Far Field Approximation After a Prism
In summary, the problem requires using Snell's law to find the refraction angle and then using Fresnel diffraction to calculate the field on a screen at a distance $d$ from the prism. The prism's finite width, $D$, must be taken into account in the calculations.
Yoni V
44
A wave with an initial profile ##U(z)=Ae^{ik_0z}e^{-\frac{z^2}{2\sigma^2}}## is traveling in the z direction (yes, the Gaussian profile and the optical axis are not perpendicular). It then passes through a prism with apex angle ##\alpha## and refractive index ##n=n_0+\gamma(k-k_0)## as in the drawing.
Assume the prism is infinite in the axes perpendicular to z.
a) What is the refraction angle (from the z axis); assume small angles.
b) Define the above angle as the new optical axis. With respect to that axis, find the field on a screen of distance d, using the small angle and far field approximations.
Fraunhofer approx., Snell's law.
The first part is a breeze, using Snell's law to get $$\phi=\theta_2-\alpha=\sin^{-1}(n\sin(\alpha))-\alpha$$ and then Taylor etc.
The second part is more of a snow storm with Gaussian blur. It might not be that bad, it's just that I can't figure out how to handle the "infinite" prism.
We actually solved a similar setup in one of the problem sets, where the prism was finite, with width D and height L (corresponding to the apparent sides of the triangle in the picture), and the wave had the form ##Ae^{-\frac{\rho^2}{2\sigma^2}}##. Writing the amplitude right after the wave exits the prism, we have $$U\left(x,y,0\right)=Ae^{-\frac{x^{2}+y^{2}}{2\sigma^{2}}}e^{ikD}e^{ik\left(1-n\right)\left(L-y\right)\alpha}$$
after approximating the distance traveled through the prism as ##d(y)=(L-y)\tan(\alpha)\approx(L-y)\alpha##.
Then, using Fraunhofer approx. $$-\frac{ik}{2\pi z}e^{ik\left(z+\frac{x^{2}+y^{2}}{2z}\right)}\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}dx'dy'U\left(x',y',0\right)e^{-i\frac{k}{z}\left(xx'+yy'\right)}$$
it's just algebra to get to something like $$U\left(x,y,z\right)=-\frac{ikA}{2\pi z}\left[\frac{1}{\sqrt{2\pi\sigma^{2}}}\right]e^{ikD}e^{ik\left(n-1\right)\alpha L}e^{-\frac{\sigma^{2}}{2}\left(\frac{2\pi}{\lambda z}\right)^{2}\left[x^{2}+\left(y+\left(n-1\right)\alpha z\right)^{2}\right]}$$ (I might have erred along the way... nvm...)
We can also deduce the angle of the new optical axis and compare it to the geometric analysis, by noticing we have the center of our new Gaussian, so it's just quick trig to get the angle.
But now for this setup, I can't make much progress. First, all my answers were up to a constant phase, because I don't have D, so I can't really tell how much phase the wave in different places along the "y" axis had accumulated. So I can only make it relative. Second, Using Fraunhofer method doesn't make sense, because since it doesn't take z elements into account, it predicts that for all "z-only" profiles we would get the same diffraction pattern. So my next two guesses are:
1) simply claim ##\Phi=Ae^{ik_0d}e^{-\frac{d^2}{2\sigma^2}}e^{-i\omega t}## because it's the same beast but in a different direction. But that's kinda lame, I don't buy it myself...
2) assume the profile remains in the z direction, and just calculate using trig for a given d and refraction angle ##\phi## from the z axis, what's the corresponding z value for all x,y. But that also seems incomplete, as it makes no use of some of the data, specifically the refractive index and proposition to assume far field approx.
Sorry for the length.
Any thoughts?
A:I think you are missing the most important part of this problem: the prism is not infinitely wide. It has a finite width, $D$, which means the wavefront that exits the prism will have a finite size, $2D$. Thus, when calculating the field on a screen at distance $d$, you should use Fresnel diffraction instead of Fraunhofer diffraction.The Fraunhofer approximation is valid only in the limit of $D \rightarrow \infty$ (or, equivalently, $L \rightarrow \infty$), and so it should not be used here.
Related to Far Field Approximation After a Prism
1. What is the Far Field Approximation After a Prism?
The Far Field Approximation After a Prism is a mathematical method used to calculate the electromagnetic field distribution in the far field region after a light beam has passed through a prism. It is used to describe the behavior of light in a practical situation where the observation point is far from the light source.
2. Why is the Far Field Approximation After a Prism important?
The Far Field Approximation After a Prism is important because it allows us to accurately predict the behavior of light after it has passed through a prism. This is crucial in many scientific fields, such as optics, where understanding the behavior of light is essential for developing new technologies and conducting experiments.
3. How is the Far Field Approximation After a Prism calculated?
The Far Field Approximation After a Prism is calculated using a mathematical formula that takes into account the properties of the prism, such as its refractive index and angle of incidence. It also considers the wavelength of the light and the distance between the prism and the observation point.
4. What are the limitations of the Far Field Approximation After a Prism?
While the Far Field Approximation After a Prism is a useful tool, it does have limitations. It assumes that the light beam is monochromatic (single-wavelength) and that the prism is thin, among other simplifying assumptions. It also becomes less accurate as the observation point gets closer to the prism.
5. What are some real-world applications of the Far Field Approximation After a Prism?
The Far Field Approximation After a Prism has many practical applications, including in the design of optical instruments such as lenses, cameras, and telescopes. It is also used in the study of light-matter interactions, such as in spectroscopy and microscopy. Additionally, it is used in the development of technologies such as laser machining and fiber optics communication.
