Falling (toppling) rigid tower (uniform rod)
In summary, the conversation involved a person working on an animation of a vertical tower falling to the ground and needing to calculate the angle of the tower in a given time. They were provided with a link to a resource on moment of inertia and were given a formula to calculate the trajectory. The conversation also discussed the parameters needed for the formula, including the initial angular velocity and the length of the tower.
zaphat
I am working on an animation, which involves a rigid, vertical tower falling (toppling) to the ground, and I am stuck at its core physics.
Actually this is the same as the thin uniform rod initially positioned in the vertical direction, with its lower end attached to a frictionless axis.
I would need the angle (compared to the ground) of the rod in a given time.
The tower is 50meters long. (It is a simple animation, the effect of gravity only is enough: no friction, no radial acceleration, no stress forces etc. is needed)
Thanks in advance
So what have you tried to do to solve your problem?
Here is something to grit your teeth on with regards to moment of inertia.
http://www.uta.edu/physics/courses/wkim/lctr_notes/phys1443-fall06-1116-20(F).pdf
Your tower is a pendulum, whose initial angle from "pointing down" is 180 degree. Starting from the pendulum's differential equation,
[tex]
x'' + a \sin x = 0
x''x' + a (\sin x)x' = 0
\frac {x'^2 - {x'}_0^2} {2} - a(\cos x - \cos x_0) = 0
[/tex]
## x_0 = \pi ## (the pendulum is upward from "pointing down"), so
[tex]
x' = \sqrt {{x'}_0^2 + 2a(\cos x + 1)}
\int_{\pi}^x ({x'}_0^2 + 2a(\cos x + 1))^{-1/2} dx = t
[/tex]
The latter integral, as far as I can tell, does not exist in the closed form, but it can be tabulated between ## \pi ## (upward) and ## \pi/2 ## (toppled), which will give you the trajectory you want. You will need ## {x'}_0 ## which is the initial angular velocity, and you will need ## a ##, which is ## \frac {3g} {2L} ## for a uniform rod, ## L ## being the length.
Related to Falling (toppling) rigid tower (uniform rod)
1. How does the height of a rigid tower affect its falling speed?
The height of a rigid tower does not affect its falling speed. According to the law of free fall, all objects fall at the same rate regardless of their mass or shape. This means that a shorter tower will fall at the same speed as a taller tower.
2. Can a rigid tower fall faster than the speed of gravity?
No, a rigid tower cannot fall faster than the speed of gravity. The maximum falling speed for any object is the speed of gravity, which is approximately 9.8 meters per second squared.
3. How does the shape of a rigid tower affect its falling motion?
The shape of a rigid tower does not affect its falling motion. As long as the tower is uniform and not affected by external forces like wind, it will fall straight down at a constant speed.
4. Why does a rigid tower topple when it reaches the ground?
A rigid tower topples when it reaches the ground because of the distribution of its mass. When the tower falls, the top part experiences a greater downward force due to gravity than the bottom part. This causes the tower to rotate and topple when it reaches the ground.
5. Does the mass of a rigid tower affect its falling speed?
No, the mass of a rigid tower does not affect its falling speed. As mentioned before, all objects fall at the same rate regardless of their mass. However, a heavier tower may cause more damage upon impact due to its greater kinetic energy.
  • Mechanics
  • Classical Physics
