FBD representing a bird feeder.
  • Thread starter physicsdude123
  • Tags
    Bird Fbd
In summary, when considering the forces acting on the birdfeeder, the weight of the bird and the normal force that the bird exerts on the feeder are two separate forces. The normal force is included in the free-body diagram of the feeder, while the weight of the bird is not.
physicsdude123
A bird sits in a birdfeeder suspended from a tree by a wire, as shown in the diagram below.
Let WB and WF be the weight of the bird and the feeder respectively. Let T be the tension in the wire and N be the normal force between the bird and the feeder. Which of the following free-body diagrams best represents the birdfeeder? (The force vectors are not drawn to scale and are only meant to show the direction, not the magnitude, of each force.)
The image and possible solutions are shown here: http://i48.tinypic.com/5zirzp.png
None, its a conceptual question.
I understand that there must be a force of tension and the weight of the feeder that acts on the birdfeeder. The correct answer is (e) in the picture provided... whereas I thought it was (f). I was just wondering if anyone can clarify the distinction between the N force and W{B} force and why it is the N force that must be considered rather than weight of the bird.
Thank you.
Hello, Physicsdude123. Welcome to PF!
The "weight" of the bird is the force of gravity that acts on the bird. It is a force that the Earth mysteriously exerts on the bird through empty space ("action at a distance"). So, the weight of the bird is a force acting on the bird, not on the feeder.
The bird happens to be in direct contact with the feeder. So, the bird exerts a "contact force" on the feeder where part of the surface of the bird presses on part of the surface of the feeder. This force is called a "normal" force since it acts perpendicularly to the surfaces in contact.
Now, it might happen in a particular situation that the magnitude of the normal force that the bird exerts on the feeder equals the magnitude of the force that the Earth exerts on the bird. But, even so, the weight of the bird and the normal force that the bird exerts on the feeder are distinct forces. When drawing the free-body diagram of the feeder, you would include the normal force that the bird exerts on the feeder but you would not include the force that the Earth exerts on the bird (i.e., the weight of the bird).
Related to FBD representing a bird feeder.
1. What is an FBD representing a bird feeder?
An FBD (free-body diagram) representing a bird feeder is a simplified diagram that shows all the forces acting on the bird feeder. This includes forces such as gravity, tension, and normal force.
2. Why is it important to create an FBD for a bird feeder?
Creating an FBD for a bird feeder allows you to understand and analyze the forces acting on the feeder. This can help you determine the stability and strength of the feeder, as well as identify any potential weak points or areas of concern.
3. How do you create an FBD for a bird feeder?
To create an FBD for a bird feeder, you will need to identify all the external forces acting on the feeder. This can include the weight of the feeder, the force of the birds, and any support or attachment points. Once you have identified these forces, you can draw them as vectors on a diagram and label them accordingly.
4. Can an FBD for a bird feeder change over time?
Yes, an FBD for a bird feeder can change over time. As the feeder is used and exposed to different environmental conditions, the forces acting on it may change. It is important to regularly check and update the FBD to ensure the feeder remains stable and secure.
5. Are there any other benefits to using an FBD for a bird feeder?
Aside from understanding the forces acting on the bird feeder, creating an FBD can also help with troubleshooting any issues with the feeder. By analyzing the forces, you may be able to identify and address any potential problems before they become bigger issues.
