Falling solid cylinder with string
In summary: No, you hadbut the T is a force not a torque. Just replace the T with the torque that T exerts about the centre of the cylinder.torque is the tangential forceNo, a torque is not a force. How do you find the torque of a force about an axis?torque=R F sin(theta)where theta is the between R and FRight, so correct your equation in post #15 and go from there.torque=T RF= tensionR= radius of cylindertheta = 90 degreesTorque=T RRight, so correct your first equation in post #15 and go
Suyash Singh
168
m:mass of solid cylinder
T: tension in string
w:angular velocity
m(g-a)=T
mg-ma=T
a=v^2/r=w^2r
now what?
More equations needed ! :smile:
Suyash Singh said:
a=v^2/r
How do you get that?
Likes Suyash Singh
its the equation for centripetal acceleration
Centripetal force = mv^2/r for cylinder
And what role does that play here ?
What about the relation between ##\omega## and ##T## ?
What is ##I## ?
Likes Suyash Singh
Make a sketch to see where forces act (free body diagram)
What is ##I## ?
Tension = m(g-a)+mrw^2
The only centripetal forces are internal to the cylinder. They have no consequence for the rate at which the cylinder descends.
You need to think about angular acceleration and its relationships to torque and to linear acceleration.
I think T = W and a = (2/3) g
Please do not post answers at such an early stage. This is a homework forum. The idea is to provide hints, correct misunderstandings and point out errors.
Did you read the guidelines?
Likes Suyash Singh
My bad. You might start by considering the motion to be about the contact between the cylinder and the string like considering the motion of a tire down the road by analyzing the motion of the tire about the contact with the road.
Likes Suyash Singh
Dr Dr news said:
I think T = W ...
The tension would be equal to the weight only if the acceleration is zero. See OP's equation in #1, mg - ma = T.
Tension=I alpha
where I is moment of inertia
and alpha is angular acceleration
Tension=1/(2) (MR^2) alpha
but what is alpha?
oh ok so i found this formula
a=r alpha
So T= 1/(2) (mr^2) a/r
=1/2 mra
Also
T=m(g-a)
comparing we have
1/2mra=m(g-a)
1/2ra=g-a
(r/(2)+1)a=g
r+2/2=g/a
r+2=2g/a
a=2g/r+2
now what?
Suyash Singh said:
T= 1/(2) (mr^2) a/r
Not quite. You are using T as a force, but on the right you have Iα, which is not a force. What have you forgotten?
Torque=I alpha
Suyash Singh said:
Torque=I alpha
Right, so what is the torque in this case?
T= mr alpha
T=m(g-a)
r alpha =m(g-a)
a=mg-ma
a(m+1)=mg
a=mg/m+1
Suyash Singh said:
T= mr alpha
No, you had
Suyash Singh said:
T= 1/(2) (mr^2) a/r
haruspex said:
No, you had
what do you mean?
Suyash Singh said:
what do you mean?
What is the torque that the tension T exerts on the cylinder about the cylinder's axis?
Torque=I alpha
=1/2 mr^2 a/r
=1/2 mar
=1/2 T r
If you are taking moments about the string-cylinder contact point, you need to use the parallel-axis theorem.
Suyash Singh said:
Torque=I alpha
No, I mean using the equation you wrote in post #21 what is T's torque about the axis of the cylinder?
Dr Dr news said:
If you are taking moments about the string-cylinder contact point.
I see no evidence that Suyash is doing that.
Likes Suyash Singh
  • #31
Torque=F R sin(theta)
  • #32
Yes, but that's a generic equation. You need to write it in terms of the variables in this question: T, r etc. What are F, R and θ here?
  • #33
F= tension
theta = 90 degrees
Torque=T R
  • #34
Suyash Singh said:
F= tension
theta = 90 degrees
Torque=T R
haruspex said:
Right, so correct your first equation in post #15 and go from there.
  • #35
Torque= T R
=m(g-a)R
