Faraday Cage not blocking wifi
In summary, a metal hull can act as a Faraday cage, but it may not be effective in blocking all types of radio signals. This is due to gaps or slots in the metal that can act as antennas, and the design and power of the receivers and transmitters inside and outside the hull. In some cases, grounding the metal can improve its ability to block signals. Other factors such as local interference can also affect the performance of the hull as a Faraday cage.
DzinVision
In our school we made a submarine. The inner hull is a few cm thick metal, so it should be a good farady cage, but it does not act like one when blocking wifi from inside the hull. Wifi antenna is not touching the hull. The hull acts like a faraday cage when blocking a phone signal from the outside the cage. My question is, why does the hull not block wifi signal comming from inside the hull, but does block other signals comming from outside the hull.
wifi is much higher frequency
how RF tight are the seals around the hull ?
water tight is one thing, RF tight is a whole different ball game
would take very little for 2.4 GHz or 5.8 GHz to leak out
Gaps or slots in or between sheets of metal can sometimes act like aerials. As davenn said, it can be difficult to stop RF getting out.
'Fraid not. It's very hard to make a good faraday cage. When an EM wave hits the metal surface, it sets of currents all over. Where there is a join / seam, there will be a resistance and some current will flow in through the join (finite gap with a resistive layer on the metal surface). If only 1/10 of the surface current flows through then you will have something in the region of 1/100 of the incident power getting through. In RF terms, that's almost like a wide open window because receivers cope with a vast range of input signal levels. But, if it were a 'good' cage then you'd get no communications through it??
The reason why one way behaves differently from the other way could be the design of the receivers and transmitters inside and outside the box. Your receiver in the box may be just below threshold whilst the outside receiver may be 'better'. Also the transmit powers may be different. It would depend on the actual circumstances.
Why not fit a fibreglass window in the hull?
Likes DzinVision
If a radio signal originates inside the hull then it can propagate freely inside the hull. It just bounces around when it hits the metal. But when it originates outside, if the hull has no holes, it cannot penetrate.
that didn't really answer the Q :wink:
I have made some receivers to detect static charges. I usually run a point out from a coil around the the antenna coil of a AM battery powered transistorized radio. The radio is then covered by aluminum foil. The interesting thing is that to shield the AM signals it is important to not only use aluminum foil but to ground the foil to the ground circuit on the radio.
Whilst there is a principle called Reciprocity which says that a link should work the same in either direction, you can have local interference caused by equipment in the submarine. That will mean you have a worse Carrier to noise (/ interference) ratio inside the hull and worse performance, as a consequence.
Related to Faraday Cage not blocking wifi
What is a Faraday Cage?
A Faraday Cage is a conductive enclosure that is designed to block electromagnetic fields.
How does a Faraday Cage work?
A Faraday Cage works by creating a barrier of conductive material around an object or space. This barrier blocks external electromagnetic fields from entering the cage, thus protecting the interior from interference.
Can a Faraday Cage block wifi signals?
Yes, a Faraday Cage can block wifi signals if it is made of a conductive material and is properly sealed. However, some materials used to make Faraday Cages, such as wire mesh, may not completely block all wifi signals.
Why would someone want to use a Faraday Cage for wifi?
Some people may want to use a Faraday Cage for wifi to protect their devices from outside interference or to prevent their wifi signal from being accessed by others. It can also be used for security purposes, such as in military or government facilities.
Are there any other uses for Faraday Cages?
Yes, Faraday Cages have various other uses besides blocking wifi signals. They are commonly used in electronic testing, in medical imaging to prevent outside interference, and in lightning protection for buildings and electronic equipment.
  • Electromagnetism
  • Electromagnetism
14K
  • Electromagnetism
10K
11K
  • Electrical Engineering
11K
