Faraday cage made of a real conductor
In summary: Depending on the application (size, frequencies involved, etc.), the biggest issue with shielded enclosures is seams (like along doorway edges) and entries for cables (like power, Ethernet data, etc.). - Welding up a shielded box is not that hard, but putting doors and access ports on it can be challenging.
cuallito
95
A faraday cage made of a perfect conductor would theoretically have a zero E field inside.
However, are there cases where a faraday cage made of a real conductor like copper wouldn't block out all EM radiation, like very high or low frequencies? How can the design be improved to make a real faraday cage work more closely to an ideal one? Grounding?
Depending on the application (size, frequencies involved, etc.), the biggest issue with shielded enclosures is seams (like along doorway edges) and entries for cables (like power, Ethernet data, etc.). Welding up a shielded box is not that hard, but putting doors and access ports on it can be challenging.
One of the things you do with doors and similar access ports is to use conductive gasketing to seal the door to the frame. Such gasketing must have many points of contact between the surfaces, and have high contact pressure at those contact points to prevent corrosion.
More info about typical shielded enclosures and rooms here:
https://www.ets-lindgren.com/products/shielding?page=Products-Landing-Page
https://www.ets-lindgren.com/support/articles-whitepapers?page=Articles-WhitePapers-Page
Likes DaveE
It will depend upon frequency and conductivity. This is in most textbooks.
There's lots of stuff on the web about this. It's a big issue for the EMC requirements of electronic equipment.
Here are a couple of things you can look into to learn more about shielding effectiveness:
- Skin effect; the effect of limited conductivity of the shield material.
- "Waveguide beyond cutoff"; the effect of openings and seams in the enclosure.
Likes hutchphd
FAQ: Faraday cage made of a real conductor
What is a Faraday cage made of a real conductor?
A Faraday cage made of a real conductor is a type of shielding material that is designed to block external electric fields. It is typically made of a conductive material, such as copper or aluminum, and is used to protect electronic devices from electromagnetic interference (EMI).
How does a Faraday cage made of a real conductor work?
A Faraday cage made of a real conductor works by creating a barrier that prevents external electric fields from reaching the inside of the cage. This is achieved by the conductive material of the cage redistributing the electric charge and creating an equal and opposite charge on its surface, effectively canceling out the external field.
What are the benefits of using a Faraday cage made of a real conductor?
A Faraday cage made of a real conductor provides protection against EMI, which can disrupt or damage electronic devices. It can also protect sensitive information from being intercepted by blocking electromagnetic signals. Additionally, it can prevent electric shocks and fires caused by lightning strikes or power surges.
Are there any limitations to using a Faraday cage made of a real conductor?
While a Faraday cage made of a real conductor is effective at blocking external electric fields, it is not 100% impenetrable. Extremely strong electric fields, such as those produced by a lightning strike, may still be able to penetrate the cage. Additionally, the cage must be properly grounded in order to function effectively.
How is a Faraday cage made of a real conductor different from other types of shielding materials?
A Faraday cage made of a real conductor is different from other types of shielding materials, such as conductive fabrics or paints, because it provides a complete enclosure rather than just a surface coating. This makes it more effective at blocking external electric fields and provides better overall protection for electronic devices.
