contradicts the equivalence principle?
1. What is the equivalence principle?
The equivalence principle is a fundamental principle in physics that states that the effects of gravity are indistinguishable from the effects of acceleration. This means that in a small region of space, an observer cannot tell the difference between being in a gravitational field and being in an accelerating reference frame.
2. How does the falling EM system contradict the equivalence principle?
The falling EM (electromagnetic) system refers to a hypothetical scenario in which a charged particle is falling in a uniform gravitational field while also experiencing a uniform electric field. This scenario contradicts the equivalence principle because the electric field would cause the charged particle to experience a force that is dependent on its charge, while the gravitational field would cause the particle to experience a force that is dependent on its mass. This violates the principle that the effects of gravity and acceleration should be indistinguishable.
3. Is the falling EM system a real-world scenario?
No, the falling EM system is a hypothetical scenario that has not been observed in the real world. It is often used as a thought experiment to explore the implications of the equivalence principle.
4. What are the implications of the falling EM system for our understanding of gravity?
The falling EM system raises questions about the true nature of gravity and whether it can be unified with other fundamental forces, such as electromagnetism. It also challenges our understanding of the equivalence principle and whether it holds true in all situations.
5. How can we test the validity of the equivalence principle in light of the falling EM system?
One way to test the validity of the equivalence principle is through precision experiments with objects of different masses and charges in different gravitational and electric fields. If the equivalence principle holds true, these objects should experience the same acceleration regardless of their mass or charge. Any deviations from this would indicate a violation of the equivalence principle and could potentially lead to new theories of gravity.
  • Classical Physics
