Favor Request: Proofread an essay for me?
In summary: You could use a stronger opener to grab the reader's attention and make them want to read more. Your main points are introduced well, but you could elaborate more on why these points are important. In summary, Kris pointed out that Georgina's suggestions to improve her writing style were very useful, and Georgina agreed. Secondly, Georgina mentioned that she uses contractions sparingly, and that her thesis statement is not as strong as it could be. Lastly, Kris offered some helpful criticism which Georgina accepted.
finebykris
Sorry! said:
Agreed, this is a very important aspect in my opinion on writing essays.
Agree with this too.
Agree with this too! (Georgina on a roll). Every paper I wrote semi-colons were only to be used in a 'must use' situation. Reason being is that they are most of the time unnecessary and they are hard to know for sure you've used correctly. They must have two independant clauses on either side or be used as a 'super-comma' in a list. Sometimes you've used it correctly but other times the clauses weren't independent so the semi-colon is wrong to use.
Second that. :smile:
I'm not trying to be harsh on your writing syle it's just that all the things that Georgina had pointed out I had noticed while reading too. I just figured that if I told you about it that you would just dismiss it mostly because 'your prof. doesn't mind.' In my opinion these exercises should be about making you a better writer for the future and not to get you a passing grade.
I would have gone through the essay last night making detailed edits but again, as Georgina pointed out the essay was posted in .pdf format which I can not edit.
About the contractions... I'm not taking it lightly. Thanks to your recommendation, in the future, I will try to avoid them entirely, however, I believe that it's not worth the trouble of fixing on this paper.
Thanks for the criticism, both of you. I really didn't noticed that I overused semicolons... If anthing I would think that I overused colons leading into quotations.
Quick question, if a colon precedes a quotation, does the quotation need to be an independent clause?
Also, thanks for catching the pronoun miss usage, for some reason it made sense at the time, hopefully I would have caught it in my own proof of the paper (which I hate yet to do, but I have a hard copy and a red pen to make it easier to find errors... there's something about the printed form that helps me see my mistakes.)
EDIT: Turned it in earlier today, Thanks for the help!
I might not have time to completely read it over and you need it for tomorrow... I don't know if that's tomorrow (today-the 15th) or tomorrow (tomorrow- the 16th) sometimes people say 'tomorrow' just because it's dark outside when they really mean later today :-p
First thing is what writing conventions is it supposed to use... i.e. for citations is it formal/informal... etc.
That would be due 4pm TODAY.
Thanks for the interest. And it is MLA... I am getting my up to snuff and I will update the PDF in a few minutes.
Well, firstly always use no contractions. So that's = that is.
Ive updated the PDF.
Luckily my teacher does not have an issue with contractions. My essay is filled with them.
Like i said, my most common mistake is using the wrong word (minor dyslexia maybe?). Also, sentences arent always complete. I also tend to forget apostrophes on my contractions.
Well, finebykris, if you would have posted this last night or a couple of days ago, and not in a pdf format (I can't edit that for you) I could have helped. As it is, it's 7:30 a.m. and your paper is 8 pages long and you want it done by 4. That's not reasonable. I hesitate to even offer ideas because Sorry! offered one that's an absolute *must* for college/university writing and you blew it off. For what it's worth, DO NOT use contractions in formal/school writing. I don't care if this particular prof doesn't care, don't do it.
Quick glance. You need to get pronouns right. When you refer to a person, do not use "that". As in: he was a writer that blah blah blah. It is "he was a writer WHO".
You use far too many semi-colons and not always correctly. They are predominantly used stylistically and therefore sparingly. They replace a conjunction, and there should be an independent clause on either side of it. You have some with subordinate clauses after the semi-colon.
Your thesis statement isn't well-rounded. You jump to the name of a book, and I don't have any clue how that's supposed to relate to your opening premise. Did the fellow you're writing about write the book? Don't make assumptions as in: oh, the prof knows what I'm talking about so I don't have to refer back or connect dots. Connect dots. Assume that someone who knows nothing about your subject matter is going to read your essay, and it needs everything spelled out clearly to make sense to them. Clearly state what you are trying to accomplish with your paper in your first few paragraphs. I have no idea where you're going or why.
That's all I have time to give you with this late notice. As I said, given more lead-time, and I could have combed it and helped more. Nonetheless, from the first three pages I've read, your writing style is clear and concise. You don't try to overdo things with overly-complicated words or catch-phrases. Tighten up your thesis statement and get rid of a bunch of the semi-colons, especially the ones that don't have complete sentences on each side.
Good luck to you!
Good luck to you!
Also, thanks for catching the pronoun miss usage, for some reason it made sense at the time, hopefully I would have caught it in my own proof of the paper (which I hate yet to do, but I have a hard copy and a red pen to make it easier to find errors... there's something about the printed form that helps me see my mistakes.)EDIT: if its not too late, I've added a .doc file to my original post. Remember, all i need right now is to make it correct writing, it doesn't need to be good.
Hmm this is a tricky one.
-I know for MLA a quotation over 4 lines in length needs to be preceded by a colon.
-To use it in a sentence the clause that comes before the quote must be an independent clause.
Alright, that's good to know.
Psst. "miss usage" is one word -- misusage. And, further, I'd use misuse in place of that.
I'll look at the .doc file.
i thought so!
Firefox's spellcheck is on crack.
Okay, done. Not bad, actually. What level of school are you writing for?
I cleaned up some typos and fixed some punctuation. No big changes.
A couple of things.
Find a better noun to use than "stuff". (I substituted that word for "work".)
There is no such thing as "very unique". Unique is a one-of. There are no gradations of it.
eco-terrorist(ism) is hyphenated.
I've renamed the document I've proofed to be [2] rather than [1].
Maybe a comparison later when you have some time will help you some. Generally I'd mark changes in coloured fonts so you could see them. I realize you likely don't have time to go through and switch them again.
Anyway, there you go. A quick clean-up. Good luck.
  • Abbey%202000%20MLA[2].doc
A couple of things.
I wish you would have actually changed the color on your corrections. I've got another version that I'm trying to improve a little and it would be nice to just manually add the corrections you made to my original.
Its fine though, I'll try to find them anyways.
Sorry, I thought time was more of a factor. If you print off both the original you posted here and the amended one I posted and compare them, you can highlight the new stuff fairly quickly.
I don't know if it is too late or not but Word has a Compare function under the review tab that will pick out the changes in both documents instantly.
You're welcome. I hope some of it helped.
Related to Favor Request: Proofread an essay for me?
1. Can you proofread my essay for free?
Unfortunately, as a scientist, my expertise lies in the field of science and not in proofreading. It is not ethical for me to provide services for free, as it is a valuable skill that requires time and effort. I suggest reaching out to a professional proofreader or a friend/family member who is skilled in proofreading.
2. How long will it take for you to proofread my essay?
The time it takes to proofread an essay depends on the length and complexity of the essay. It is important to allow enough time for the proofreading process, as it is crucial for catching errors and improving the overall quality of the essay. I suggest providing a minimum of 24 hours for proofreading, but it may take longer depending on the length and quality of the essay.
3. Will you provide feedback or just correct errors?
As a scientist, I understand the importance of providing constructive feedback. Therefore, I will not only correct errors, but also provide feedback on the overall structure, flow, and clarity of your essay. This will help you to improve your writing skills and make necessary revisions for a stronger essay.
4. Can I request specific areas to focus on for proofreading?
Yes, you can definitely request specific areas to focus on for proofreading. It is helpful if you provide any specific concerns or areas that you would like me to focus on while proofreading your essay. This will ensure that I provide thorough and comprehensive proofreading services specific to your needs.
5. How do I know my essay will be kept confidential?
As a scientist, I understand the importance of confidentiality and ethical standards. Any essay that I proofread will be kept confidential and will not be shared with anyone else. Once the proofreading process is complete, I will delete all copies of your essay from my records to ensure your privacy.
  • Other Physics Topics
  • Classical Physics
  • General Discussion
  • STEM Career Guidance
