Faraday's Law Need help with explanation
In summary, the three wire-loop configurations shown in the link have different orientations and currents, but the loop in (a) will induce the largest V emf due to the fact that the magnetic field generated by the current in the long straight wire penetrates the loop area at a 90 degree angle, resulting in a changing flux and therefore an induced emf. This is in contrast to the loops in (b) and (c) which have a parallel magnetic field, resulting in no flux and no induced emf.
http://em.groups.et.byu.net/embook/ch6/mod6.4.html
^^The link has the problem
Three wire-loop configurations are shown below. In all cases, the long straight wire is oriented along the z-direction and carried current I=Io cos wt. The loop in (a) lies in the y-z plane. In contrast, the loops in (b) and (c) lie in the x-y plane. All three loops are of equal area. Explain which loop configuration will induce a V emf with the largest amplitude.
I know the answer is (a), but can someone explain to me the reason configuration (A) induces the largest V emf?? compared to (b) or (c)??
The emf induced is proportional to the rate of change of flux penetrating the area of the loop.
ε = - dψ/dt
(which comes from ∇×E = -∂B/dt integrated over the area enclosed by the loop)
The current I sets up a magnetic field that circles the wire. Take your right hand, point your thumb in the direction of the current and your folded fingers show you how the magnetic field circles the wire.
For b and c, the field is parallel to the plane containing the wire loop so no flux passes through the area enclosed by the loop. ∂ψ/dt is zero so no emf is induced.
For a, the field penetrates the loop area at 90 degrees. Because the current is sinusoidal and the B it generates is proportional to the current, the B penetrating the loop is also sinusoidal, ie is changing. Therefore an emf is induced in the loop.
FAQ: Faraday's Law Need help with explanation
What is Faraday's Law?
Faraday's Law is a fundamental principle in physics that describes the relationship between a changing magnetic field and an induced electric field. It was discovered by scientist Michael Faraday in the 19th century.
How does Faraday's Law work?
Faraday's Law states that when a conductor (such as a wire) is placed in a changing magnetic field, a voltage is induced across the conductor. This voltage is directly proportional to the rate of change of the magnetic field and the length of the conductor.
What is the equation for Faraday's Law?
The equation for Faraday's Law is E = -N * dΦ/dt, where E is the induced voltage, N is the number of turns in the conductor, and dΦ/dt is the rate of change of the magnetic flux through the conductor.
How is Faraday's Law used in real life?
Faraday's Law is used in many real-life applications, including generators, transformers, and electric motors. It also plays a crucial role in electromagnetic induction, which is the basis for many technologies such as wireless charging and electromagnetic braking.
What are some limitations of Faraday's Law?
Faraday's Law is based on the assumption of a perfect conductor, which does not exist in reality. In addition, it only applies to cases where the magnetic field is changing. It cannot be used to calculate the voltage induced by a constant magnetic field.
