Fast And Slow Muscle Fiber Conundrum
In summary: So, in summary, the slow set will produce more overall tension to the slow muscle fibers, also fatigue or work the slow muscle fibers harder. However, a fast set of fast reps will produce more power/strength overall.
waynexk8
398
Question 1,
WHICH SET WILL PRODUCE MORE, AND MORE OVERALL FORCE FROM THE SLOW MUSCLE FIBERS, THUS IN TURN MORE TENSION TO THEM.
A slow set of slow reps 3/3, using 75% of your 1RM, let us call this 100pounds, 6 repetitions = 36 seconds.
You fail faster in the faster rep with the same weight.
A fast set of fast reps, .5/.5, using 75% of your 1RM; let us call this 100 pounds, 25 repetitions = 15 seconds.
Overall poundage moved.
Slow set 600 pounds,
Fast set 2500 pounds.
Question 2,
How much force would the slow muscle fibers be producing in the slow set and the fast set ? Low, medium, high or all.
I myself would say the slow muscle fibers generate far more force in the faster rep.
3/3 and 1/1 means three seconds up for the positive and three seconds down for the negative in each repetition of the set. 75% means using 75% of a person’s 1 repetition maximum attempt in a lift.
Thank you for your time.
Wayne
Biology news on Phys.org
I am quite surprised at no comments.
What if I changed the question slightly, too, which set will produce more overall tension to the slow muscle fibers, also fatigue or work the slow muscle fibers harder. And make them try and produce more force output.
The power/strength overall output in the faster/slow reps and sets.
Lets calculate how much power/strength I would be used on both rep speeds. Distance weight moved 1.85 M. Since we are using the metric system, we will first need to convert the mass of the barbell into kilograms (200 lb ÷ 2.2 = 91 kg). Secondly, to determine the force we will need to figure out what the weight of the barbell is (W = mg = 91 kg x 9.81 m/s² = 892 kg.m/s² or 892 N). Now, if work is equal to Force x distance then, U = 892 N x 1.85 m = 1650 Nm.
We can calculate that lifting a 200 lb barbell overhead a distance of 1.85 m required 1650 J of work. You will notice that the time it took to lift the barbell was not taken into account.
Let us only add up the positive part of the lift.
The concept of power however, takes time into consideration. If for example, it took .5 seconds to complete the lift, then the power generated is 1650 J divided .5 s = 3300 J/s.
If it took 2 seconds to complete the lift, then the power generated is 1650 J divided 2 s = 412.5 J/s.
Slow set,
412.5 x 6 = 2475Joules.
Fast set,
3300 x 25 = 99000Joules
Wayne
I think I have solved the problem.
On asking your opinions on which set will produce more overall tension, stimuli, stress to the slow muscle fibers ONLY, also fatigue or work the slow muscle fibers harder.
And also make them try and produce more overall force output, in free weights and their dynamics, not Isokinetic/Isometric, so please no studies from Isokinetic Machines that have no relevance to this debate, if you think they have, please say why when you use them.
And when moving free weights, as long as you are not breaking terminal velocity, a faster movement will result in more force being used. A force is required first to maintain static equilibrium and second to generate acceleration.
Additional force results in acceleration of a mass, since the slow movement reduces acceleration; the force used to accelerate the object is near zero above the load its self.
A fast set of fast reps, .5/.5, using 75% of your 1RM; let us call this 100 pounds, 25 repetitions = 25 seconds.
Lets calculate how much power/strength I would be used on both rep speeds. Distance weight moved 1.85 M. Since we are using the metric system, we will first need to convert the mass of the barbell into kilograms (200 lb divided 2.2 = 91 kg).
Secondly, to determine the force we will need to figure out what the weight of the barbell is (W = mg = 91 kg x 9.81 m/s = 892 kg.m/s or 892 N). Now, if work is equal to Force x distance then, U = 892 N x 1.85 m = 1650 Nm.
If it took 2 seconds to complete the lift, then the power generated is 1650 J divided 2 s = 825 J/s.
Slow set,
825 x 6 = 4950Joules.
Fast set,
3300 x 25 = 82500Joules
Wayne
Related to Fast And Slow Muscle Fiber Conundrum
What is the fast and slow muscle fiber conundrum?
The fast and slow muscle fiber conundrum refers to the debate among scientists about whether there are truly two distinct types of muscle fibers - fast-twitch and slow-twitch - or if there is a continuum of muscle fibers with varying properties.
What are fast-twitch and slow-twitch muscle fibers?
Fast-twitch muscle fibers contract quickly and powerfully, but fatigue more easily. They are used for activities that require short bursts of energy, such as sprinting. Slow-twitch muscle fibers contract more slowly and with less force, but can sustain activity for longer periods of time. They are used for activities that require endurance, such as distance running.
How do scientists study the fast and slow muscle fiber conundrum?
Scientists use a variety of techniques to study muscle fibers, including muscle biopsies, muscle fiber typing, and measuring muscle fiber characteristics such as size, strength, and endurance. They also use animal models and computer models to better understand the properties of muscle fibers.
What is the significance of the fast and slow muscle fiber conundrum?
The fast and slow muscle fiber conundrum has important implications for athletes, as well as individuals with muscle-related disorders. Understanding the properties and functions of different muscle fibers can help improve training methods and develop treatments for muscle diseases.
What is the current understanding of the fast and slow muscle fiber conundrum?
While there is still ongoing research, the current understanding is that there is a continuum of muscle fibers with varying properties, rather than distinct types of fast-twitch and slow-twitch fibers. This means that muscles can adapt and change based on training and other factors, rather than being limited to a predetermined type of muscle fiber.
  • Biology and Medical
  • Nuclear Engineering
  • Other Physics Topics
28K
20K
9K
