FAQs about Bobrick & Martire's Warp Drive & Lentz's Paper
  • B
  • Thread starter rgtr
  • Tags
    Warp
In summary: I believe the main complaint by Visser et.al. against Bobrick et.al. is that they don't compute the whole Einstein tensor; mostly they just compute the 00 component of it. This is simply insufficient to make any claims about satisfying an energy condition. Thus, I would say it is simply an open question whether a subluminal warp drive with ordinary matter is possible - it very well may be, but the Bobrick et.al. analysis on this point is incomplete per Visser et.al.
rgtr
92
TL;DR Summary
I have a few layman's questions about warp drives.
Bobrick and Martire's warp drive.
https://arxiv.org/abs/2102.06824
Lentz's paper.
https://arxiv.org/abs/2006.07125
Is the warp shield the bending of space in the warp drive?What feeds energy into the system to accelerate? I mean can a planet accelerating be equivalent to a rocket engine accelerating to power the warp drive? In a warp drive in order to speed up do you need a to feed in energy?
what is the warp shield made of? I mean is it man made or created by nature?How does any of this relate to Erik lentz paper and my question?In Lentz paper can the warp shield be created by nature or is it man made? In Lentz paper can you accelerate faster then light?By shrinking the passenger area do you need less energy to go faster?
PAllen said:
Both papers you cite are thoroughly refuted here
To be more precise, the claims in the papers cited in the OP that energy conditions are not violated, so that such spacetime geometries might actually be feasible to realize, are refuted.
Just to confirm you are saying "spacetime geometries might actually be feasible to realize, are refuted." because the energy conditions are violated. Is this correct? Do you have a simple definition of energy conditions that warp drives violate? I do not understand the definitions of energy conditions that I found online. Thanks.
It means that the warp drive can only be made out of material that has a negative energy density. By ##E=mc^2## that means it would have a negative mass. If you were to push it to the left it would accelerate to the right.
Such material has never been observed and most likely would not be able to be stable. So generally solutions requiring this sort of exotic matter are considered non-physical.
There seems to be insufficient knowledge that if it were possible to create a macroscopic body violating the dominant energy condition, such a body could simply move on a spacelike trajectory, (I.e. FTL) without need to bother with wormholes or warp drives. This also means ‘a baseball’ of such material could be thrown into the past by two cooperating observers via the tachyonic anti-telephone method.
See, for example:
https://arxiv.org/abs/1106.2336
and more recent work by Weatherall and Geroch that even more generally establishes that there is no expectation (in general relativity) that a small body moves on timelike geodesics unless the dominant energy condition is satisfied.
Likes PeroK and PeterDonis
I find it interesting that in this paper, it's not even the standard dominant energy condition that is shown to be necessary, but a "strengthened" dominant energy condition, which includes the requirement that, basically, the 4-momentum of a piece of matter has to be timelike. In other words, it's almost putting in by hand the fact that small bodies move on timelike worldlines.
I haven’t had a chance to look at these much, but these newer collaborative papers of Weatherall and Geroch seem to be able to use the ordinary dominant energy condition via a new method they introduce (tracking). This means many different lines of research (e.g. Gralla and Wald, as well) converge on the idea that timelike motion of bodies is simply not mandated by GR without the dominant energy condition.
https://arxiv.org/abs/1810.09046
https://arxiv.org/abs/1707.04222
Likes PeterDonis
Sorry for the repetitive question but according to current science warp drives need negative energy even slower then light warp drives? Do you think it would ever be possible to create a positive mass warp drive?
I believe the main complaint by Visser et.al. against Bobrick et.al. is that they don't compute the whole Einstein tensor; mostly they just compute the 00 component of it. This is simply insufficient to make any claims about satisfying an energy condition. Thus, I would say it is simply an open question whether a subluminal warp drive with ordinary matter is possible - it very well may be, but the Bobrick et.al. analysis on this point is incomplete per Visser et.al. Both of these papers actually agree that exotic matter (matter that could move superluminally by itself) is required for superluminal warp drives.
So why hasn't someone calculated or computed all the components of the tensor? Also how does this relate to Lentz paper?
The Lentz paper is simply bogus, per Visser et.al. analysis. Its primary claims about energy conditions are just false.
Why hasn't anyone computed all the components? Visser et.al. have no particular interest in doing so (I would guess). Bobrick et.al. might get around to it in a future paper. But who knows? It is not a simple undertaking.
FAQ: FAQs about Bobrick & Martire's Warp Drive & Lentz's Paper
What is Bobrick & Martire's Warp Drive?
Bobrick & Martire's Warp Drive is a theoretical concept proposed by scientists Harold Bobrick and Joseph Martire. It suggests the possibility of traveling faster than the speed of light by manipulating spacetime.
Who is Lentz and what is his paper about?
Lentz refers to physicist David Lentz, who published a paper in 2012 discussing the potential feasibility of Bobrick & Martire's Warp Drive. In his paper, Lentz explores the theoretical framework and challenges of this concept.
Is the Warp Drive concept scientifically sound?
At this time, the Warp Drive concept is still purely theoretical and has not been proven to be scientifically sound. While it is based on established principles of physics, it would require significant advancements in technology and understanding of the universe to become a reality.
What are the potential implications of a successful Warp Drive?
If the Warp Drive concept were to be proven and developed, it could revolutionize space travel and exploration. It could potentially allow humans to travel to distant planets and galaxies at a much faster rate than currently possible, opening up new possibilities for scientific research and discovery.
Are there any current efforts to test or develop the Warp Drive concept?
There are some ongoing research efforts to explore the possibility of a Warp Drive, but they are still in the early stages and have yet to yield any significant results. Scientists continue to study and debate the feasibility and potential of this concept, but it is still far from being a practical reality.
