Falling Rock Climber (Work and Energy)
In summary, the conversation is about the use of stretchable ropes for rock climbing and the calculation of the distance the rope will stretch when it stops a falling climber. The work-energy principle is applied to find the relationship between the rope's stretch distance (x), the climber's mass (m), the rope's spring constant (k), and the rope's unstretched length (l). The final equation is x = (mg/k)[1+√(1+4kl/mg)], which can be solved to find the stretch distance.
kubaanglin
47
Stretchable ropes are used to safely arrest the fall of rock climbers. Suppose one end of a rope with unstretched length ##l## is anchored to a cliff and a climber of mass m is attached to the other end. Ehrm the climber is a height ##l## above the anchor point, he slips and falls under the influence of gravity for a distance ##2l##, after which the rope becomes taut and stretches a distance ##x## as it stops the climber. Assume a stretchy rope behaves as a spring with spring constant ##k##.
(a) Applying the work-energy principle, show that
$$x=\frac{mg}{k}\left[1+\sqrt{1+\frac{4kl}{mg}}\right]$$
$$U_{GPE}=mgh$$
$$K=\frac{1}{2}mv^2$$
$$U_{spring}=\frac{1}{2}kx^2$$
$$F_{spring}=|kx|$$
$$W=ΔK$$
Before the climber falls
##U_{GPE}=mg(2l+x)## and ##U_{spring}=0##
After the climber has reached maximum displacement
##U_{GPE}=0## and ##U_{spring}=\frac{1}{2}kx^2##
Therefore ##mg(2l+x)=\frac{1}{2}kx^2##
I feel that this is incorrect because I am not using the work-energy principle, but what is the relevance if the kinetic energies at the beginning and end of the fall are zero? Should I split this problem into two parts where ##\frac{1}{2}mv^2=mg(2l)## at the point when the rope begins to stretch and then work from there?
You've done alright. You've used the work-energy principle to convert the GPE into the work done by gravity resulting in KE of the climber. You didn't, for example, use kinematic equations and the acceleration due to gravity to find the speed, then determine the KE from that.
Just solve your equation for x.
Related to Falling Rock Climber (Work and Energy)
What is a "Falling Rock Climber (Work and Energy)"?
A "Falling Rock Climber (Work and Energy)" is a scientific concept that involves the study of the relationship between work and energy in the context of a rock climber falling from a height.
How does a falling rock climber demonstrate the concept of work?
When a rock climber falls, they are exerting a force against gravity, which is considered work. This work is equal to the force of gravity multiplied by the distance the climber falls.
What is the relationship between work and energy in a falling rock climber?
The relationship between work and energy in a falling rock climber is that the work done by the climber is converted into kinetic energy as they fall. This kinetic energy is then dissipated upon impact with the ground.
How does the height of the rock climber affect their potential energy?
The higher the rock climber is, the greater their potential energy will be. This is because potential energy is directly proportional to the height of an object above the ground.
Can a rock climber's position on the rock affect their potential energy?
Yes, a rock climber's position on the rock can affect their potential energy. If the climber is at a higher position, they will have more potential energy than if they were at a lower position. This is due to the fact that potential energy is also affected by an object's position in a gravitational field.
