Falling Rain Drop (Variable Mass)
In summary: The differential equation for a raindrop with mass ##m_0\geq 0## is solved to find the velocity as ##t\to\infty##. The velocity is found to be ##v(t) = \frac{m_0g}{k}+\frac{gt}{2}## where ##k## is a constant. Interestingly, at large times the velocity always increases by ##g/2##, regardless of ##\alpha##.
Potatochip911
318
Suppose a rain drop with mass ##m_0\neq 0## is falling due to gravity with initial velocity ##v_0##, assume ##\frac{dm}{dt}=k=##constant. Solve the differential equation and determine the velocity as ##t\to\infty##
##F=\frac{dp}{dt}=\dot{m}v+m\dot{v}##
Since ##F=mg## the D.E. is ##\dot{m}v+m\dot{v}=mg##, substituting in ##\frac{dm}{dt}=k## we find ##kv+m\dot{v}=mg##, since the mass increases with time we have ##m=m_0+kt##. One method I've attempted is essentially using the integrating factor but since the LHS is already a product rule derivative I don't need to multiply it by anything so:
$$\frac{d}{dt}(mv)=mg \\
\int \frac{d}{dt}(mv)dt=\int mg dt=\int mg \frac{dt}{dm}dm=\frac{g}{k}\int_{m_0}^{m} m\, dm\\
v(m_0+kt)+C=\frac{g}{2k}((m_0+kt)^2-m_0^2)=\frac{g}{2k}(2m_0kt+k^2t^2)
at ##t=0##, ##v=v_0\Rightarrow##, ##v_0(m_0+0)+C=0\Longrightarrow C=-v_0m_0##
therefore...
$$v(m_0+kt)-v_0m_0=gm_0t+\frac{gkt^2}{2}\\
v(m_0+kt)=m_0(v_0+gt)+\frac{gkt^2}{2} \\
v=\frac{m_0(v_0+gt)}{m_0+kt}+\frac{gkt^2}{2(m_0+kt)}
Now I find this solution a bit odd since my professor said that it would become asymptotic but I think he's wrong about this? The first term will approach ##\frac{m_0g}{k}## but the second term clearly diverges as ##t\to\infty## and it doesn't make sense that an object would reach a terminal velocity without drag. I suppose you could say it asymptotically goes to infinity but it's increasing linearly...
By itself that means nothing. What is supposed to tend asymptotically to a constant, or to a certain function of what?
The link DrSteve posted shows the acceleration tends to a constant.
Likes Potatochip911
Okay I suppose I'm just too used to thinking of functions converging to a constant when that term is mentioned.
The velocity tends to a simple function as t tends to infinity. What is that simple function?
Likes Potatochip911
I believe it's just ##v=\frac{m(t)g}{k}## from setting ##\dot{v}=0## in the D.E.
Simplifying my expression for ##v(t)## would give ##v(t)=\frac{m_0g}{k}+\frac{gt}{2}## though
Sorry for so many edits but just noticed that the first one becomes ##v=\frac{m_0g}{k}+gt## which is almost the same as the result from simplification.
You can not set ##\dot v = 0##. The acceleration does not tend to zero. At great t, v increases linearly with time with rate g/2 instead of g as it were for a constant-mass body.
Likes Potatochip911
Whoops, I realize now it doesn't make much sense to set acceleration equal to 0 :)
Interestingly at large t, it appears v always increases by ##g/2## regardless of ##\alpha## for ##\frac{dm}{dt}=k^{\alpha}##
##k^{\alpha}## is just an other constant. Why do you mix alpha in? It was said that dm/dt=k.
Likes Potatochip911
It is interesting the acceleration at long time tends to g/2, regardless of k.
Likes Potatochip911
I was looking through my posts when I stumbled upon this one and I can't understand how they're solving the differential equation in the paper that was linked in response to this post.
The author states that when ##\frac{dm}{dt}## is independent of velocity then the accretion equation can be solved for ##m(t)## and then the Newtonian equation can be solved for ##v(t)##. I'm having trouble seeing this since for my problem ##\frac{dm}{dt} = k## which leads to ##m(t) = m_0 + kt##. I don't understand how this helps solve ##mg = \frac{dm}{dt}v + m\frac{dv}{dt}## for velocity.
Dividing through by ##m## and using ##\frac{dm}{dt}=k## I can get the result $$g = \frac{kv}{m} + \frac{dv}{dt}$$
At which point I can't see how to make progress, evidently I should apply ##m=m_0+kt## but I don't see how that helps when I can't seem to get ##\frac{dv}{v}## without a ##\frac{g}{v}## term
I think expanding ##\frac d{dt}(mv)## was unhelpful.
Go back to ##mg= \frac d{dt}(mv)## and substitute for m using m0 etc.
Both sides are directly integrable wrt t.
Likes Potatochip911
Potatochip911 said:
therefore...
Apologies, but how has the [itex] v [/itex] appeared in the RHS?
You might want to think about integrating factors. The differential equation is of the form:
[tex] \frac{dv}{dt} + f(t) v = h(t) [/tex]
where [itex] h(t) [/itex] is a constant in this case. If you use an integrating factor, you get to an expression that is almost similar to the form you derived in the original post.
Likes Potatochip911
$$mg = \frac{d}{dt}(mv)$$
$$d(mv) = mg\cdot dt$$
$$\int_{t=0}^{t=t} d(mv) = g\int_0^t(m_0+kt)dt$$
$$mv-m_0v_0 = g(m_0t+kt^2/2)$$
$$v = \frac{m_0v_0+g(m_0t+kt^2/2)}{m_0+kt}$$
Their expression for velocity is so simplified in the paper I can't even tell if this is correct.
I have basically no idea how I derived anything in the original post. I don't even understand how I got this
Does this part make sense to you?
I thought I couldn't use integrating factor here because the ##m## is actually ##m(t)## and it's in the denominator for the ##f(t)## function. I might be wrong I haven't done integrating factor in years.
That all looks right, and you can quickly see the asymptotic behaviour is v=gt/2.
Does this answer your question in post #11?
Likes Potatochip911
Just thought I would respond to this part for now. I believe you can use an integrating factor here.
Background on integrating factor (might be useful if you haven't seen it for a while; feel free to skip this section):
Without just jumping to the formula, the integrating factor can be thought of as the answer to the following question: "what term do I need to multiply the equation by such that I can write it as a derivative of a product?" I.e. if we have:
[tex] \frac{dv}{dt} + f(t){v} = h(t) [/tex] it would be much more convenient to write the LHS in a form that is more easily integrated (wrt. [itex] t [/itex]). If we have integrating factor [itex] P(t) [/itex] and we multiply it through to get:
[tex] P(t) \frac{dv}{dt} + P(t)f(t){v} = h(t)P(t) [/tex]
we now want the LHS to be expressed as [itex] \frac{d}{dt}(P(t)v(t)) [/itex]. By using the product rule and comparing coefficients, we can see that [itex] \frac{dP(t)}{dt} = P(t)f(t) [/itex]. This can be solved to give the form of the integrating factor [itex] P(t) = e^{ \int f(t) dt } [/itex]
Therefore, if we integrate the equation with respect to [itex] t [/itex]:
[tex] P(t)v(t) = \int P(t)h(t) dt[/tex]
Specific response to your question:
So we have [itex] f(t) = \frac{k}{m_0 + kt} [/itex]. Can that be integrated? (Hint: think about natural logarithms). Don't forget that the integrating factor is [itex] P(t) = e^{ \int f(t) dt } [/itex]
One final note:
I hasten to add this as you have already been helped, but I just thought to let you know of another way of getting to the differential equation (it is my preferred approach when doing these types of questions). It is very similar to what you have written, but you can perhaps use it to double-check whether your ODE is correct in future problems. The whole principle here (as you know) is that Impulse = change in momentum. So we can draw a diagram of the mass at time [itex] t [/itex]: it has mass [itex] m [/itex] and velocity [itex] v [/itex] (downwards). It has a weight [itex] mg [/itex] acting on it downwards. We can then draw an 'after' picture at time [itex] \delta t [/itex] later (so at time [itex] t + \delta t [/itex]). It now mass mass [itex] m + \delta m [/itex] (as it is accumulating mass) and has velocity [itex] v + \delta v [/itex] (downwards). During the time [itex] \delta t [/itex], an impulse equal to [itex] mg \delta t [/itex] acted on the raindrop. If we resolve vertically downwards and write out impulse = change in momentum:
[tex] mg \delta t = (m + \delta m)(v + \delta v) - mv [/tex]
We can then simplify, divide by [itex] \delta t [/itex] and let [itex] \delta t [/itex] tend to 0 to form the same ODE that you derived.
Please note that the 'before' and 'after' diagrams may look different for different types of problems (e.g. rocket burning fuel). While diagrams may differ, the underlying concepts are the same.
Hope that was useful. If not, let me know which parts could be more clear. Apologies if you already knew all of that, but perhaps it might be helpful to another reader.
Likes Potatochip911
Yes it does thanks.
Interesting for some reason I had it in my mind that they had to be polynomials.
$$\frac{dv}{dt}+\frac{k}{m}v=g $$ $$\ln P(t)=\int \frac{k}{m_0+kt}dt=\ln{\left (m_0+kt\right )}+C $$ $$P(t)=e^C(m_0+kt)$$
$$\frac{d}{dt} ( v(m_0+kt)e^C ) = (m_0+kt)e^Cg$$
$$v(m_0+kt)-v_0m_0 = g(m_0t+kt^2/2)$$
$$v = \frac{v_0m_0+g(m_0t+kt^2/2)}{m_0+kt}$$
resulting in the same answer as from the previous method, nice.
Master1022 said:
One final note:
I have seen this before but mostly forgotten about it, I will try to use this method in the future when possible.
I also just realized the equations in the original post used to be separated in latex using "\ \" which no longer creates new lines, the ##v## in post #13 is actually at the start of a newline.
Likes Master1022
Related to Falling Rain Drop (Variable Mass)
1. What causes a raindrop to fall?
A raindrop falls due to the force of gravity acting on it. As the raindrop falls, it accelerates towards the ground until it reaches its terminal velocity, which is the maximum speed it can reach due to air resistance.
2. How does the mass of a raindrop affect its fall?
The mass of a raindrop does not have a significant impact on its fall. The main factors that affect the speed of a falling raindrop are its size and shape, as well as air resistance. However, a larger mass may slightly increase the amount of air resistance and therefore slightly decrease the terminal velocity of the raindrop.
3. What is the average speed of a falling raindrop?
The average speed of a falling raindrop is approximately 8 meters per second. However, this can vary depending on the size and shape of the raindrop, as well as the air resistance it experiences during its fall.
4. Can a raindrop reach a speed faster than its terminal velocity?
No, a raindrop cannot reach a speed faster than its terminal velocity. Once the raindrop reaches its terminal velocity, the force of air resistance is equal to the force of gravity, resulting in a balanced force and a constant speed.
5. How does the height of a cloud affect the fall of raindrops?
The height of a cloud does not have a direct effect on the fall of raindrops. However, it can indirectly impact the speed of a raindrop due to the temperature and wind conditions at different cloud heights. These factors can affect the size and shape of the raindrop, and therefore its terminal velocity and speed of fall.
